I had an NTFS partition on my HD with data.
I then deleted the partition and created an ext4 partition and filesystem in its place.
I haven't written any data to the HD.
Is it possible for me to recover my old NTFS partition and data? What is the likelyhood of recovery?
Removed & created partition and filesystem - can I recover?
Re: Removed & created partition and filesystem - can I recov
Run TestDisk, Analyze, Search, Quick Search, the NTFS partition should be listed, set all the partition to keep as P'rimary), *(bootable) or L(ogical).
The NTFS partition wasn't listed... doing a deep search now.
Not sure what to do now... here are the steps I've taken:
1. The analyse step gave me this:
1 P Linux 0 1 1 121601 80 63 1953525105 [Backup 1.1 (fai
2. When I do a Quick Search, I get this warning:
Disk /dev/sde - 1000 GB / 931 GiB - CHS 121601 255 63
Warning: the current number of heads per cylinder is 255
but the correct value may be 16.
You can use the Geometry menu to change this value.
It's something to try if
- some partitions are not found by TestDisk
- or the partition table can not be written because partitions overlaps.
And the following result:
>* Linux 0 1 1 121601 254 63 1953536067 [Backup 1.1 (fail]
3. I then choose a Deeper Search and get this warning:
I hit continue and get this:
HPFS - NTFS 0 32 33 121601 25 24 1953519616 [Backup 1.1]
Enter: to continue
ext4 blocksize=4096 Large file Sparse superblock Recover, 1000 GB / 931 GiB
4. What do I do now to recover my NTFS partition and data?
Enter: to continue
