After Raid error GPT tables missing
pogow
#1 Post by pogow »
I have a big problem, something happend with my HP DL380 G7 serwer, two disk from six stop working, after reebot server looks fine but, vmware can't see 8,12TB disk, problem is:
"Error: Both the primary and backup GPT tables are corrupt. Try making a fresh table, and using Parted's rescue feature to recover partitions."
I use test disk to recover - log:
Compilation date: 2014-11-13T18:59:50
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=9001677840384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=4009754624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=9001677840384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4009754624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=489127936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=3162112
Disk /dev/sda - 9001 GB / 8383 GiB - CHS 1094391 255 63, sector size=512 - HP LOGICAL VOLUME, S/N:PACCRID11330K2F, FW:5.12
Disk /dev/sdb - 4009 MB / 3824 MiB - CHS 487 255 63, sector size=512 - USB DISK 2.0, FW:PMAP
Drive D: - 489 MB / 466 MiB - CHS 116 64 32, sector size=2048 - hp DVD RW AD-7586H, FW:KH04
Drive X: - 3162 KB / 3088 KiB - CHS 193 16 2, sector size=512 - Microsoft Corporation RamDisk
Disk /dev/sda - 9001 GB / 8383 GiB - HP LOGICAL VOLUME
Analyse Disk /dev/sda - 9001 GB / 8383 GiB - CHS 1094391 255 63
BAD_RS LBA=1 16450622
Warning: Bad starting head (CHS and LBA don't match)
VMFS 0 32 33 1094363 158 3 17580949504
VMFS 5, 9001 GB / 8383 GiB
file_pread(4,2,buffer,401532928(1094391/169/51)) lseek err Invalid argument
file_pread(4,1,buffer,401532928(1094391/169/51)) lseek err Invalid argument
file_pread(4,1,buffer,401532927(1094391/169/50)) lseek err Invalid argument
file_pread(4,14,buffer,401532929(1094391/169/52)) lseek err Invalid argument
file_pread(4,3,buffer,401532943(1094391/170/3)) lseek err Invalid argument
file_pread(4,3,buffer,401532990(1094391/170/50)) lseek err Invalid argument
file_pread(4,8,buffer,401533006(1094391/171/3)) lseek err Invalid argument
file_pread(4,11,buffer,401533053(1094391/171/50)) lseek err Invalid argument
file_pread(4,2,buffer,401534975(1094391/202/19)) lseek err Invalid argument
* VMFS 0 32 33 1094363 158 3 17580949504
1 * VMFS 0 32 33 1094363 158 3 17580949504
NTFS at 401024/6/6
filesystem size 4294703104
mftmirr_lcn 2
HPFS - NTFS 133691 30 36 401024 6 6 4294703104
NTFS found using backup sector, blocksize=4096, 2198 GB / 2047 GiB
recover_EXT2: s_block_group_nr=0/111662, s_mnt_count=14/30, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 3658969088
recover_EXT2: part_size 3501948928
Linux 546582 50 29 2368664 135 47 29271752704
ext4 blocksize=4096 Large file Sparse superblock Recover, 14 TB / 13 TiB
This partition ends after the disk limits. (start=8780843008, size=29271752704, end=38052595711, disk end=17581402032)
Linux 546585 98 10 2368667 183 28 29271752704
This partition ends after the disk limits. (start=8780894208, size=29271752704, end=38052646911, disk end=17581402032)
Linux 546587 205 51 2368670 36 6 29271752704
This partition ends after the disk limits. (start=8780933120, size=29271752704, end=38052685823, disk end=17581402032)
The harddisk (9001 GB / 8383 GiB) seems too small! (< 19 TB / 17 TiB)
I's possible to fix this disk?
Re: After Raid error GPT tables missing
Run TestDisk, select your disk and force EFI GPT table partition instead of PC Intel.
pogow
#3 Post by pogow »
What I do:
First I analise dysk (select intel partition), Quick search not working so I do deep search after 10 hours test disk say about small disk, next I again do deep search (now is in progress it should be done in one hour).
testdisk scan
testdisk scan
deep search done:
deep search finish
deep search finish
Again qucik search:
Done
Done
pogow
#4 Post by pogow »
I can't post more images so reply the post.
gpt info.jpg (45.47 KiB) Viewed 3883 times
I'm start what You say but I'm not quit from testdisk just back to disk select (Q button), next select EFI GPT, analyse and quick search, but it working very slowly, about 2 unit/second, in my case it's take 151 hours (1094391/2/3600sec), do I somenthing wrong or this is ok?
gpt
gpt
It's possible to do something else like extend the cylinder?
