*SOLVED* Error during TrueCrypt encryption Topic is solved
trove
#1 Post by trove »
Hi!
Today I decided to run full encryption of my non-system drive and in about 13% of encryption an error popped up that there's no volume (or something) and actually there was no partition to be seen in My Computer nor TrueCrypt. I've run TestCrypt and now I'm following THIS instruction.
Right now I'm here
Am I doing everything right? If not, how can I recover lost partition?
Cheers!
EDIT: I've found out that there're files and folders listed in TestDisk, so I simply created small (about 350GB) partition at the end of HDD and copied all the files through TestDisk.
