Tried to restore partition using testdisk but I think I have written the wrong partition as after doing so, my 1.5TB (which is around 98% full) became 250GB (the rest are unallocated according to Windows Disk Manager). So I "expanded" the allocation thinking that it will magically bring my files back, but didn't. Please note that the files seem to be there as well but most of them (around 90%) are 0 bytes in sizes. And every time I try to navigate to each folder I get this message as well: "The Recycle Bin on W:\ is corrupted. Do you want to empty the Recycle Bin for this drive?" Of course I always click No as I do not want to make matters worse. I have tried running testdisk again (deep search) and the following is the log:
Mon Jan 19 20:36:39 2015
TestDisk 7.0-WIP, Data Recovery Utility, May 2014
Compilation date: 2014-05-20T10:35:40
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=240057409536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000398933504
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=239502098432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1000202240512
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000397884928
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=1000202273280
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\W:)=1500298346496
Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA MQ01ABD100, S/N:X3DPP40YT, FW:AX001C
Disk /dev/sdb - 240 GB / 223 GiB - CHS 29185 255 63, sector size=512 - Crucial_CT240M500SSD3, S/N:1347095AE1A1, FW:MU03
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Seagate BUP Slim RD, S/N:NA78XQAK, FW:0143
Disk /dev/sdd - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - ST315003 41AS, S/N:9344EFFFFFFF
Disk /dev/sde - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Seagate Desktop, S/N:2GHKBBPP, FW:0130
Disk /dev/sdd - 1500 GB / 1397 GiB - ST315003 41AS
NTFS at 0/32/33
1 * HPFS - NTFS 0 32 33 182401 3 2 2930270208
NTFS, blocksize=4096, 1500 GB / 1397 GiB
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
filesystem size 2930270208
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
Failed to open inode: Input/output error.
repair_MFT
NTFS at 0/32/33
ntfs_readdir failed for cluster 5
NTFS listing using MFT:
5 dr-xr-xr-x 0 0 0 17-Jan-2015 02:45 .
5 dr-xr-xr-x 0 0 0 17-Jan-2015 02:45 ..
14984 dr-xr-xr-x 0 0 0 30-Nov-2010 22:39 H_Blog
ntfs_dir: ntfs_inode_open failed
Don't fix MFT mirror.
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
Analyse Disk /dev/sdd - 1500 GB / 1397 GiB - CHS 182401 255 63
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
file_pread(7,2,buffer,2930278400(182401/100/36)) lseek err Invalid argument
file_pread(7,1,buffer,2930278400(182401/100/36)) lseek err Invalid argument
file_pread(7,8,buffer,2930277248(182401/82/18)) lseek err Invalid argument
file_pread(7,1,buffer,2930277248(182401/82/18)) lseek err Invalid argument
file_pread(7,8,buffer,2930277376(182401/84/20)) lseek err Invalid argument
file_pread(7,8,buffer,2930277504(182401/86/22)) lseek err Invalid argument
file_pread(7,8,buffer,2930277632(182401/88/24)) lseek err Invalid argument
file_pread(7,8,buffer,2930277760(182401/90/26)) lseek err Invalid argument
file_pread(7,8,buffer,2930277888(182401/92/28)) lseek err Invalid argument
file_pread(7,8,buffer,2930278016(182401/94/30)) lseek err Invalid argument
file_pread(7,8,buffer,2930278144(182401/96/32)) lseek err Invalid argument
file_pread(7,8,buffer,2930278272(182401/98/34)) lseek err Invalid argument
file_pread(7,1,buffer,2930278399(182401/100/35)) lseek err Invalid argument
file_pread(7,14,buffer,2930278401(182401/100/37)) lseek err Invalid argument
file_pread(7,3,buffer,2930278415(182401/100/51)) lseek err Invalid argument
file_pread(7,3,buffer,2930278462(182401/101/35)) lseek err Invalid argument
file_pread(7,8,buffer,2930278478(182401/101/51)) lseek err Invalid argument
file_pread(7,11,buffer,2930278525(182401/102/35)) lseek err Invalid argument
file_pread(7,2,buffer,2930280447(182401/133/4)) lseek err Invalid argument
Any comments or guidance on what to do next will be much appreciated. Thanks in advance.
Elmer
Is there any hope in getting back my data?
Re: Is there any hope in getting back my data?
The partition table is ok but the MFT is corrupted.
Run "cmd" (right click run as administrator) and "chkdsk /f d:" (replace d: by the correct drive letter)
Hi, thanks for the reply. After running chkdsk /f as suggested, the result is still the same: meaning most of my files are still 0 byte in size. I ran another "deeper search" and the following is the log:cgrenier wrote:The partition table is ok but the MFT is corrupted.
Wed Jan 21 21:01:52 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=8004304896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=8004304896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=8002732032
Disk /dev/sdf - 8004 MB / 7633 MiB - CHS 973 255 63, sector size=512 - SanDisk Cruzer Glide, S/N:4C532000020926104521, FW:1.26
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
- "Unrecoverable" partition 1
- AfterDeeperSearch1.PNG (15.6 KiB) Viewed 4126 times
- "Unrecoverable" partition 2
- AfterDeeperSearch2.PNG (13.76 KiB) Viewed 4126 times
- "Unrecoverable" partition 3
- AfterDeeperSearch3.PNG (13.85 KiB) Viewed 4126 times
Ok then, I guess there's no more hope in recovering my data...thanks anyway for the help.
europanorama
If you can see your files wiht testdisk you would rather save them with knoppix live-dvd. its much easier and quicker. try it out. nothing can be destroyed.
http://forum.cgsecurity.org/phpBB3/back ... t4690.html
if not successful try to restore with phototec.
