Unable to access to WD portable HD
darklorz
#1 Post by darklorz »
My WD portable hard drive (1TB) did not auto open when i plug it to my computer. Normally, It will auto run and open the hard drive folder. However, the hard drive was detected under Devices and Drives as Local Disk (G: ) so i try double click it to open it but it become not responding.
After waiting for a very long time, a window pop out saying that the location is not available : G:\ is not accessible. The parameter is incorrect. The hard drive was still working fine before i go for my one week holiday. When im back. i try to access my hard drive but to no avail.
After a few days later, the Local Disk (G: ) was not even showing. Thus, i got check the diskmgmt and i got this :
so what shld i do to recover my file from the hard disk using testdisk? Because i run the testdisk software, quick search and deeper search but nothing was found. Need help.
Darklorz
