j'ai branché un disque dur externe usb sur un portable XP, tout se passait bien, il y avait des donnees dessus et d'un coup, le disque n'est plus visible. Dans le gestionnaire de stockage du panneau de configuration, il voit bien la partition mais indique "Sain (Partition de protection GPT)"
j'ai fait un deepsearch sur testdisk (windows) ça donne ça:
Disk /dev/sdc - 1000 GB / 931 GiB - Seagate BUP Slim Mac SL
Partition table type: EFI GPT
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953525166 (expected 1953525166)
hdr_lba_start=34
hdr_lba_end=1953525133
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P EFI System 40 409639 409600 [EFI System Partition]
2 P Mac HFS 409640 1953262983 1952853344 [Seagate Backup Plus Drive]
FAT32 at 0/0/41
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
heads/cylinder 16 (FAT) != 255 (HD)
FAT32 at 0/0/41
EFI System 40 409639 409600 [EFI]
HFS+ magic value at 25/127/15
part_size 1952853344
HFS+ blocksize=4096, 999 GB / 931 GiB
file_pread(6,1,buffer,1953525168(121601/81/1)) lseek err Invalid argument
file_pread(6,1,buffer,1953525169(121601/81/2)) lseek err Invalid argument
file_pread(6,1,buffer,1953525170(121601/81/3)) lseek err Invalid argument
file_pread(6,1,buffer,1953525171(121601/81/4)) lseek err Invalid argument
file_pread(6,1,buffer,1953525172(121601/81/5)) lseek err Invalid argument
il y a un nombre incalculable de ce genre de lignes
sinon J'ai aussi lancé GPT fdisk et il me detecte 3 problemes :
Problem: The secondary header's self-pointer indicates that it doesn't reside
at the end of the disk. If you've added a disk to a RAID array, use the 'e'
option on the experts' menu to adjust the secondary header's and partition
table's locations.
Problem: main GPT header's current LBA pointer (1) doesn't
match the backup GPT header's alternate LBA pointer(1953525166).
Problem: main GPT header's backup LBA pointer (1953525166) doesn't
match the backup GPT header's current LBA pointer (1).
The 'e' option on the experts' menu may fix this problem.
Identified 3 problems!
Que dois je faire sous GPT fdisk pour récupérer mes données super importantes?
cordialement
William
recuperation donnees sur Partition de protection GPT
Re: recuperation donnees sur Partition de protection GPT
Actuellement
- la table des partitions est au format EFI, non supporté par XP (sauf XP 64 bits)
- une partition HFS+, utilisable sous Mac OS X, est listée, non gérée sous Windows.
Si vous êtes certain que ce disque était utilisable sous Windows et n'a pas été utilisé sur un Mac, choisissez Pc/Intel plutôt que EFI GPT.
