Partition can't be recovered
sgiraldoa
#1 Post by sgiraldoa »
Hi, I'm trying to recover a partition, I've deleted the partition but I didn't formatted, so the data is still there. Testdisk found it but it says it can't be recovered perhaps it founds the right name of the partition [Secundario].
Runnning photorec didn't found this partition [Secundario], what can I do?
This is the log from Testdisk:
_____________________________________________________
OS: Windows 7 (7600)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119926685696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=102655590400
Disk /dev/sda - 120 GB / 111 GiB - CHS 15505 240 63, sector size=512 - SPCC Sol id State Dis, S/N:FEB4074416B200179352, FW:S8FM
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 129201 240 63, sector size=512 - SAMSUNG HD103SJ, S/N:S246J90B809193, FW:1AJ1
Disk /dev/sdb - 1000 GB / 931 GiB - SAMSUNG HD103SJ
Analyse Disk /dev/sdb - 1000 GB / 931 GiB - CHS 129201 240 63
Geometry from i386 MBR: head=240 sector=63
NTFS at 13/163/20
NTFS at 0/32/33
1 E extended 0 32 32 13 239 63 209633
2 P HPFS - NTFS 13 163 20 13274 50 18 200499200
5 L HPFS - NTFS 0 32 33 13 163 19 204800 [Reservado para el sistema]
NTFS at 0/32/33
filesystem size 204800
mft_lcn 8533
mftmirr_lcn 2
NTFS at 13/163/20
filesystem size 200499200
mftmirr_lcn 2
NTFS, blocksize=4096, 102 GB / 95 GiB
NTFS at 13274/50/19
filesystem size 1953515071
mft_lcn 26898432
mftmirr_lcn 26112002
HPFS - NTFS 13274 50 19 142474 226 1 1953515071 [Secundario]
This partition ends after the disk limits. (start=200706048, size=1953515071, end=2154221118, disk end=1953525168)
file_pread(5,1,buffer,1953525759(129201/105/25)) lseek err Invalid argument
file_pread(5,1,buffer,1953525760(129201/105/26)) lseek err Invalid argument
file_pread(5,14,buffer,1953525761(129201/105/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(129201/105/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(129201/106/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(129201/106/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(129201/107/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(129201/137/57)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 1102 GB / 1027 GiB)
Warning: the current number of heads per cylinder is 240 but the correct value may be 255.
* HPFS - NTFS 0 32 33 13 163 19 204800 [Reservado para el sistema]
1 * HPFS - NTFS 0 32 33 13 163 19 204800 [Reservado para el sistema]
______________________________________________________________
The partition I want to recover is:
Thanks for your help!
Re: Partition can't be recovered
Let's try something. Run TestDisk, select the disk, PC/Intel, Geometry, set 142475 cylinders, Analyse, Quick Search, try to list the files from your "Secundario" partition. If it works, set the following partition as *(bootable)
the other two should be P(rimary).
choose Write, confirm, Quit and restart
If you can access the files from "Secundario", backup them, delete this partition, recreate it and restore your files.
