Disk Recovery
jliddil
Disk Recovery
#1 Post by jliddil »
Ran Test Disk. Not sure what to do next
Thu Feb 12 18:07:27 2015
TestDisk 7.0-WIP, Data Recovery Utility, January 2015
Compiler: GCC 4.9, MinGW 3.11
Compilation date: Feb 9 2015 17:11:54
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=801569726464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4000752599040
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=750156373504
filewin32_getfilesize(\\.\PhysicalDrive8) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\PhysicalDrive8) SetFilePointer err Incorrect function.
Warning: can't get size for \\.\PhysicalDrive8
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1487008694272
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3000591450112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=13151240192
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=2000364240896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=750153761280
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=4000751550464
Disk \\.\PhysicalDrive0 - 801 GB / 746 GiB - CHS 97451 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 4000 GB / 3725 GiB - CHS 60799 255 63, sector size=4096
Disk \\.\PhysicalDrive3 - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Disk \\.\PhysicalDrive4 - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512
Drive C: - 1487 GB / 1384 GiB - CHS 180785 255 63, sector size=512
Drive E: - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Drive J: - 13 GB / 12 GiB - CHS 1598 255 63, sector size=512
Drive K: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive L: - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512
Drive O: - 4000 GB / 3725 GiB - CHS 60799 255 63, sector size=4096
Analyse Drive E: - 3000 GB / 2794 GiB - CHS 364801 255 63
BAD_RS LBA=1067337157 11131794
HPFS - NTFS 333788 3 45 449796 4 28 1863668567
This partition ends after the disk limits. (start=5362304453, size=1863668567, end=7225973019, disk end=5860530176)
BAD_RS LBA=2152979926 14366400
HPFS - NTFS 134016 204 35 385618 124 61 4041981117
This partition ends after the disk limits. (start=2152979926, size=4041981117, end=6194961042, disk end=5860530176)
BAD_RS LBA=2519155656 4535432
FAT32 424159 136 50 450362 252 4 420958458
This partition ends after the disk limits. (start=6814122952, size=420958458, end=7235081409, disk end=5860530176)
The harddisk (3000 GB / 2794 GiB) seems too small! (< 3704 GB / 3449 GiB)
Store new MBR code
New options :
Dump : No
Align partition: Yes
Expert mode : Yes
interface_load
Re: Disk Recovery
Please explain your problem.
If you are looking for a missing partition, you need to select a disk (ie. \\.\PhysicalDrive2 ), not a partition like Drive E:
