No partitions found on 64 GB card
califauna
#1 Post by califauna »
HI All,
When my Samsung s2 motherboard crashed recently it seems to have completely corrupted the 64 GB micro SD card inside.
Im trying to get access to the card as before if possible, with the folder structure intact, rather than go straight to recovery with Photorec, as the organisation of the folders not just as important as the files in them in this case.
The card size is read as 62 GB, but no partitions are found after quick and deep search.
It reports an invalid Fat boot sector, and that the CHS and LBA dont match.
Ive also tried 'Rebuild the boot section' a couple of times, but it results in 'cant find cluster size' and 'no partition found or selected' after deep search.
I had the internal SD card backed up but unfortunately not this external SD.
Is there anything else I can try?
I can upload the logs here,Im using 32 bit version on windows XP, with card in the memory card slot of my laptop.
Thanks very much for any help.
Re: No partitions found on 64 GB card
Please post the testdisk.log file content.
califauna
#3 Post by califauna »
OK . Here's the partition search first, and then the beginning of the boot sector rebuild and dump. I will post the entire log for that when its finished (Im running it for the second time and its currently about 30% complete and has been running for about 12 hours!)
------------------------------------- PARTITION SEARCH ----------------------------------------------------------------
Thu Jan 29 13:36:41 2015
TestDisk 7.0-WIP, Data Recovery Utility, January 2015
OS: Windows XP SP3
Compilation date: 2015-01-19T21:26:37
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=62881005568
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=62881005568
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=74907592704
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=35993825280
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=49129565184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=62879956992
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - TOSHIBA MK1655GSX, FW:FG010A
Disk /dev/sdb - 62 GB / 58 GiB - CHS 7644 255 63, sector size=512 - JMCR SD/MMC
Disk /dev/sdb - 62 GB / 58 GiB - JMCR SD/MMC
Analyse Disk /dev/sdb - 62 GB / 58 GiB - CHS 7644 255 63
BAD_RS LBA=2048 16450622
test_FAT()
1 * FAT32 LBA 0 32 33 7644 215 59 122812416
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
Invalid FAT boot sector
Warning: Bad starting head (CHS and LBA don't match)
file_pread(5,2,buffer,122814464(7644/215/60)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,122814464(7644/215/60)) ReadFile The drive cannot find the sector requested.
file_pread(5,14,buffer,122814465(7644/215/61)) lseek err Invalid argument
file_pread(5,1,buffer,122814465(7644/215/61)) lseek err Invalid argument
file_pread(5,8,buffer,122814471(7644/216/4)) lseek err Invalid argument
file_pread(5,3,buffer,122814479(7644/216/12)) lseek err Invalid argument
file_pread(5,3,buffer,122814526(7644/216/59)) lseek err Invalid argument
file_pread(5,8,buffer,122814542(7644/217/12)) lseek err Invalid argument
file_pread(5,11,buffer,122814589(7644/217/59)) lseek err Invalid argument
file_pread(5,2,buffer,122816511(7644/248/28)) lseek err Invalid argument
file_pread(5,14,buffer,122814466(7644/215/62)) lseek err Invalid argument
file_pread(5,1,buffer,122814482(7644/216/15)) lseek err Invalid argument
file_pread(5,1,buffer,122814529(7644/216/62)) lseek err Invalid argument
file_pread(5,1,buffer,122814550(7644/217/20)) lseek err Invalid argument
file_pread(5,1,buffer,122814600(7644/218/7)) lseek err Invalid argument
file_pread(5,1,buffer,122816513(7644/248/30)) lseek err Invalid argument
file_pread(5,16,buffer,68141119(4241/150/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,103098447(6417/148/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,113094719(7039/209/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,113108991(7040/180/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,113240190(7048/223/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,113354815(7056/2/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,113373200(7057/39/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,113404030(7059/18/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,113547546(7068/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,113786943(7082/231/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,113868800(7088/1/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114049087(7099/57/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114075648(7100/224/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114270487(7113/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114430015(7122/239/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114450431(7124/53/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114466832(7125/58/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114477135(7125/222/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114499710(7127/70/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114516031(7128/74/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114542591(7129/241/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114559578(7131/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114591870(7133/3/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114618494(7134/171/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114640895(7136/16/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,114656927(7137/16/15)) ReadFile Data error (cyclic redundancy check).
---------------------------------------- REBUILD BOOT SECTOR AND BS DUMP ----------------------------------------------------
Thu Jan 29 17:31:08 2015
OS: Windows XP SP3
test_FAT()
sector_size 0
cluster_size 0
reserved 0
fats 0
dir_entries 0
sectors 0
media 00
fat_length 0
secs_track 0
heads 0
hidden 0
total_sect 0
fat32_boot_sector
Bad
Bad
First sectors (Boot code and partition information) are not identical.
Boot sector Backup boot sector
0000 52526141 58464154 RRaAXFAT 00000000 00000000 ........
0008 20202000 00000000 ..... 00000000 00000000 ........
0010 00000000 00000000 ........ 00000000 00000000 ........
0018 00000000 00000000 ........ 00000000 00000000 ........
0020 00000000 00000000 ........ 00000000 00000000 ........
0028 00000000 00000000 ........ 00000000 00000000 ........
0030 00000000 00000000 ........ 00000000 00000000 ........
0038 00000000 00000000 ........ 00000000 00000000 ........
0040 00000000 00000000 ........ 00000000 00000000 ........
0048 00f85107 00000000 ..Q..... 00000000 00000000 ........
0050 00080000 00100000 ........ 00000000 00000000 ........
0058 00180000 e0510700 .....Q.. 00000000 00000000 ........
0060 04000000 976b531f .....kS. 00000000 00000000 ........
0068 00010000 09080180 ........ 00000000 00000000 ........
0070 5d000000 00000000 ]....... 00000000 00000000 ........
0078 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0080 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0088 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0090 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0098 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00A0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00A8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00B0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00B8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00C0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00C8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00D0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00D8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00E0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00E8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00F0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
00F8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0100 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0108 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0110 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0118 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0120 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0128 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0130 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0138 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0140 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0148 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0150 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0158 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0160 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0168 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0170 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0178 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0180 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0188 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0190 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
0198 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01A0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01A8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01B0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01B8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01C0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01C8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01D0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01D8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01E0 f4f4f4f4 72724161 ....rrAa 00000000 00000000 ........
01E8 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01F0 f4f4f4f4 f4f4f4f4 ........ 00000000 00000000 ........
01F8 f4f4f4f4 000055aa ......U. 00000000 000055aa ......U.
0200 00000000 00000000 ........ 00000000 00000000 ........
0208 00000000 00000000 ........ 00000000 00000000 ........
0210 00000000 00000000 ........ 00000000 00000000 ........
0218 00000000 00000000 ........ 00000000 00000000 ........
0220 00000000 00000000 ........ 00000000 00000000 ........
0228 00000000 00000000 ........ 00000000 00000000 ........
0230 00000000 00000000 ........ 00000000 00000000 ........
0238 00000000 00000000 ........ 00000000 00000000 ........
0240 00000000 00000000 ........ 00000000 00000000 ........
0248 00000000 00000000 ........ 00000000 00000000 ........
0250 00000000 00000000 ........ 00000000 00000000 ........
0258 00000000 00000000 ........ 00000000 00000000 ........
0260 00000000 00000000 ........ 00000000 00000000 ........
0268 00000000 00000000 ........ 00000000 00000000 ........
0270 00000000 00000000 ........ 00000000 00000000 ........
0278 00000000 00000000 ........ 00000000 00000000 ........
0280 00000000 00000000 ........ 00000000 00000000 ........
0288 00000000 00000000 ........ 00000000 00000000 ........
0290 00000000 00000000 ........ 00000000 00000000 ........
0298 00000000 00000000 ........ 00000000 00000000 ........
02A0 00000000 00000000 ........ 00000000 00000000 ........
02A8 00000000 00000000 ........ 00000000 00000000 ........
02B0 00000000 00000000 ........ 00000000 00000000 ........
02B8 00000000 00000000 ........ 00000000 00000000 ........
02C0 00000000 00000000 ........ 00000000 00000000 ........
02C8 00000000 00000000 ........ 00000000 00000000 ........
02D0 00000000 00000000 ........ 00000000 00000000 ........
02D8 00000000 00000000 ........ 00000000 00000000 ........
02E0 00000000 00000000 ........ 00000000 00000000 ........
02E8 00000000 00000000 ........ 00000000 00000000 ........
02F0 00000000 00000000 ........ 00000000 00000000 ........
02F8 00000000 00000000 ........ 00000000 00000000 ........
0300 00000000 00000000 ........ 00000000 00000000 ........
0308 00000000 00000000 ........ 00000000 00000000 ........
0310 00000000 00000000 ........ 00000000 00000000 ........
0318 00000000 00000000 ........ 00000000 00000000 ........
0320 00000000 00000000 ........ 00000000 00000000 ........
0328 00000000 00000000 ........ 00000000 00000000 ........
0330 00000000 00000000 ........ 00000000 00000000 ........
0338 00000000 00000000 ........ 00000000 00000000 ........
0340 00000000 00000000 ........ 00000000 00000000 ........
0348 00000000 00000000 ........ 00000000 00000000 ........
0350 00000000 00000000 ........ 00000000 00000000 ........
0358 00000000 00000000 ........ 00000000 00000000 ........
0360 00000000 00000000 ........ 00000000 00000000 ........
0368 00000000 00000000 ........ 00000000 00000000 ........
0370 00000000 00000000 ........ 00000000 00000000 ........
0378 00000000 00000000 ........ 00000000 00000000 ........
0380 00000000 00000000 ........ 00000000 00000000 ........
0388 00000000 00000000 ........ 00000000 00000000 ........
0390 00000000 00000000 ........ 00000000 00000000 ........
0398 00000000 00000000 ........ 00000000 00000000 ........
03A0 00000000 00000000 ........ 00000000 00000000 ........
03A8 00000000 00000000 ........ 00000000 00000000 ........
03B0 00000000 00000000 ........ 00000000 00000000 ........
03B8 00000000 00000000 ........ 00000000 00000000 ........
03C0 00000000 00000000 ........ 00000000 00000000 ........
03C8 00000000 00000000 ........ 00000000 00000000 ........
03D0 00000000 00000000 ........ 00000000 00000000 ........
03D8 00000000 00000000 ........ 00000000 00000000 ........
03E0 00000000 00000000 ........ 00000000 00000000 ........
03E8 00000000 00000000 ........ 00000000 00000000 ........
03F0 00000000 00000000 ........ 00000000 00000000 ........
03F8 00000000 000055aa ......U. 00000000 000055aa ......U.
0400 00000000 00000000 ........ 00000000 00000000 ........
0408 00000000 00000000 ........ 00000000 00000000 ........
0410 00000000 00000000 ........ 00000000 00000000 ........
0418 00000000 00000000 ........ 00000000 00000000 ........
0420 00000000 00000000 ........ 00000000 00000000 ........
0428 00000000 00000000 ........ 00000000 00000000 ........
0430 00000000 00000000 ........ 00000000 00000000 ........
0438 00000000 00000000 ........ 00000000 00000000 ........
0440 00000000 00000000 ........ 00000000 00000000 ........
0448 00000000 00000000 ........ 00000000 00000000 ........
0450 00000000 00000000 ........ 00000000 00000000 ........
0458 00000000 00000000 ........ 00000000 00000000 ........
0460 00000000 00000000 ........ 00000000 00000000 ........
0468 00000000 00000000 ........ 00000000 00000000 ........
0470 00000000 00000000 ........ 00000000 00000000 ........
0478 00000000 00000000 ........ 00000000 00000000 ........
0480 00000000 00000000 ........ 00000000 00000000 ........
0488 00000000 00000000 ........ 00000000 00000000 ........
0490 00000000 00000000 ........ 00000000 00000000 ........
0498 00000000 00000000 ........ 00000000 00000000 ........
04A0 00000000 00000000 ........ 00000000 00000000 ........
04A8 00000000 00000000 ........ 00000000 00000000 ........
04B0 00000000 00000000 ........ 00000000 00000000 ........
04B8 00000000 00000000 ........ 00000000 00000000 ........
04C0 00000000 00000000 ........ 00000000 00000000 ........
04C8 00000000 00000000 ........ 00000000 00000000 ........
04D0 00000000 00000000 ........ 00000000 00000000 ........
04D8 00000000 00000000 ........ 00000000 00000000 ........
04E0 00000000 00000000 ........ 00000000 00000000 ........
04E8 00000000 00000000 ........ 00000000 00000000 ........
04F0 00000000 00000000 ........ 00000000 00000000 ........
04F8 00000000 00000000 ........ 00000000 00000000 ........
0500 00000000 00000000 ........ 00000000 00000000 ........
0508 00000000 00000000 ........ 00000000 00000000 ........
0510 00000000 00000000 ........ 00000000 00000000 ........
0518 00000000 00000000 ........ 00000000 00000000 ........
0520 00000000 00000000 ........ 00000000 00000000 ........
0528 00000000 00000000 ........ 00000000 00000000 ........
0530 00000000 00000000 ........ 00000000 00000000 ........
0538 00000000 00000000 ........ 00000000 00000000 ........
0540 00000000 00000000 ........ 00000000 00000000 ........
0548 00000000 00000000 ........ 00000000 00000000 ........
0550 00000000 00000000 ........ 00000000 00000000 ........
0558 00000000 00000000 ........ 00000000 00000000 ........
0560 00000000 00000000 ........ 00000000 00000000 ........
0568 00000000 00000000 ........ 00000000 00000000 ........
0570 00000000 00000000 ........ 00000000 00000000 ........
0578 00000000 00000000 ........ 00000000 00000000 ........
0580 00000000 00000000 ........ 00000000 00000000 ........
0588 00000000 00000000 ........ 00000000 00000000 ........
0590 00000000 00000000 ........ 00000000 00000000 ........
0598 00000000 00000000 ........ 00000000 00000000 ........
05A0 00000000 00000000 ........ 00000000 00000000 ........
05A8 00000000 00000000 ........ 00000000 00000000 ........
05B0 00000000 00000000 ........ 00000000 00000000 ........
05B8 00000000 00000000 ........ 00000000 00000000 ........
05C0 00000000 00000000 ........ 00000000 00000000 ........
05C8 00000000 00000000 ........ 00000000 00000000 ........
05D0 00000000 00000000 ........ 00000000 00000000 ........
05D8 00000000 00000000 ........ 00000000 00000000 ........
05E0 00000000 00000000 ........ 00000000 00000000 ........
05E8 00000000 00000000 ........ 00000000 00000000 ........
05F0 00000000 00000000 ........ 00000000 00000000 ........
05F8 00000000 000055aa ......U. 00000000 000055aa ......U.
FAT32
sector_size 0 0
cluster_size 0 0
reserved 0 0
fats 0 0
dir_entries 0 0
sectors 0 0
media 00 00
fat_length 0 0
secs_track 0 0
heads 0 0
hidden 0 0
total_sect 0 0
fat32_length 0 0
flags 0000 0000
version 0.0 0.0
root_cluster 0 0
info_sector 0 0
backup_boot 0 0
free_count 0 0
next_free 0 0
fat32_boot_sector
Bad
Bad
rebuild_FAT_BS p_fat12 0, p_fat16 0, p_fat32 1
fat_find_type(max_offset=959536, p_fat12=0, p_fat16=0, p_fat32=1, debug=1, dump_ind=0)
FAT32 at 2048(0/65/2), nbr=704
FAT32 at 6144(0/130/3), nbr=1
FAT32 at 6145(0/130/4), nbr=1
FAT32 at 6146(0/130/5), nbr=1
FAT32 at 6147(0/130/6), nbr=1
FAT32 at 6148(0/130/7), nbr=1
FAT32 at 6149(0/130/8), nbr=1
FAT32 at 6150(0/130/9), nbr=1
FAT32 at 6151(0/130/10), nbr=1
FAT32 at 6152(0/130/11), nbr=1
FAT32 at 6153(0/130/12), nbr=1
FAT32 at 6154(0/130/13), nbr=1
FAT32 at 6155(0/130/14), nbr=1
FAT32 at 6156(0/130/15), nbr=1
FAT32 at 6157(0/130/16), nbr=1
FAT32 at 6158(0/130/17), nbr=1
FAT32 at 6159(0/130/18), nbr=1
FAT32 at 6160(0/130/19), nbr=1
FAT32 at 6161(0/130/20), nbr=1
FAT32 at 6162(0/130/21), nbr=1
FAT32 at 6163(0/130/22), nbr=1
FAT32 at 6164(0/130/23), nbr=1
FAT32 at 6165(0/130/24), nbr=1
FAT32 at 6166(0/130/25), nbr=1
FAT32 at 6167(0/130/26), nbr=1
FAT32 at 6168(0/130/27), nbr=1
FAT32 at 6169(0/130/28), nbr=1
FAT32 at 6170(0/130/29), nbr=1
FAT32 at 6171(0/130/30), nbr=1
FAT32 at 6172(0/130/31), nbr=1
FAT32 at 6173(0/130/32), nbr=1
FAT32 at 6174(0/130/33), nbr=1
FAT32 at 6175(0/130/34), nbr=1
FAT32 at 6176(0/130/35), nbr=1
FAT32 at 6177(0/130/36), nbr=1
FAT32 at 6178(0/130/37), nbr=1
FAT32 at 6179(0/130/38), nbr=1
FAT32 at 6180(0/130/39), nbr=1
FAT32 at 6181(0/130/40), nbr=1
FAT32 at 6182(0/130/41), nbr=1
FAT32 at 6183(0/130/42), nbr=1
FAT32 at 6184(0/130/43), nbr=1
FAT32 at 6185(0/130/44), nbr=1
FAT32 at 6186(0/130/45), nbr=1
FAT32 at 6187(0/130/46), nbr=1
FAT32 at 6188(0/130/47), nbr=1
FAT32 at 6189(0/130/48), nbr=1
FAT32 at 6190(0/130/49), nbr=1
FAT32 at 6191(0/130/50), nbr=1
FAT32 at 6192(0/130/51), nbr=1
FAT32 at 6193(0/130/52), nbr=1
FAT32 at 6194(0/130/53), nbr=1
FAT32 at 6195(0/130/54), nbr=1
FAT32 at 6196(0/130/55), nbr=1
FAT32 at 6197(0/130/56), nbr=1
FAT32 at 6198(0/130/57), nbr=1
FAT32 at 6199(0/130/58), nbr=1
FAT32 at 6200(0/130/59), nbr=1
FAT32 at 6201(0/130/60), nbr=1
FAT32 at 6202(0/130/61), nbr=1
FAT32 at 6203(0/130/62), nbr=1
FAT32 at 6204(0/130/63), nbr=1
FAT32 at 6205(0/131/1), nbr=1
FAT32 at 6206(0/131/2), nbr=1
FAT32 at 6207(0/131/3), nbr=1
FAT32 at 6208(0/131/4), nbr=1
FAT32 at 6209(0/131/5), nbr=1
FAT32 at 6210(0/131/6), nbr=1
FAT32 at 6211(0/131/7), nbr=1
FAT32 at 6212(0/131/8), nbr=1
FAT32 at 6213(0/131/9), nbr=1
FAT32 at 6214(0/131/10), nbr=1
FAT32 at 6216(0/131/12), nbr=1
FAT32 at 6218(0/131/14), nbr=1
FAT32 at 6219(0/131/15), nbr=1
FAT32 at 6220(0/131/16), nbr=1
FAT32 at 6221(0/131/17), nbr=1
FAT32 at 6222(0/131/18), nbr=1
FAT32 at 6223(0/131/19), nbr=1
FAT32 at 6224(0/131/20), nbr=1
FAT32 at 6230(0/131/26), nbr=1
FAT32 at 6231(0/131/27), nbr=1
FAT32 at 6232(0/131/28), nbr=1
FAT32 at 6233(0/131/29), nbr=1
FAT32 at 6234(0/131/30), nbr=1
FAT32 at 6238(0/131/34), nbr=1
FAT32 at 6239(0/131/35), nbr=1
FAT32 at 6240(0/131/36), nbr=1
FAT32 at 6241(0/131/37), nbr=1
FAT32 at 6242(0/131/38), nbr=1
FAT32 at 6243(0/131/39), nbr=1
FAT32 at 6244(0/131/40), nbr=1
FAT32 at 6245(0/131/41), nbr=1
FAT32 at 6246(0/131/42), nbr=1
FAT32 at 6247(0/131/43), nbr=1
FAT32 at 6248(0/131/44), nbr=1
FAT32 at 6249(0/131/45), nbr=1
FAT32 at 6250(0/131/46), nbr=1
FAT32 at 6251(0/131/47), nbr=1
FAT32 at 6252(0/131/48), nbr=1
FAT32 at 6253(0/131/49), nbr=1
FAT32 at 6254(0/131/50), nbr=1
FAT32 at 6255(0/131/51), nbr=1
FAT32 at 6256(0/131/52), nbr=1
FAT32 at 6257(0/131/53), nbr=1
FAT32 at 6258(0/131/54), nbr=1
FAT32 at 6259(0/131/55), nbr=1
FAT32 at 6261(0/131/57), nbr=1
FAT32 at 20226(1/98/36), nbr=1
FAT32 at 20738(1/106/44), nbr=1
FAT32 at 21327(1/116/3), nbr=1
FAT32 at 21333(1/116/9), nbr=1
FAT32 at 21620(1/120/44), nbr=1
FAT32 at 22090(1/128/10), nbr=1
FAT32 at 22091(1/128/11), nbr=1
FAT32 at 22141(1/128/61), nbr=1
FAT32 at 22142(1/128/62), nbr=1
FAT32 at 23320(1/147/43), nbr=1
FAT32 at 23618(1/152/26), nbr=1
FAT32 at 24179(1/161/20), nbr=1
FAT32 at 24180(1/161/21), nbr=1
FAT32 at 24837(1/171/48), nbr=1
FAT32 at 26136(1/192/24), nbr=1
FAT32 at 28461(1/229/18), nbr=1
FAT32 at 30985(2/14/22), nbr=1
FAT32 at 31834(2/27/52), nbr=1
FAT32 at 33087(2/47/45), nbr=1
FAT32 at 34339(2/67/37), nbr=1
FAT32 at 34340(2/67/38), nbr=1
FAT32 at 34341(2/67/39), nbr=1
FAT32 at 34342(2/67/40), nbr=1
FAT32 at 34343(2/67/41), nbr=1
FAT32 at 34344(2/67/42), nbr=1
FAT32 at 34345(2/67/43), nbr=1
FAT32 at 34346(2/67/44), nbr=1
FAT32 at 34910(2/76/41), nbr=1
FAT32 at 34911(2/76/42), nbr=1
FAT32 at 37423(2/116/34), nbr=1
FAT32 at 37424(2/116/35), nbr=1
FAT32 at 37425(2/116/36), nbr=1
FAT32 at 37426(2/116/37), nbr=1
FAT32 at 37427(2/116/38), nbr=1
FAT32 at 38191(2/128/46), nbr=1
FAT32 at 38192(2/128/47), nbr=1
FAT32 at 38193(2/128/48), nbr=1
FAT32 at 38508(2/133/48), nbr=1
FAT32 at 39298(2/146/19), nbr=1
FAT32 at 40201(2/160/40), nbr=1
FAT32 at 44790(2/233/30), nbr=1
FAT32 at 46282(3/2/10), nbr=1
FAT32 at 46425(3/4/27), nbr=1
FAT32 at 47774(3/25/53), nbr=1
FAT32 at 49049(3/46/5), nbr=1
FAT32 at 49050(3/46/6), nbr=1
FAT32 at 49051(3/46/7), nbr=1
FAT32 at 49052(3/46/8), nbr=1
FAT32 at 51355(3/82/43), nbr=1
FAT32 at 51356(3/82/44), nbr=1
FAT32 at 51357(3/82/45), nbr=1
FAT32 at 51358(3/82/46), nbr=1
FAT32 at 51359(3/82/47), nbr=1
FAT32 at 51360(3/82/48), nbr=1
FAT32 at 51537(3/85/36), nbr=1
FAT32 at 53252(3/112/50), nbr=1
FAT32 at 56129(3/158/29), nbr=1
FAT32 at 56131(3/158/31), nbr=1
FAT32 at 56838(3/169/45), nbr=1
FAT32 at 62751(4/8/36), nbr=1
FAT32 at 65141(4/46/32), nbr=1
FAT32 at 65142(4/46/33), nbr=1
FAT32 at 65143(4/46/34), nbr=1
FAT32 at 65144(4/46/35), nbr=1
FAT32 at 65145(4/46/36), nbr=1
FAT32 at 65146(4/46/37), nbr=1
FAT32 at 65147(4/46/38), nbr=1
FAT32 at 65148(4/46/39), nbr=1
FAT32 at 65149(4/46/40), nbr=1
FAT32 at 65150(4/46/41), nbr=1
FAT32 at 65151(4/46/42), nbr=1
FAT32 at 65152(4/46/43), nbr=1
FAT32 at 65153(4/46/44), nbr=1
FAT32 at 65154(4/46/45), nbr=1
FAT32 at 65155(4/46/46), nbr=1
FAT32 at 65156(4/46/47), nbr=1
FAT32 at 65157(4/46/48), nbr=1
FAT32 at 65158(4/46/49), nbr=1
FAT32 at 65159(4/46/50), nbr=1
FAT32 at 65160(4/46/51), nbr=1
FAT32 at 65161(4/46/52), nbr=1
FAT32 at 65162(4/46/53), nbr=1
FAT32 at 65163(4/46/54), nbr=1
FAT32 at 65164(4/46/55), nbr=1
FAT32 at 65165(4/46/56), nbr=1
FAT32 at 65166(4/46/57), nbr=1
FAT32 at 65167(4/46/58), nbr=1
FAT32 at 65168(4/46/59), nbr=1
FAT32 at 65169(4/46/60), nbr=1
FAT32 at 65170(4/46/61), nbr=1
FAT32 at 65171(4/46/62), nbr=1
FAT32 at 65172(4/46/63), nbr=1
FAT32 at 65173(4/47/1), nbr=1
FAT32 at 65174(4/47/2), nbr=1
FAT32 at 65175(4/47/3), nbr=1
FAT32 at 65176(4/47/4), nbr=1
FAT32 at 65177(4/47/5), nbr=1
FAT32 at 65178(4/47/6), nbr=1
FAT32 at 65179(4/47/7), nbr=1
FAT32 at 65180(4/47/8), nbr=1
FAT32 at 65181(4/47/9), nbr=1
FAT32 at 65182(4/47/10), nbr=1
FAT32 at 65183(4/47/11), nbr=1
FAT32 at 65184(4/47/12), nbr=1
FAT32 at 65185(4/47/13), nbr=1
FAT32 at 65186(4/47/14), nbr=1
FAT32 at 65187(4/47/15), nbr=1
FAT32 at 65188(4/47/16), nbr=1
FAT32 at 65189(4/47/17), nbr=1
FAT32 at 65190(4/47/18), nbr=1
FAT32 at 65191(4/47/19), nbr=1
FAT32 at 65192(4/47/20), nbr=1
FAT32 at 65193(4/47/21), nbr=1
FAT32 at 65194(4/47/22), nbr=1
FAT32 at 65195(4/47/23), nbr=1
FAT32 at 65196(4/47/24), nbr=1
FAT32 at 65197(4/47/25), nbr=1
FAT32 at 65198(4/47/26), nbr=1
FAT32 at 65199(4/47/27), nbr=1
FAT32 at 65200(4/47/28), nbr=1
FAT32 at 65201(4/47/29), nbr=1
FAT32 at 65202(4/47/30), nbr=1
FAT32 at 65203(4/47/31), nbr=1
FAT32 at 65204(4/47/32), nbr=1
FAT32 at 65205(4/47/33), nbr=1
FAT32 at 65206(4/47/34), nbr=1
FAT32 at 65207(4/47/35), nbr=1
FAT32 at 65208(4/47/36), nbr=1
FAT32 at 65209(4/47/37), nbr=1
FAT32 at 65210(4/47/38), nbr=1
FAT32 at 65211(4/47/39), nbr=1
FAT32 at 65212(4/47/40), nbr=1
FAT32 at 65213(4/47/41), nbr=1
FAT32 at 65214(4/47/42), nbr=1
FAT32 at 65215(4/47/43), nbr=1
FAT32 at 65216(4/47/44), nbr=1
FAT32 at 65217(4/47/45), nbr=1
FAT32 at 65218(4/47/46), nbr=1
FAT32 at 65219(4/47/47), nbr=1
FAT32 at 65220(4/47/48), nbr=1
FAT32 at 65221(4/47/49), nbr=1
FAT32 at 65222(4/47/50), nbr=1
FAT32 at 65223(4/47/51), nbr=1
FAT32 at 65224(4/47/52), nbr=1
FAT32 at 65225(4/47/53), nbr=1
FAT32 at 65226(4/47/54), nbr=1
FAT32 at 65227(4/47/55), nbr=1
FAT32 at 65228(4/47/56), nbr=1
FAT32 at 65229(4/47/57), nbr=1
FAT32 at 65230(4/47/58), nbr=1
FAT32 at 65231(4/47/59), nbr=1
FAT32 at 65232(4/47/60), nbr=1
FAT32 at 65233(4/47/61), nbr=1
FAT32 at 65234(4/47/62), nbr=1
FAT32 at 65235(4/47/63), nbr=1
FAT32 at 65236(4/48/1), nbr=1
FAT32 at 65237(4/48/2), nbr=1
FAT32 at 65238(4/48/3), nbr=1
FAT32 at 65239(4/48/4), nbr=1
FAT32 at 65240(4/48/5), nbr=1
FAT32 at 65241(4/48/6), nbr=1
FAT32 at 65242(4/48/7), nbr=1
FAT32 at 65243(4/48/8), nbr=1
FAT32 at 65244(4/48/9), nbr=1
FAT32 at 65245(4/48/10), nbr=1
FAT32 at 65246(4/48/11), nbr=1
FAT32 at 65247(4/48/12), nbr=1
FAT32 at 65248(4/48/13), nbr=1
FAT32 at 65249(4/48/14), nbr=1
FAT32 at 65250(4/48/15), nbr=1
FAT32 at 65251(4/48/16), nbr=1
FAT32 at 65252(4/48/17), nbr=1
FAT32 at 65253(4/48/18), nbr=1
FAT32 at 65254(4/48/19), nbr=1
FAT32 at 65255(4/48/20), nbr=1
FAT32 at 65256(4/48/21), nbr=1
FAT32 at 65257(4/48/22), nbr=1
FAT32 at 65258(4/48/23), nbr=1
FAT32 at 65259(4/48/24), nbr=1
FAT32 at 65260(4/48/25), nbr=1
FAT32 at 65261(4/48/26), nbr=1
FAT32 at 65262(4/48/27), nbr=1
FAT32 at 65263(4/48/28), nbr=1
FAT32 at 65264(4/48/29), nbr=1
FAT32 at 65265(4/48/30), nbr=1
FAT32 at 65266(4/48/31), nbr=1
FAT32 at 65267(4/48/32), nbr=1
FAT32 at 65268(4/48/33), nbr=1
FAT32 at 65269(4/48/34), nbr=1
FAT32 at 65270(4/48/35), nbr=1
FAT32 at 65271(4/48/36), nbr=1
FAT32 at 65272(4/48/37), nbr=1
FAT32 at 65273(4/48/38), nbr=1
FAT32 at 65274(4/48/39), nbr=1
FAT32 at 65275(4/48/40), nbr=1
FAT32 at 65276(4/48/41), nbr=1
FAT32 at 65277(4/48/42), nbr=1
FAT32 at 65278(4/48/43), nbr=1
FAT32 at 65279(4/48/44), nbr=1
FAT32 at 65794(4/56/55), nbr=1
FAT32 at 65795(4/56/56), nbr=1
FAT32 at 65796(4/56/57), nbr=1
FAT32 at 65797(4/56/58), nbr=1
FAT32 at 65798(4/56/59), nbr=1
FAT32 at 65799(4/56/60), nbr=1
FAT32 at 65800(4/56/61), nbr=1
FAT32 at 65801(4/56/62), nbr=1
FAT32 at 65802(4/56/63), nbr=1
FAT32 at 65803(4/57/1), nbr=1
FAT32 at 65804(4/57/2), nbr=1
FAT32 at 65805(4/57/3), nbr=1
FAT32 at 65806(4/57/4), nbr=1
FAT32 at 65807(4/57/5), nbr=1
FAT32 at 65808(4/57/6), nbr=1
FAT32 at 65809(4/57/7), nbr=1
FAT32 at 65810(4/57/8), nbr=1
FAT32 at 65811(4/57/9), nbr=1
FAT32 at 65812(4/57/10), nbr=1
FAT32 at 65813(4/57/11), nbr=1
FAT32 at 65814(4/57/12), nbr=1
FAT32 at 65815(4/57/13), nbr=1
FAT32 at 65816(4/57/14), nbr=1
FAT32 at 65817(4/57/15), nbr=1
FAT32 at 65818(4/57/16), nbr=1
FAT32 at 65819(4/57/17), nbr=1
FAT32 at 65820(4/57/18), nbr=1
FAT32 at 65821(4/57/19), nbr=1
FAT32 at 65822(4/57/20), nbr=1
FAT32 at 65823(4/57/21), nbr=1
FAT32 at 65824(4/57/22), nbr=1
FAT32 at 65825(4/57/23), nbr=1
FAT32 at 65826(4/57/24), nbr=1
FAT32 at 65827(4/57/25), nbr=1
FAT32 at 65828(4/57/26), nbr=1
FAT32 at 65829(4/57/27), nbr=1
FAT32 at 65830(4/57/28), nbr=1
FAT32 at 65831(4/57/29), nbr=1
FAT32 at 65832(4/57/30), nbr=1
FAT32 at 65833(4/57/31), nbr=1
FAT32 at 65834(4/57/32), nbr=1
FAT32 at 65835(4/57/33), nbr=1
FAT32 at 65836(4/57/34), nbr=1
FAT32 at 65837(4/57/35), nbr=1
FAT32 at 65838(4/57/36), nbr=1
FAT32 at 65839(4/57/37), nbr=1
FAT32 at 65840(4/57/38), nbr=1
FAT32 at 65841(4/57/39), nbr=1
FAT32 at 65842(4/57/40), nbr=1
FAT32 at 65843(4/57/41), nbr=1
FAT32 at 65844(4/57/42), nbr=1
FAT32 at 65845(4/57/43), nbr=1
FAT32 at 65846(4/57/44), nbr=1
FAT32 at 65847(4/57/45), nbr=1
FAT32 at 65848(4/57/46), nbr=1
FAT32 at 65849(4/57/47), nbr=1
FAT32 at 65850(4/57/48), nbr=1
FAT32 at 65851(4/57/49), nbr=1
FAT32 at 65852(4/57/50), nbr=1
FAT32 at 65853(4/57/51), nbr=1
FAT32 at 65854(4/57/52), nbr=1
FAT32 at 65855(4/57/53), nbr=1
FAT32 at 65856(4/57/54), nbr=1
FAT32 at 65857(4/57/55), nbr=1
FAT32 at 65858(4/57/56), nbr=1
FAT32 at 65859(4/57/57), nbr=1
FAT32 at 65860(4/57/58), nbr=1
FAT32 at 65861(4/57/59), nbr=1
FAT32 at 65862(4/57/60), nbr=1
FAT32 at 65863(4/57/61), nbr=1
FAT32 at 65864(4/57/62), nbr=1
FAT32 at 65865(4/57/63), nbr=1
FAT32 at 65866(4/58/1), nbr=1
FAT32 at 65867(4/58/2), nbr=1
FAT32 at 65868(4/58/3), nbr=1
FAT32 at 65869(4/58/4), nbr=1
FAT32 at 65870(4/58/5), nbr=1
FAT32 at 65871(4/58/6), nbr=1
FAT32 at 65872(4/58/7), nbr=1
FAT32 at 65873(4/58/8), nbr=1
FAT32 at 65874(4/58/9), nbr=1
FAT32 at 65875(4/58/10), nbr=1
FAT32 at 65876(4/58/11), nbr=1
FAT32 at 65877(4/58/12), nbr=1
FAT32 at 65878(4/58/13), nbr=1
FAT32 at 65879(4/58/14), nbr=1
FAT32 at 65880(4/58/15), nbr=1
FAT32 at 65881(4/58/16), nbr=1
FAT32 at 65882(4/58/17), nbr=1
FAT32 at 65883(4/58/18), nbr=1
FAT32 at 65884(4/58/19), nbr=1
FAT32 at 65885(4/58/20), nbr=1
FAT32 at 65886(4/58/21), nbr=1
FAT32 at 65887(4/58/22), nbr=1
FAT32 at 65888(4/58/23), nbr=1
FAT32 at 65889(4/58/24), nbr=1
FAT32 at 65890(4/58/25), nbr=1
FAT32 at 65891(4/58/26), nbr=1
FAT32 at 65892(4/58/27), nbr=1
FAT32 at 65893(4/58/28), nbr=1
FAT32 at 65894(4/58/29), nbr=1
FAT32 at 65895(4/58/30), nbr=1
FAT32 at 65896(4/58/31), nbr=1
FAT32 at 65897(4/58/32), nbr=1
FAT32 at 65898(4/58/33), nbr=1
FAT32 at 65899(4/58/34), nbr=1
FAT32 at 65900(4/58/35), nbr=1
FAT32 at 65901(4/58/36), nbr=1
FAT32 at 65902(4/58/37), nbr=1
FAT32 at 65903(4/58/38), nbr=1
FAT32 at 65904(4/58/39), nbr=1
FAT32 at 65905(4/58/40), nbr=1
FAT32 at 65906(4/58/41), nbr=1
FAT32 at 65907(4/58/42), nbr=1
FAT32 at 65908(4/58/43), nbr=1
FAT32 at 65909(4/58/44), nbr=1
FAT32 at 65910(4/58/45), nbr=1
FAT32 at 65911(4/58/46), nbr=1
FAT32 at 65912(4/58/47), nbr=1
FAT32 at 65913(4/58/48), nbr=1
FAT32 at 65914(4/58/49), nbr=1
FAT32 at 65915(4/58/50), nbr=1
FAT32 at 65916(4/58/51), nbr=1
FAT32 at 65917(4/58/52), nbr=1
FAT32 at 65918(4/58/53), nbr=1
FAT32 at 65919(4/58/54), nbr=1
FAT32 at 65920(4/58/55), nbr=1
FAT32 at 65921(4/58/56), nbr=1
FAT32 at 65922(4/58/57), nbr=1
FAT32 at 65923(4/58/58), nbr=1
FAT32 at 65924(4/58/59), nbr=1
FAT32 at 65925(4/58/60), nbr=1
FAT32 at 65926(4/58/61), nbr=1
FAT32 at 65927(4/58/62), nbr=1
FAT32 at 65928(4/58/63), nbr=1
FAT32 at 65929(4/59/1), nbr=1
FAT32 at 65930(4/59/2), nbr=1
FAT32 at 65931(4/59/3), nbr=1
FAT32 at 65932(4/59/4), nbr=1
FAT32 at 65933(4/59/5), nbr=1
FAT32 at 65934(4/59/6), nbr=1
FAT32 at 65935(4/59/7), nbr=1
FAT32 at 65936(4/59/8), nbr=1
FAT32 at 65937(4/59/9), nbr=1
FAT32 at 65938(4/59/10), nbr=1
FAT32 at 65939(4/59/11), nbr=1
FAT32 at 65940(4/59/12), nbr=1
FAT32 at 65941(4/59/13), nbr=1
FAT32 at 65942(4/59/14), nbr=1
FAT32 at 65943(4/59/15), nbr=1
FAT32 at 65944(4/59/16), nbr=1
FAT32 at 65945(4/59/17), nbr=1
FAT32 at 65946(4/59/18), nbr=1
FAT32 at 65947(4/59/19), nbr=1
FAT32 at 65948(4/59/20), nbr=1
FAT32 at 65949(4/59/21), nbr=1
FAT32 at 65950(4/59/22), nbr=1
FAT32 at 65951(4/59/23), nbr=1
FAT32 at 65952(4/59/24), nbr=1
FAT32 at 65953(4/59/25), nbr=1
FAT32 at 65954(4/59/26), nbr=1
FAT32 at 65955(4/59/27), nbr=1
FAT32 at 65956(4/59/28), nbr=1
FAT32 at 65957(4/59/29), nbr=1
FAT32 at 65958(4/59/30), nbr=1
FAT32 at 65959(4/59/31), nbr=1
FAT32 at 65960(4/59/32), nbr=1
FAT32 at 65961(4/59/33), nbr=1
FAT32 at 65962(4/59/34), nbr=1
FAT32 at 65963(4/59/35), nbr=1
FAT32 at 65964(4/59/36), nbr=1
FAT32 at 65965(4/59/37), nbr=1
FAT32 at 65966(4/59/38), nbr=1
FAT32 at 65967(4/59/39), nbr=1
FAT32 at 65968(4/59/40), nbr=1
FAT32 at 65969(4/59/41), nbr=1
FAT32 at 65970(4/59/42), nbr=1
FAT32 at 65971(4/59/43), nbr=1
FAT32 at 65972(4/59/44), nbr=1
FAT32 at 65973(4/59/45), nbr=1
FAT32 at 65974(4/59/46), nbr=1
FAT32 at 65975(4/59/47), nbr=1
FAT32 at 65976(4/59/48), nbr=1
FAT32 at 65977(4/59/49), nbr=1
FAT32 at 65978(4/59/50), nbr=1
FAT32 at 65979(4/59/51), nbr=1
FAT32 at 65980(4/59/52), nbr=1
FAT32 at 65981(4/59/53), nbr=1
FAT32 at 65982(4/59/54), nbr=1
FAT32 at 65983(4/59/55), nbr=1
FAT32 at 65984(4/59/56), nbr=1
FAT32 at 65985(4/59/57), nbr=1
FAT32 at 65986(4/59/58), nbr=1
FAT32 at 65987(4/59/59), nbr=1
FAT32 at 65988(4/59/60), nbr=1
FAT32 at 65989(4/59/61), nbr=1
FAT32 at 65990(4/59/62), nbr=1
FAT32 at 65991(4/59/63), nbr=1
FAT32 at 65992(4/60/1), nbr=1
FAT32 at 65993(4/60/2), nbr=1
FAT32 at 65994(4/60/3), nbr=1
FAT32 at 65995(4/60/4), nbr=1
FAT32 at 65996(4/60/5), nbr=1
FAT32 at 65997(4/60/6), nbr=1
FAT32 at 65998(4/60/7), nbr=1
FAT32 at 65999(4/60/8), nbr=1
FAT32 at 66000(4/60/9), nbr=1
FAT32 at 66001(4/60/10), nbr=1
FAT32 at 66002(4/60/11), nbr=1
FAT32 at 66003(4/60/12), nbr=1
FAT32 at 66004(4/60/13), nbr=1
FAT32 at 66005(4/60/14), nbr=1
FAT32 at 66006(4/60/15), nbr=1
FAT32 at 66007(4/60/16), nbr=1
FAT32 at 66008(4/60/17), nbr=1
FAT32 at 66009(4/60/18), nbr=1
FAT32 at 66010(4/60/19), nbr=1
FAT32 at 66011(4/60/20), nbr=1
FAT32 at 66012(4/60/21), nbr=1
FAT32 at 66013(4/60/22), nbr=1
FAT32 at 66014(4/60/23), nbr=1
FAT32 at 66015(4/60/24), nbr=1
FAT32 at 66016(4/60/25), nbr=1
FAT32 at 66017(4/60/26), nbr=1
FAT32 at 66018(4/60/27), nbr=1
FAT32 at 66019(4/60/28), nbr=1
FAT32 at 66020(4/60/29), nbr=1
FAT32 at 66021(4/60/30), nbr=1
FAT32 at 66022(4/60/31), nbr=1
FAT32 at 66023(4/60/32), nbr=1
FAT32 at 66024(4/60/33), nbr=1
FAT32 at 66025(4/60/34), nbr=1
FAT32 at 66026(4/60/35), nbr=1
FAT32 at 66027(4/60/36), nbr=1
FAT32 at 66028(4/60/37), nbr=1
FAT32 at 66029(4/60/38), nbr=1
FAT32 at 66030(4/60/39), nbr=1
FAT32 at 66031(4/60/40), nbr=1
FAT32 at 66032(4/60/41), nbr=1
FAT32 at 66033(4/60/42), nbr=1
FAT32 at 66034(4/60/43), nbr=1
FAT32 at 66035(4/60/44), nbr=1
FAT32 at 66036(4/60/45), nbr=1
FAT32 at 66037(4/60/46), nbr=1
FAT32 at 66038(4/60/47), nbr=1
FAT32 at 66039(4/60/48), nbr=1
FAT32 at 66040(4/60/49), nbr=1
FAT32 at 66041(4/60/50), nbr=1
FAT32 at 66042(4/60/51), nbr=1
FAT32 at 66043(4/60/52), nbr=1
FAT32 at 66044(4/60/53), nbr=1
FAT32 at 66045(4/60/54), nbr=1
FAT32 at 66046(4/60/55), nbr=1
FAT32 at 66047(4/60/56), nbr=1
FAT32 at 66628(4/70/7), nbr=1
FAT32 at 66629(4/70/8), nbr=1
FAT32 at 66630(4/70/9), nbr=1
FAT32 at 66631(4/70/10), nbr=1
FAT32 at 66632(4/70/11), nbr=1
FAT32 at 66633(4/70/12), nbr=1
FAT32 at 66634(4/70/13), nbr=1
FAT32 at 66635(4/70/14), nbr=1
FAT32 at 66636(4/70/15), nbr=1
FAT32 at 66637(4/70/16), nbr=1
FAT32 at 66638(4/70/17), nbr=1
FAT32 at 66639(4/70/18), nbr=1
FAT32 at 66640(4/70/19), nbr=1
FAT32 at 66641(4/70/20), nbr=1
FAT32 at 66642(4/70/21), nbr=1
FAT32 at 66643(4/70/22), nbr=1
FAT32 at 66644(4/70/23), nbr=1
FAT32 at 66645(4/70/24), nbr=1
FAT32 at 66646(4/70/25), nbr=1
FAT32 at 66647(4/70/26), nbr=1
FAT32 at 66648(4/70/27), nbr=1
FAT32 at 66649(4/70/28), nbr=1
FAT32 at 66650(4/70/29), nbr=1
FAT32 at 66651(4/70/30), nbr=1
FAT32 at 66652(4/70/31), nbr=1
FAT32 at 66653(4/70/32), nbr=1
FAT32 at 66654(4/70/33), nbr=1
FAT32 at 66655(4/70/34), nbr=1
FAT32 at 66656(4/70/35), nbr=1
FAT32 at 66657(4/70/36), nbr=1
FAT32 at 66658(4/70/37), nbr=1
FAT32 at 66659(4/70/38), nbr=1
FAT32 at 66660(4/70/39), nbr=1
FAT32 at 66661(4/70/40), nbr=1
FAT32 at 66662(4/70/41), nbr=1
FAT32 at 66663(4/70/42), nbr=1
FAT32 at 66664(4/70/43), nbr=1
FAT32 at 66665(4/70/44), nbr=1
FAT32 at 66666(4/70/45), nbr=1
FAT32 at 66667(4/70/46), nbr=1
FAT32 at 66668(4/70/47), nbr=1
FAT32 at 66669(4/70/48), nbr=1
FAT32 at 66670(4/70/49), nbr=1
FAT32 at 66671(4/70/50), nbr=1
FAT32 at 66672(4/70/51), nbr=1
FAT32 at 66673(4/70/52), nbr=1
FAT32 at 66674(4/70/53), nbr=1
FAT32 at 66675(4/70/54), nbr=1
FAT32 at 66676(4/70/55), nbr=1
FAT32 at 66677(4/70/56), nbr=1
FAT32 at 66678(4/70/57), nbr=1
FAT32 at 66679(4/70/58), nbr=1
FAT32 at 66680(4/70/59), nbr=1
FAT32 at 66681(4/70/60), nbr=1
FAT32 at 66682(4/70/61), nbr=1
FAT32 at 66683(4/70/62), nbr=1
FAT32 at 66684(4/70/63), nbr=1
FAT32 at 66685(4/71/1), nbr=1
FAT32 at 66686(4/71/2), nbr=1
FAT32 at 66687(4/71/3), nbr=1
FAT32 at 66688(4/71/4), nbr=1
FAT32 at 66689(4/71/5), nbr=1
FAT32 at 66690(4/71/6), nbr=1
FAT32 at 66691(4/71/7), nbr=1
FAT32 at 66692(4/71/8), nbr=1
FAT32 at 66693(4/71/9), nbr=1
FAT32 at 66694(4/71/10), nbr=1
FAT32 at 66695(4/71/11), nbr=1
FAT32 at 66696(4/71/12), nbr=1
FAT32 at 66697(4/71/13), nbr=1
FAT32 at 66698(4/71/14), nbr=1
FAT32 at 66699(4/71/15), nbr=1
FAT32 at 66700(4/71/16), nbr=1
FAT32 at 66701(4/71/17), nbr=1
FAT32 at 66702(4/71/18), nbr=1
FAT32 at 66703(4/71/19), nbr=1
FAT32 at 66704(4/71/20), nbr=1
FAT32 at 66705(4/71/21), nbr=1
FAT32 at 66706(4/71/22), nbr=1
FAT32 at 66707(4/71/23), nbr=1
FAT32 at 66708(4/71/24), nbr=1
FAT32 at 66709(4/71/25), nbr=1
FAT32 at 66710(4/71/26), nbr=1
FAT32 at 66711(4/71/27), nbr=1
FAT32 at 66712(4/71/28), nbr=1
FAT32 at 66713(4/71/29), nbr=1
FAT32 at 66714(4/71/30), nbr=1
FAT32 at 66715(4/71/31), nbr=1
FAT32 at 66716(4/71/32), nbr=1
FAT32 at 66717(4/71/33), nbr=1
FAT32 at 66718(4/71/34), nbr=1
FAT32 at 66719(4/71/35), nbr=1
FAT32 at 66720(4/71/36), nbr=1
FAT32 at 66721(4/71/37), nbr=1
FAT32 at 66722(4/71/38), nbr=1
FAT32 at 66723(4/71/39), nbr=1
FAT32 at 66724(4/71/40), nbr=1
FAT32 at 66725(4/71/41), nbr=1
FAT32 at 66726(4/71/42), nbr=1
FAT32 at 66727(4/71/43), nbr=1
FAT32 at 66728(4/71/44), nbr=1
FAT32 at 66729(4/71/45), nbr=1
FAT32 at 66730(4/71/46), nbr=1
FAT32 at 66731(4/71/47), nbr=1
FAT32 at 66732(4/71/48), nbr=1
FAT32 at 66733(4/71/49), nbr=1
FAT32 at 66734(4/71/50), nbr=1
FAT32 at 66735(4/71/51), nbr=1
FAT32 at 66736(4/71/52), nbr=1
FAT32 at 66737(4/71/53), nbr=1
FAT32 at 66738(4/71/54), nbr=1
FAT32 at 66739(4/71/55), nbr=1
FAT32 at 66740(4/71/56), nbr=1
FAT32 at 66741(4/71/57), nbr=1
FAT32 at 66742(4/71/58), nbr=1
FAT32 at 66743(4/71/59), nbr=1
FAT32 at 66744(4/71/60), nbr=1
FAT32 at 66745(4/71/61), nbr=1
FAT32 at 66746(4/71/62), nbr=1
FAT32 at 66747(4/71/63), nbr=1
FAT32 at 66748(4/72/1), nbr=1
FAT32 at 66749(4/72/2), nbr=1
FAT32 at 66750(4/72/3), nbr=1
FAT32 at 66751(4/72/4), nbr=1
FAT32 at 66752(4/72/5), nbr=1
FAT32 at 66753(4/72/6), nbr=1
FAT32 at 66754(4/72/7), nbr=1
FAT32 at 66755(4/72/8), nbr=1
FAT32 at 66756(4/72/9), nbr=1
FAT32 at 66757(4/72/10), nbr=1
FAT32 at 66758(4/72/11), nbr=1
FAT32 at 66759(4/72/12), nbr=1
FAT32 at 66760(4/72/13), nbr=1
FAT32 at 66761(4/72/14), nbr=1
FAT32 at 66762(4/72/15), nbr=1
FAT32 at 66763(4/72/16), nbr=1
FAT32 at 66764(4/72/17), nbr=1
FAT32 at 66765(4/72/18), nbr=1
FAT32 at 66766(4/72/19), nbr=1
FAT32 at 66767(4/72/20), nbr=1
FAT32 at 66768(4/72/21), nbr=1
FAT32 at 66769(4/72/22), nbr=1
FAT32 at 66770(4/72/23), nbr=1
FAT32 at 66771(4/72/24), nbr=1
FAT32 at 66772(4/72/25), nbr=1
FAT32 at 66773(4/72/26), nbr=1
FAT32 at 66774(4/72/27), nbr=1
FAT32 at 66775(4/72/28), nbr=1
FAT32 at 66776(4/72/29), nbr=1
FAT32 at 66777(4/72/30), nbr=1
FAT32 at 66778(4/72/31), nbr=1
FAT32 at 66779(4/72/32), nbr=1
FAT32 at 66780(4/72/33), nbr=1
FAT32 at 66781(4/72/34), nbr=1
FAT32 at 66782(4/72/35), nbr=1
FAT32 at 66783(4/72/36), nbr=1
FAT32 at 66784(4/72/37), nbr=1
FAT32 at 66785(4/72/38), nbr=1
FAT32 at 66786(4/72/39), nbr=1
FAT32 at 66787(4/72/40), nbr=1
FAT32 at 66788(4/72/41), nbr=1
FAT32 at 66789(4/72/42), nbr=1
FAT32 at 66790(4/72/43), nbr=1
FAT32 at 66791(4/72/44), nbr=1
FAT32 at 66792(4/72/45), nbr=1
FAT32 at 66793(4/72/46), nbr=1
FAT32 at 66794(4/72/47), nbr=1
FAT32 at 66795(4/72/48), nbr=1
FAT32 at 66796(4/72/49), nbr=1
FAT32 at 66797(4/72/50), nbr=1
FAT32 at 66798(4/72/51), nbr=1
FAT32 at 66799(4/72/52), nbr=1
FAT32 at 66800(4/72/53), nbr=1
FAT32 at 66801(4/72/54), nbr=1
FAT32 at 66802(4/72/55), nbr=1
FAT32 at 66803(4/72/56), nbr=1
FAT32 at 66804(4/72/57), nbr=1
FAT32 at 66805(4/72/58), nbr=1
FAT32 at 66806(4/72/59), nbr=1
FAT32 at 66807(4/72/60), nbr=1
FAT32 at 66808(4/72/61), nbr=1
FAT32 at 66809(4/72/62), nbr=1
FAT32 at 66810(4/72/63), nbr=1
FAT32 at 66811(4/73/1), nbr=1
FAT32 at 66812(4/73/2), nbr=1
FAT32 at 66813(4/73/3), nbr=1
FAT32 at 66814(4/73/4), nbr=1
FAT32 at 66815(4/73/5), nbr=1
FAT32 at 67433(4/82/56), nbr=1
FAT32 at 67751(4/87/59), nbr=1
FAT32 at 68304(4/96/45), nbr=1
FAT32 at 68604(4/101/30), nbr=1
FAT32 at 68605(4/101/31), nbr=1
FAT32 at 69387(4/113/57), nbr=1
FAT32 at 69498(4/115/42), nbr=1
FAT32 at 73653(4/181/39), nbr=1
FAT32 at 73654(4/181/40), nbr=1
FAT32 at 73655(4/181/41), nbr=1
FAT32 at 73656(4/181/42), nbr=1
FAT32 at 73657(4/181/43), nbr=1
FAT32 at 73658(4/181/44), nbr=1
FAT32 at 73659(4/181/45), nbr=1
FAT32 at 73660(4/181/46), nbr=1
FAT32 at 73661(4/181/47), nbr=1
FAT32 at 73662(4/181/48), nbr=1
FAT32 at 73663(4/181/49), nbr=1
FAT32 at 73664(4/181/50), nbr=1
FAT32 at 73665(4/181/51), nbr=1
FAT32 at 73666(4/181/52), nbr=1
FAT32 at 73667(4/181/53), nbr=1
FAT32 at 73668(4/181/54), nbr=1
FAT32 at 73669(4/181/55), nbr=1
FAT32 at 73670(4/181/56), nbr=1
FAT32 at 73671(4/181/57), nbr=1
FAT32 at 73672(4/181/58), nbr=1
FAT32 at 73673(4/181/59), nbr=1
FAT32 at 73674(4/181/60), nbr=1
FAT32 at 73675(4/181/61), nbr=1
FAT32 at 73676(4/181/62), nbr=1
FAT32 at 73677(4/181/63), nbr=1
FAT32 at 73678(4/182/1), nbr=1
FAT32 at 73679(4/182/2), nbr=1
FAT32 at 73680(4/182/3), nbr=1
FAT32 at 73681(4/182/4), nbr=1
FAT32 at 73682(4/182/5), nbr=1
FAT32 at 73683(4/182/6), nbr=1
FAT32 at 73684(4/182/7), nbr=1
FAT32 at 73685(4/182/8), nbr=1
FAT32 at 73686(4/182/9), nbr=1
FAT32 at 73687(4/182/10), nbr=1
FAT32 at 73688(4/182/11), nbr=1
FAT32 at 73689(4/182/12), nbr=1
FAT32 at 73690(4/182/13), nbr=1
FAT32 at 73691(4/182/14), nbr=1
FAT32 at 73692(4/182/15), nbr=1
FAT32 at 73693(4/182/16), nbr=1
FAT32 at 73694(4/182/17), nbr=1
FAT32 at 73695(4/182/18), nbr=1
FAT32 at 73696(4/182/19), nbr=1
FAT32 at 73697(4/182/20), nbr=1
FAT32 at 73698(4/182/21), nbr=1
FAT32 at 73699(4/182/22), nbr=1
FAT32 at 73700(4/182/23), nbr=1
FAT32 at 73701(4/182/24), nbr=1
FAT32 at 73702(4/182/25), nbr=1
FAT32 at 73703(4/182/26), nbr=1
FAT32 at 73704(4/182/27), nbr=1
FAT32 at 73705(4/182/28), nbr=1
FAT32 at 73706(4/182/29), nbr=1
FAT32 at 73707(4/182/30), nbr=1
FAT32 at 73708(4/182/31), nbr=1
FAT32 at 73709(4/182/32), nbr=1
FAT32 at 73710(4/182/33), nbr=1
FAT32 at 73711(4/182/34), nbr=1
FAT32 at 73712(4/182/35), nbr=1
FAT32 at 73713(4/182/36), nbr=1
FAT32 at 73714(4/182/37), nbr=1
FAT32 at 73715(4/182/38), nbr=1
FAT32 at 73716(4/182/39), nbr=1
FAT32 at 73717(4/182/40), nbr=1
FAT32 at 73718(4/182/41), nbr=1
FAT32 at 73719(4/182/42), nbr=1
FAT32 at 73720(4/182/43), nbr=1
FAT32 at 73721(4/182/44), nbr=1
FAT32 at 73722(4/182/45), nbr=1
FAT32 at 73723(4/182/46), nbr=1
FAT32 at 73724(4/182/47), nbr=1
FAT32 at 73725(4/182/48), nbr=1
FAT32 at 73726(4/182/49), nbr=1
FAT32 at 73727(4/182/50), nbr=1
FAT32 at 73760(4/183/20), nbr=1
FAT32 at 74592(4/196/33), nbr=1
FAT32 at 74799(4/199/51), nbr=1
FAT32 at 74800(4/199/52), nbr=1
FAT32 at 74801(4/199/53), nbr=1
FAT32 at 74802(4/199/54), nbr=1
FAT32 at 74803(4/199/55), nbr=1
FAT32 at 74804(4/199/56), nbr=1
FAT32 at 74805(4/199/57), nbr=1
FAT32 at 74806(4/199/58), nbr=1
FAT32 at 74807(4/199/59), nbr=1
FAT32 at 74808(4/199/60), nbr=1
FAT32 at 74809(4/199/61), nbr=1
FAT32 at 74810(4/199/62), nbr=1
FAT32 at 74811(4/199/63), nbr=1
FAT32 at 74812(4/200/1), nbr=1
FAT32 at 74813(4/200/2), nbr=1
FAT32 at 74814(4/200/3), nbr=1
FAT32 at 74815(4/200/4), nbr=1
FAT32 at 74816(4/200/5), nbr=1
FAT32 at 74817(4/200/6), nbr=1
FAT32 at 74818(4/200/7), nbr=1
FAT32 at 74819(4/200/8), nbr=1
FAT32 at 74820(4/200/9), nbr=1
FAT32 at 74821(4/200/10), nbr=1
FAT32 at 74822(4/200/11), nbr=1
FAT32 at 74823(4/200/12), nbr=1
FAT32 at 74824(4/200/13), nbr=1
FAT32 at 74825(4/200/14), nbr=1
FAT32 at 74826(4/200/15), nbr=1
FAT32 at 74827(4/200/16), nbr=1
FAT32 at 74828(4/200/17), nbr=1
FAT32 at 74829(4/200/18), nbr=1
FAT32 at 74830(4/200/19), nbr=1
FAT32 at 74831(4/200/20), nbr=1
FAT32 at 74832(4/200/21), nbr=1
FAT32 at 74833(4/200/22), nbr=1
FAT32 at 74834(4/200/23), nbr=1
FAT32 at 74835(4/200/24), nbr=1
FAT32 at 74836(4/200/25), nbr=1
FAT32 at 74837(4/200/26), nbr=1
FAT32 at 74838(4/200/27), nbr=1
FAT32 at 74839(4/200/28), nbr=1
FAT32 at 74840(4/200/29), nbr=1
FAT32 at 74841(4/200/30), nbr=1
FAT32 at 74842(4/200/31), nbr=1
FAT32 at 74843(4/200/32), nbr=1
FAT32 at 74844(4/200/33), nbr=1
FAT32 at 74845(4/200/34), nbr=1
FAT32 at 74846(4/200/35), nbr=1
FAT32 at 74847(4/200/36), nbr=1
FAT32 at 74848(4/200/37), nbr=1
FAT32 at 74849(4/200/38), nbr=1
FAT32 at 74850(4/200/39), nbr=1
FAT32 at 74851(4/200/40), nbr=1
FAT32 at 74852(4/200/41), nbr=1
FAT32 at 74853(4/200/42), nbr=1
FAT32 at 74854(4/200/43), nbr=1
FAT32 at 74855(4/200/44), nbr=1
FAT32 at 74856(4/200/45), nbr=1
FAT32 at 74857(4/200/46), nbr=1
FAT32 at 74858(4/200/47), nbr=1
FAT32 at 74859(4/200/48), nbr=1
FAT32 at 74860(4/200/49), nbr=1
FAT32 at 74861(4/200/50), nbr=1
FAT32 at 74862(4/200/51), nbr=1
FAT32 at 74863(4/200/52), nbr=1
FAT32 at 74864(4/200/53), nbr=1
FAT32 at 74865(4/200/54), nbr=1
FAT32 at 74866(4/200/55), nbr=1
FAT32 at 74867(4/200/56), nbr=1
FAT32 at 74868(4/200/57), nbr=1
FAT32 at 74869(4/200/58), nbr=1
FAT32 at 74870(4/200/59), nbr=1
FAT32 at 74871(4/200/60), nbr=1
FAT32 at 74872(4/200/61), nbr=1
FAT32 at 74873(4/200/62), nbr=1
FAT32 at 74874(4/200/63), nbr=1
FAT32 at 74875(4/201/1), nbr=1
FAT32 at 74876(4/201/2), nbr=1
FAT32 at 74877(4/201/3), nbr=1
FAT32 at 74878(4/201/4), nbr=1
FAT32 at 74879(4/201/5), nbr=1
FAT32 at 74880(4/201/6), nbr=1
FAT32 at 74881(4/201/7), nbr=1
FAT32 at 74882(4/201/8), nbr=1
FAT32 at 74883(4/201/9), nbr=1
FAT32 at 74884(4/201/10), nbr=1
FAT32 at 74885(4/201/11), nbr=1
FAT32 at 74886(4/201/12), nbr=1
FAT32 at 74887(4/201/13), nbr=1
FAT32 at 74888(4/201/14), nbr=1
FAT32 at 74889(4/201/15), nbr=1
FAT32 at 74890(4/201/16), nbr=1
FAT32 at 74891(4/201/17), nbr=1
FAT32 at 74892(4/201/18), nbr=1
FAT32 at 74893(4/201/19), nbr=1
FAT32 at 74894(4/201/20), nbr=1
FAT32 at 74895(4/201/21), nbr=1
FAT32 at 74896(4/201/22), nbr=1
FAT32 at 74897(4/201/23), nbr=1
FAT32 at 74898(4/201/24), nbr=1
FAT32 at 74899(4/201/25), nbr=1
FAT32 at 74900(4/201/26), nbr=1
FAT32 at 74901(4/201/27), nbr=1
FAT32 at 74902(4/201/28), nbr=1
FAT32 at 74903(4/201/29), nbr=1
FAT32 at 74904(4/201/30), nbr=1
FAT32 at 74905(4/201/31), nbr=1
FAT32 at 74906(4/201/32), nbr=1
FAT32 at 74907(4/201/33), nbr=1
FAT32 at 74908(4/201/34), nbr=1
FAT32 at 74909(4/201/35), nbr=1
FAT32 at 74910(4/201/36), nbr=1
FAT32 at 74911(4/201/37), nbr=1
FAT32 at 74912(4/201/38), nbr=1
FAT32 at 74913(4/201/39), nbr=1
FAT32 at 74914(4/201/40), nbr=1
FAT32 at 74915(4/201/41), nbr=1
FAT32 at 74916(4/201/42), nbr=1
FAT32 at 74917(4/201/43), nbr=1
FAT32 at 74918(4/201/44), nbr=1
FAT32 at 74919(4/201/45), nbr=1
FAT32 at 74920(4/201/46), nbr=1
FAT32 at 74921(4/201/47), nbr=1
FAT32 at 74922(4/201/48), nbr=1
FAT32 at 74923(4/201/49), nbr=1
FAT32 at 74924(4/201/50), nbr=1
FAT32 at 74925(4/201/51), nbr=1
FAT32 at 74926(4/201/52), nbr=1
FAT32 at 74927(4/201/53), nbr=1
FAT32 at 74928(4/201/54), nbr=1
FAT32 at 74929(4/201/55), nbr=1
FAT32 at 74930(4/201/56), nbr=1
FAT32 at 74931(4/201/57), nbr=1
FAT32 at 74932(4/201/58), nbr=1
FAT32 at 74933(4/201/59), nbr=1
FAT32 at 74934(4/201/60), nbr=1
FAT32 at 74935(4/201/61), nbr=1
FAT32 at 74936(4/201/62), nbr=1
FAT32 at 74937(4/201/63), nbr=1
FAT32 at 74938(4/202/1), nbr=1
FAT32 at 74939(4/202/2), nbr=1
FAT32 at 74940(4/202/3), nbr=1
FAT32 at 74941(4/202/4), nbr=1
FAT32 at 74942(4/202/5), nbr=1
FAT32 at 74943(4/202/6), nbr=1
FAT32 at 74944(4/202/7), nbr=1
FAT32 at 74945(4/202/8), nbr=1
FAT32 at 74946(4/202/9), nbr=1
FAT32 at 74947(4/202/10), nbr=1
FAT32 at 74948(4/202/11), nbr=1
FAT32 at 74949(4/202/12), nbr=1
FAT32 at 74950(4/202/13), nbr=1
FAT32 at 74951(4/202/14), nbr=1
FAT32 at 74952(4/202/15), nbr=1
FAT32 at 74953(4/202/16), nbr=1
FAT32 at 74954(4/202/17), nbr=1
FAT32 at 74955(4/202/18), nbr=1
FAT32 at 74956(4/202/19), nbr=1
FAT32 at 74957(4/202/20), nbr=1
FAT32 at 74958(4/202/21), nbr=1
FAT32 at 74959(4/202/22), nbr=1
FAT32 at 74960(4/202/23), nbr=1
FAT32 at 74961(4/202/24), nbr=1
FAT32 at 74962(4/202/25), nbr=1
FAT32 at 74963(4/202/26), nbr=1
FAT32 at 74964(4/202/27), nbr=1
FAT32 at 74965(4/202/28), nbr=1
FAT32 at 74966(4/202/29), nbr=1
FAT32 at 74967(4/202/30), nbr=1
FAT32 at 74968(4/202/31), nbr=1
FAT32 at 74969(4/202/32), nbr=1
FAT32 at 74970(4/202/33), nbr=1
FAT32 at 74971(4/202/34), nbr=1
FAT32 at 74972(4/202/35), nbr=1
FAT32 at 74973(4/202/36), nbr=1
FAT32 at 74974(4/202/37), nbr=1
FAT32 at 74975(4/202/38), nbr=1
FAT32 at 74976(4/202/39), nbr=1
FAT32 at 74977(4/202/40), nbr=1
FAT32 at 74978(4/202/41), nbr=1
FAT32 at 74979(4/202/42), nbr=1
FAT32 at 74980(4/202/43), nbr=1
FAT32 at 74981(4/202/44), nbr=1
FAT32 at 74982(4/202/45), nbr=1
FAT32 at 74983(4/202/46), nbr=1
FAT32 at 74984(4/202/47), nbr=1
FAT32 at 74985(4/202/48), nbr=1
FAT32 at 74986(4/202/49), nbr=1
FAT32 at 74987(4/202/50), nbr=1
FAT32 at 74988(4/202/51), nbr=1
FAT32 at 959485(59/217/28), nbr=1
FAT differs, FAT sectors=0-16/4096
first_fat 2048, second_fat 6144
FAT : 32, reserved=0, fat_length=0
find_sectors_per_cluster skip_sectors=5620 (skip_offset=2877440)
Can't find cluster size
fat32_boot_sector
Bad
Bad
califauna
#4 Post by califauna »
bump. Still need help with this!
