Accidentally formatted second (data drive)
After running the program test disk the results seem to indicate the correct partitions, normal for a Dell Laptop, the recovery partition and then it showed two NTFS partitions. I don't care about the recovery partition, I had previously wiped and formatted the drive once I successfully installed my SSD.
Re: Accidentally formatted second (data drive)
I have attached a log of my attempts thus far and looking for clarification.
Here are the specifics (ignore first post - I rambled) :
1.) Drive that was attempted full format: TOSHIBA MK6461GSY 640G
2.) Drive is used as secondary data drive
3.) Drive was original DELL laptop primary drive with Win7 OS and recovery partition
4.) I thought I had repartitioned and reformatted to use entire drive for secondary drive, this was completed and has been in use for a few years as secondary drive.
5.) When using Testdisk, it appears the original recovery partition shows up during the initial scan.
6.) There are no defects or faults with the drive but I did make an image to test with so as not to write to this drive.
The following is the log from my first attempts, nothing has been written or altered since I formatted the drive.
]Mon Jan 26 08:44:25 2015
TestDisk 7.0-WIP, Data Recovery Utility, January 2015
Compilation date: 2015-01-19T21:26:37
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=120031478784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=5341184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=106896384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=624290526720
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=15734960640
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - INTEL SSDSA2CW120G3, S/N:544252503331343932304a4232314c304e472020, FW:4PC10362
Disk /dev/sdb - 640 GB / 596 GiB - CHS 77825 255 63, sector size=512 - TOSHIBA MK6461GSY, S/N:2020202020202020202032205031544753355431, FW:MC000D
Drive D: - 5341 KB / 5216 KiB - CHS 1 64 32, sector size=2048 - Optiarc DVD+-RW AD-7717H, FW:101A
Disk /dev/sdb - 640 GB / 596 GiB - TOSHIBA MK6461GSY
Analyse Disk /dev/sdb - 640 GB / 596 GiB - CHS 77825 255 63
FAT16 at 0/1/1
Info: size boot_sector 208782, partition 208782
FAT1 : 1-204
FAT2 : 205-408
start_rootdir : 409
Data : 441-208780
sectors : 208782
cluster_size : 4
no_of_cluster : 52085 (2 - 52086)
fat_length 204 calculated 204
NTFS at 13/0/1
NTFS at 1926/0/1
1 * FAT16 >32M 0 1 1 12 254 63 208782 [DellUtility]
2 P HPFS - NTFS 13 0 1 1925 254 63 30732345
3 P HPFS - NTFS 1926 0 1 77824 254 63 1219317435
FAT16 at 0/1/1
FAT1 : 1-204
FAT2 : 205-408
start_rootdir : 409
Data : 441-208780
sectors : 208782
cluster_size : 4
FAT16 at 0/1/1
FAT16, blocksize=2048, 106 MB / 101 MiB
NTFS at 13/0/1
filesystem size 30732345
mftmirr_lcn 16
NTFS, blocksize=4096, 15 GB / 14 GiB
NTFS at 1926/0/1
filesystem size 1219317435
mftmirr_lcn 2
NTFS, blocksize=4096, 624 GB / 581 GiB
file_pread(5,2,buffer,1250265088(77825/102/38)) lseek err Invalid argument
file_pread(5,1,buffer,1250265088(77825/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,1250263814(77825/82/24)) lseek err Invalid argument
file_pread(5,1,buffer,1250263814(77825/82/24)) lseek err Invalid argument
file_pread(5,8,buffer,1250263942(77825/84/26)) lseek err Invalid argument
file_pread(5,8,buffer,1250264070(77825/86/28)) lseek err Invalid argument
file_pread(5,8,buffer,1250264198(77825/88/30)) lseek err Invalid argument
file_pread(5,8,buffer,1250264326(77825/90/32)) lseek err Invalid argument
file_pread(5,8,buffer,1250264454(77825/92/34)) lseek err Invalid argument
file_pread(5,8,buffer,1250264582(77825/94/36)) lseek err Invalid argument
file_pread(5,8,buffer,1250264710(77825/96/38)) lseek err Invalid argument
file_pread(5,8,buffer,1250264838(77825/98/40)) lseek err Invalid argument
file_pread(5,8,buffer,1250264966(77825/100/42)) lseek err Invalid argument
file_pread(5,1,buffer,1250265087(77825/102/37)) lseek err Invalid argument
file_pread(5,14,buffer,1250265089(77825/102/39)) lseek err Invalid argument
file_pread(5,3,buffer,1250265103(77825/102/53)) lseek err Invalid argument
file_pread(5,3,buffer,1250265150(77825/103/37)) lseek err Invalid argument
file_pread(5,8,buffer,1250265166(77825/103/53)) lseek err Invalid argument
file_pread(5,11,buffer,1250265213(77825/104/37)) lseek err Invalid argument
file_pread(5,2,buffer,1250267135(77825/135/6)) lseek err Invalid argument
interface_load
Disk /dev/sdb - 640 GB / 596 GiB - CHS 77825 255 63 Sun Jan 25 18:59:33 2015
I don't care about the recovery partition, just the data which I believe in the third line. Any attempts in listing files etc returns with the same error, nothing to list or see etc..
Hoping someone can provide next steps. Thanks in advance!
FAT16 at 0/1/1
FAT1 : 1-204
FAT2 : 205-408
start_rootdir : 409
Data : 441-208780
sectors : 208782
cluster_size : 4
NTFS at 13/0/1
NTFS at 1926/0/1
FAT16 at 0/1/1
FAT1 : 1-204
FAT2 : 205-408
start_rootdir : 409
Data : 441-208780
sectors : 208782
cluster_size : 4
FAT16 at 0/1/1
NTFS at 13/0/1
mftmirr_lcn 16
NTFS at 1926/0/1
mftmirr_lcn 2
interface_load
So no matter how I try to repair this HD, I can always restore my Dell Recovery partition but can never get my data partition to show up and list files.
I'm not sure what I am doing wrong, looking at my log above I always get 3 lines:
FAT Dell Recovery partition
NTFS partition 14GB
NTFS partition 580GB
I have tried everything,changed the 3rd partition to logical, primary etc, set the 2nd partition to Deleted etc., tried every possible variable, always can get the Dell Recovery partition to show up but never my data drive, what am I doing wrong? The data is there and I assume it's the 3rd partition that I need but do I need to recover the 1st Dell recovery as well. At this point I have found a backup of most of my data so this is to hopefully to learn what I'm doing wrong and hopefully restore the remaining data.
Is there a possibility that the two NTFS partitions are necessary to restore the drive?
Come on, does anyone get resolution? I've been checking all of the threads but none seem to get responses or resolution etc., I will donate if I can validate this will work I just cannot figure out what or where my issues are.
NTFS partition 14GB
