Next problem, a hard disk to copy the file .PST mail that houses that work in one place. At home and at work worth outlook 2007. I tried to reconstruct a different mail program but failed. Who can tell the detailed program which would be able to restore pst file size of 6.5 gigs ???
Standard outlook scanpst.exe program also could not open the file said error.
what options advise comrades?
I suspect that the error of the screw, the cluster is damaged or something is not turned off properly. about such suspicions.
Restoring PST file from your hard drive.
