What I found
akinbacon
What I found
#1 Post by akinbacon »
I have a 500g WD external hard drive that went RAW. I ran Testdisk and this is what I found:
Disk /dev/sdb - 500 GB / 465 GiB - CHS 7600 255 63
Invalid FAT boot sector
1 * FAT16 >32M 0 4 5 7600 33 49 122095872
I terrified of writing anything to the disk. Can anyone decipher what this means?
prakash
Re: What I found
#2 Post by prakash »
I am facing the same problem. I have run testdisk on ubuntu.
here what my screen shows.
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60797 255 63
1 P FAT16 >32M 0 32 33 60797 27 30 976703488
>[Quick Search] [ Backup ]
Try to locate partition.
please help..
akinbacon
Re: What I found
#3 Post by akinbacon »
Yeah well good luck finding any help/advice/suggestions......Not a very good forum at all....
Re: What I found
#4 Post by Fiona »
Looks like your partition in your partition table is not correct.
Normally the size of a FAT16-partition is 2 GB.
In your case, running Quick Search and if nothing would be found running Deeper Search also can help.
Please copy and paste the conent of your testdisk.log again.
As long as you don't use the menu Write, nothing will be changed.
It's exactly what I prefer, because it's intended as a diagnose only.
If partitions are found, please mark them and press p to have a try to list your files.
