Command line EO1 search for one file type
Stogie1020
#1 Post by Stogie1020 »
New user with a question, forgive me if it has been answered (I searched and did not find any posts).
I am running Photorec from the command line to search free space on a multi-part E01 file and really only want to recover specific file types. Is there a way to specify only certain file types when running PhotoRec from the command line (switches or a config file), OR, is there a way to process a multi-part E01 image from the executable?
Re: Command line EO1 search for one file type
You can disable some file types from the command line: http://www.cgsecurity.org/wiki/Scripted_run
or also modify the settings in FileOpts and save them.
Run
photorec 'image.E*'
if you want to open a multiple-files Encase image.
