Drobo 2nd gen partition bad filesystem
DavidPhoto
#1 Post by DavidPhoto »
I have a 2nd Gen Drobo with 4 2Tb partitions on it. The second one went RAW last week and I was able to repair with chkdsk, but then several days later it went RAW again and chkdsk wouldn't do anything with it.
I did a deeper scan, and at the end TestDisk seems to be confused because the MBR says the disk is bigger than it should be (which I imagine is possible with Drobos).
The harddisk (2199 GB / 2047 GiB) seems too small! (< 4398 GB / 4095 GiB)
HPFS - NTFS 267348 254 63 534697 253 62 4294961622
NTFS, blocksize=4096, 2199 GB / 2047 GiB
I'm wary to write another MBR because I'm not sure if Drobo does something strange with its Raid system.
Any ideas would be greatly appreciated.
Thanks,
David
Tue Dec 09 15:28:40 2014
Compiler: GCC 4.8, MinGW 3.11
Compilation date: Nov 13 2014 18:59:59
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2199023185920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=2199023185920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=2199023185920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=2199023185920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive8)=64016220160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=503316480000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=250048512000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=367266977280
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=100027597824
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=532907665920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=250056705024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=496885563392
filewin32_getfilesize(\\.\J:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\J:) SetFilePointer err Incorrect function.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=64016203776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\R:)=2199020350464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\W:)=2199020350464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=2198888933888
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Y:)=2198888933888
Disk \\.\PhysicalDrive0 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 2199 GB / 2047 GiB - CHS 267349 255 63, sector size=512
Disk \\.\PhysicalDrive4 - 2199 GB / 2047 GiB - CHS 267349 255 63, sector size=512
Disk \\.\PhysicalDrive5 - 2199 GB / 2047 GiB - CHS 267349 255 63, sector size=512
Disk \\.\PhysicalDrive6 - 2199 GB / 2047 GiB - CHS 267349 255 63, sector size=512
Disk \\.\PhysicalDrive8 - 64 GB / 59 GiB - CHS 7782 255 63, sector size=512
Drive C: - 503 GB / 468 GiB - CHS 61191 255 63, sector size=512
Drive D: - 250 GB / 232 GiB - CHS 30400 255 63, sector size=512
Drive E: - 367 GB / 342 GiB - CHS 44651 255 63, sector size=512
Drive F: - 100 GB / 93 GiB - CHS 12160 255 63, sector size=512
Drive G: - 532 GB / 496 GiB - CHS 64789 255 63, sector size=512
Drive H: - 250 GB / 232 GiB - CHS 30400 255 63, sector size=512
Drive I: - 496 GB / 462 GiB - CHS 60409 255 63, sector size=512
Drive L: - 64 GB / 59 GiB - CHS 7782 255 63, sector size=512
Drive R: - 2199 GB / 2047 GiB - CHS 267348 255 63, sector size=512
Drive X: - 2198 GB / 2047 GiB - CHS 267333 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive4 - 2199 GB / 2047 GiB - CHS 267349 255 63
Invalid NTFS or EXFAT boot
1 P HPFS - NTFS 0 1 1 267348 254 63 4294961622
$MFT has invalid magic.
ntfs_mft_load(): Failed.
NTFS at 267348/254/63
filesystem size 4294961622
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 2199 GB / 2047 GiB
mftmirr_lcn 2
This partition ends after the disk limits. (start=4294961684, size=4294961622, end=8589923305, disk end=4294967160)
BAD_RS LBA=63 63
HPFS - NTFS 267349 90 5 534698 89 4 4294961622
This partition ends after the disk limits. (start=4294967359, size=4294961622, end=8589928980, disk end=4294967160)
* HPFS - NTFS 0 1 1 267348 254 63 4294961622
Not an exFAT boot sector.
interface_load
1 * HPFS - NTFS 0 1 1 267348 254 63 4294961622
mftmirr_lcn 2
mftmirr_lcn 2
