My wife's MacBook Pro has a 500GB SSD boot/system disk and 1TB Samsung data disk. As far as I know, the 1TB disk was formatted as a single Mac OS Extended (Journaled) partition using Disk Utility. But something has gone wrong and she now gets an error message on startup that requires her to eject the 1TB disk. Disk Utility will not let me do anything with this disk. I get errors when I try to partition or erase it. (Losing the data is not a huge concern, as her documents are on Google Drive and her music files are available on iTunes Cloud.)
When I ran Analyze and Quick Search on this drive, I got GPT signature missing errors, and then it found 4 partitions. (The drive was at one time the only drive in the MacBook, so it may still have hidden partitions I didn't know about.) Unfortunately, I didn't save the log file from this Quick Search. I started a Deeper Scan about 36 hours ago, and it has only finished about 14% of the drive (270 million of 1.95 billion sectors). At this rate, it will take another week to finish.
So questions for now:
1. This drive uses Advanced Format Technology with, I think, a sector size of 4096. TestDisk reported a sector size of 512, but it reported the correct disk size. Should I use Geometry to set the sector size to 4096, or is this just a difference between physical and logical sector size that TestDisk is recognizing and using correctly?
2. Because of the sector size, or for any other reason, should I stop this deeper scan now and change anything before restarting it? Or perhaps stop and just do a Quick Scan and post the log file now? Or should I let it run for a week and post the log file then?
3. Can my wife use the computer for other tasks while TestDisk is running? If so, any limitations on types of programs or activities?
Thanks in advance. I just don't want to wait another week just to find out I should have done something differently.
Duane
Bad GPT on 1TB MacBook drive
Re: Bad GPT on 1TB MacBook drive
Okay, the Deeper Search finished after a little over a week, but the log file, at 834KB, is too big to post here. So here is the Quick Search log file:
Any suggestions on how I can proceed to recover this disk?
Duane
Tue Jan 27 21:39:58 2015
TestDisk 7.0-WIP, Data Recovery Utility, December 2014
OS: Darwin, kernel 14.0.0 (Darwin Kernel Version 14.0.0: Fri Sep 19 00:26:44 PDT 2014; root:xnu-2782.1
Compiler: GCC 4.0
Compilation date: 2015-01-10T19:40:38
Disk /dev/disk0 - 512 GB / 476 GiB - 1000215216 sectors (RO), sector size=512
Disk /dev/disk1 - 1000 GB / 931 GiB - 1953525168 sectors, sector size=512
Disk /dev/disk2 - 4294 MB / 4096 MiB - 8388608 sectors (RO), sector size=512
Disk /dev/disk3 - 16 MB / 15 MiB - 31312 sectors (RO), sector size=512
Disk /dev/disk4 - 16 MB / 15 MiB - 31296 sectors (RO), sector size=512
Disk /dev/rdisk0 - 512 GB / 476 GiB - 1000215216 sectors (RO), sector size=512
Disk /dev/rdisk1 - 1000 GB / 931 GiB - 1953525168 sectors, sector size=512
Disk /dev/rdisk2 - 4294 MB / 4096 MiB - 8388608 sectors (RO), sector size=512
Disk /dev/rdisk3 - 16 MB / 15 MiB - 31312 sectors (RO), sector size=512
Disk /dev/rdisk4 - 16 MB / 15 MiB - 31296 sectors (RO), sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/rdisk1 - 1000 GB / 931 GiB - 1953525168 sectors
Trying alternate GPT
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT differs, FAT sectors=864-880/3151
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
EFI System 40 409639 409600 [EFI]
part_size 1475053312
Mac HFS 409640 1475462951 1475053312
HFS+ blocksize=4096 + Backup, 755 GB / 703 GiB
HFS+ magic value at 1475725096/0/1
part_size 476530496
Mac HFS 1475725096 1952255591 476530496
HFS+ blocksize=4096 + Backup, 243 GB / 227 GiB
HFS+ magic value at 1952255592/0/1
part_size 1269536
Mac HFS 1952255592 1953525127 1269536
HFS+ blocksize=4096 + Backup, 650 MB / 619 MiB
P EFI System 40 409639 409600 [EFI]
P Mac HFS 409640 1475462951 1475053312
P Mac HFS 1475725096 1952255591 476530496
P Mac HFS 1952255592 1953525127 1269536
dir_partition inode=0
FAT: cluster=2(0x2), pos=6374
3 drwxr-xr-x 0 0 0 1-Jan-2001 00:32 EFI
4102 drwxr-xr-x 0 0 0 23-Oct-2012 19:13 .Trashes
66370 -rwxr-xr-x 0 0 13654 1-Jan-2001 00:55 BOOTLOG
dir_partition inode=3
FAT: cluster=3(0x3), pos=6375
Directory /EFI
3 drwxr-xr-x 0 0 0 23-Oct-2012 19:13 .
0 drwxr-xr-x 0 0 0 23-Oct-2012 19:13 ..
4 drwxr-xr-x 0 0 0 1-Jan-2001 00:32 APPLE
1 P EFI System 40 409639 409600 [EFI]
2 P Mac HFS 409640 1475462951 1475053312
3 P Mac HFS 1475725096 1952255591 476530496
4 P Mac HFS 1952255592 1953525127 1269536
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
part_size 476530496
part_size 1269536
Support for this filesystem hasn't been enable during compilation.
Duane
