trying to restore partition (HFS)
leigel
#1 Post by leigel »
accidently selected the wrong drive when creating a usb boot disk. cancelled immediately but the drive still shows as empty now. ran testdisk for hours and this is all i got :\. i hope i can fix this; it wasn't even my drive i cleared!
any help will be So very appreciated!
(i am rather sure the drive was originally formatted long ago on an old PPC mac so i selected Apple Partition Map..)
Re: trying to restore partition (HFS)
Mac partition table are very uncommon... Try EFI GPT.
No log file or screenshot is visible.
leigel
#3 Post by leigel »
Thank you for the reply, Grenier!
TestDrive detects INTEL partition table, but I think that is what Startup Disk Creator formats to. FAT32 partition is found; don't see any files.
IF I select EFI GPT for table type, MS Data partition is found; no files.
If I select Mac for table type, HFS partition is found; no files.
Last night I ran a deep scan on this setting and ~8 more HFS partitions showed up by the time it finished. Still no files. I wish I could find that log! :(
The drive was definitely HFS, and I believe it was originally formatted by an old eMac (circa~2003), which is why I was guessing Apple Partition Table. I could be mistaking, but I believe that is what those old guys used..
I don't know where to go from here. I am running another deep scan right now. :| Here is the log so far... Hope this helps??
Thanks again
leigel-screens.zip
(198.11 KiB) Downloaded 568 times
leigel
#4 Post by leigel »
Finished the deep scan. This is what I got...
Anyone have any ideas?
leigel-screens-2.zip
(56.28 KiB) Downloaded 621 times
leigel
#5 Post by leigel »
Still at this! :\
But I certainly can't blame you for giving up on me.
Should I perhaps try PhotoRec for this operation ?
Thanks...
