MFT problem. No MFTmirror is there.
b0r3d
#1 Post by b0r3d »
HP 500 GB of external HDD. I checked using "chkdsk" but after 24 hrs it stopped in the second phase of index verification
and highlighted the error of MFT is corrupted and it aborted.
Then using TestDisk_win
Advanced Options-> Boot-> Repair MFT
"It says can't read NTFS MFT"
Current Boot Status of HDD:-
Boot Sector Status:OK
Backup Boot Sector Status: Ok
Sectors are identical
Plzz direct me. :geek:
Re: MFT problem. No MFTmirror is there.
You can try TestDisk, Advanced, Boot, RepairMFT.
If it doesn't work, use PhotoRec to recover your data (original filenames won't be recovered)
Mark2m
#3 Post by Mark2m »
So are you saying at this juncture to forget about the mirror image of the MFT and go another route.
MFT Mirror.JPG (36.17 KiB) Viewed 2663 times
