CHS and LBA dont match, messed up partition
Moratora
#1 Post by Moratora »
I'm pretty new to this, so please bear with me. I am trying to recover data from a hard drive that stopped responding a while ago. Its a Seagate Barracuda 2TB (Model: ST2000DM001)
It was mounted in my desktop, went bad (dont remember why, I think I did something to it while using it to fix another drive about 6 months ago). I removed it from the desktop and used a SATA/USB bridge to connect it to my laptop
I accessed it through TestDisk and get the screens below and I'm not sure what to do next. Any help would be tremendously appreciated!!!
Fri Jan  2 20:40:37 2015
TestDisk 7.0-WIP, Data Recovery Utility, June 2014
Compilation date: 2014-07-24T23:30:25
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=3000558944256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000558944256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=500105740288
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=3000557895680
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000BEVT-22A0RT0, S/N:2020202057202d44585731383841443135373934, FW:01.01A01
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 45599 255 63, sector size=4096 - WD My Book 1230, S/N:WCC4N1330500, FW:1050
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 30400 255 63, sector size=4096 - ST2000DM 001-1CH164, S/N:152D20337A0C
Disk \\.\PhysicalDrive2 - 3000 GB / 2794 GiB - CHS 45599 255 63, sector size=4096 - WD My Book 1230, S/N:WCC4N1330500, FW:1050
Disk \\.\PhysicalDrive3 - 2000 GB / 1863 GiB - CHS 30400 255 63, sector size=4096 - ST2000DM 001-1CH164, S/N:152D20337A0C
Drive I: - 3000 GB / 2794 GiB - CHS 45599 255 63, sector size=4096 - WD My Book 1230, S/N:WCC4N1330500, FW:1050
Disk /dev/sdd - 2000 GB / 1863 GiB - ST2000DM 001-1CH164
Analyse Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 30400 255 63
 1 P EFI GPT                  0   0  2 267349  89  4 4294967295
check_FAT: number of bytes per sector mismatches 512 (FAT) != 4096 (HD)
NTFS at 10/180/43
filesystem size           1024000
sectors_per_cluster       8
mft_lcn                   42666
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS             10 180 43    18 172 26     128000
     NTFS, blocksize=4096, 524 MB / 500 MiB
NTFS at 18/172/27
filesystem size           3881781248
mftmirr_lcn               2
     HPFS - NTFS             18 172 27 30222  99 21  485222656
     NTFS, blocksize=4096, 1987 GB / 1850 GiB
NTFS at 30222/99/22
filesystem size           22845616
mftmirr_lcn               2
     HPFS - NTFS          30222  99 22 30400  37 59    2855702
     NTFS, blocksize=4096, 11 GB / 10 GiB
file_pread(6,1,buffer,488378646(30400/42/1)) ReadFile Data error (cyclic redundancy check).
file_pread(6,1,buffer,488378650(30400/42/5)) lseek err Invalid argument
file_pread(6,1,buffer,488378709(30400/43/1)) lseek err Invalid argument
file_pread(6,1,buffer,488378713(30400/43/5)) lseek err Invalid argument
file_pread(6,1,buffer,488378880(30400/45/46)) lseek err Invalid argument
file_pread(6,1,buffer,488378656(30400/42/11)) lseek err Invalid argument
file_pread(6,1,buffer,488378672(30400/42/27)) lseek err Invalid argument
file_pread(6,1,buffer,488378688(30400/42/43)) lseek err Invalid argument
file_pread(6,1,buffer,488378704(30400/42/59)) lseek err Invalid argument
file_pread(6,1,buffer,488378720(30400/43/12)) lseek err Invalid argument
file_pread(6,1,buffer,488378736(30400/43/28)) lseek err Invalid argument
file_pread(6,1,buffer,488378752(30400/43/44)) lseek err Invalid argument
file_pread(6,1,buffer,488378768(30400/43/60)) lseek err Invalid argument
file_pread(6,1,buffer,488378784(30400/44/13)) lseek err Invalid argument
file_pread(6,1,buffer,488378800(30400/44/29)) lseek err Invalid argument
file_pread(6,1,buffer,488378816(30400/44/45)) lseek err Invalid argument
file_pread(6,1,buffer,488378832(30400/44/61)) lseek err Invalid argument
file_pread(6,1,buffer,488378848(30400/45/14)) lseek err Invalid argument
file_pread(6,1,buffer,488378864(30400/45/30)) lseek err Invalid argument
file_pread(6,1,buffer,488378879(30400/45/45)) lseek err Invalid argument
file_pread(6,2,buffer,488378880(30400/45/46)) lseek err Invalid argument
file_pread(6,2,buffer,488378881(30400/45/47)) lseek err Invalid argument
file_pread(6,2,buffer,488378887(30400/45/53)) lseek err Invalid argument
file_pread(6,2,buffer,488378889(30400/45/55)) lseek err Invalid argument
file_pread(6,2,buffer,488378895(30400/45/61)) lseek err Invalid argument
file_pread(6,2,buffer,488379135(30400/49/49)) lseek err Invalid argument
   * HPFS - NTFS             10 180 43    18 172 26     128000
   P HPFS - NTFS             18 172 27 30222  99 21  485222656
   P HPFS - NTFS          30222  99 22 30400  41 41    2855936
 1 * HPFS - NTFS             10 180 43    18 172 26     128000
 2 P HPFS - NTFS             18 172 27 30222  99 21  485222656
 3 P HPFS - NTFS          30222  99 22 30400  41 41    2855936
Moratora
Re: CHS and LBA dont match, messed up partition
#2 Post by Moratora »
Can anyone please help me? :(
I'd be tremendously thankful!!!
golimar
#3 Post by golimar »
Are you sure it's a EFI / GPT partition table?
europanorama
#4 Post by europanorama »
press "P"-files on every of the three lines. if files are displayed they can be backed up/restored. use c to copy folders and go the the backup-directory with left arrow. after copy you will be back in the data-section. display backup-folder on the right or left side of testdisk-window to overview backup-process.
if some data cannot be restored try to backup with knoppix-live-dvd.
