MFT corrupted on 2TB
Mark2m
#1 Post by Mark2m »
Originally chkdsk will not work for E: drive one of 3 which has mainly music and photo's. After running Test Disk I have the following, Where do I go from here?
As you can see analyze cylinder and have read error,
What do I do next? Realistically, can I replace the MFT or do I try to copy the files to another disk and consider this 2TB drive as toast?
MFM 2TB 2nd.JPG (51.72 KiB) Viewed 4466 times
Re: MFT corrupted on 2TB
Run TestDisk, Advanced, select the partition corresponding to E:, Boot, RebuildBS, List. If you can see your files, choose Write and confirm. If it's not the case, please copy the content of testdisk.log
Mark2m
#3 Post by Mark2m »
Please note, from another complaint same as mine I added the following: with the question that if both are corrupted than is there some hope elsewhere?
MFT Mirror.JPG (36.17 KiB) Viewed 4464 times
