I have mounted the HDD as an external drive and am able to see it. The drive has 5 partitions - the first and last of them work OK (even though I can't start Windows which is on the first one), but the other 3 are missing and showing as Free Space.
I've tried running TestDisk but it wasn't able to fix it:
Invalid NTFS or EXFAT boot
1 * HPFS - NTFS 0 1 1 5221 254 63 83891367
2 E extended LBA 5222 0 1 32357 254 63 435939840
3 P HPFS - NTFS 32358 0 1 60800 254 63 456936795
test_logical:
Partition sector doesn't have the endmark 0xAA55Should I try to first decrypt the whole disk and then use TestDisk? Is there a way to decrypt the disk from within Windows as opposed to going the DOS way?
