A Challenge, sector mismatches
dbxwanderer
#1 Post by dbxwanderer »
Long story short, I had an internal 3tb drive in my computer. When I moved it to an external adapter, it fubar'd the partition. I deleted the partition, but did not format or create a new one.
I ran TestDisk and it gets stuck at 99% with "Analyse Cylinder 364801/364800: 99%
Below is the export of the log.
I think the only thing that can be done now is to modify the geometry, but i'm really hestitent in doing so. Any experts out there that can help me?
Thanks in advance,
Thu Jan 15 10:09:29 2015
TestDisk 7.0-WIP, Data Recovery Utility, December 2014
Compiler: GCC 4.9, MinGW 3.11
Compilation date: Jan 10 2015 19:41:08
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=115033153536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=4000787030016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive8)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive9)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=115030884352
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4000650887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=4000650887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=4000650887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=4000650887168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=640132579328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=2000396746752
filewin32_getfilesize(\\.\L:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\L:) SetFilePointer err Incorrect function.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=3000457232384
Disk \\.\PhysicalDrive0 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 115 GB / 107 GiB - CHS 13985 255 63, sector size=512
Disk \\.\PhysicalDrive4 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512
Disk \\.\PhysicalDrive5 - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Disk \\.\PhysicalDrive6 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512
Disk \\.\PhysicalDrive7 - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk \\.\PhysicalDrive8 - 640 GB / 596 GiB - CHS 610480 64 32, sector size=512
Disk \\.\PhysicalDrive9 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Drive C: - 115 GB / 107 GiB - CHS 13985 255 63, sector size=512
Drive D: - 4000 GB / 3725 GiB - CHS 486384 255 63, sector size=512
Drive H: - 640 GB / 596 GiB - CHS 610478 64 32, sector size=512
Drive J: - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Drive M: - 3000 GB / 2794 GiB - CHS 364784 255 63, sector size=512
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 5860533167)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
New options :
Dump : No
Align partition: Yes
Expert mode : No
New options :
Dump : No
Expert mode : Yes
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
New options :
Dump : No
Expert mode : Yes
Analyse Disk \\.\PhysicalDrive2 - 3000 GB / 2794 GiB - CHS 364801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
golimar
Re: A Challenge, sector mismatches
#2 Post by golimar »
Is that Windows? Try with a Linux version with some Live CD
dbxwanderer
#3 Post by dbxwanderer »
It is Windows.
What do you mean linux version. windows cant operate linux programs...?
golimar
#4 Post by golimar »
It's just a different thing you could try, being a different operating system it may access the disk in a different way.
