Filesystem seems damaged
Damien
#1 Post by Damien »
I have an external HDD WD My Passport 1 To. Since recently, I am getting "The file or directory is corrupted and unreadable" when I connect it and can't access the data. So here what I did:
Select the PhysicalDrive (Not the Drive E:), Partition type: Intel, Advanced, Boot and i get:
Boot sector: OK
Backup boot sector: OK
But: "A valid NTFS Boot sector must be present"...
So I go forward with Rebuild BS, after a few hours, I end up with the same screen: both boot sector and backup BS are OK...
I try the List and get "Can't open filesystem. Filesystem seems damaged."
I don't really know what to try where to go now...
Could anyone help?
Thanks,
Damien
Tue Feb 17 13:29:42 2015
TestDisk 7.0-WIP, Data Recovery Utility, January 2015
Compiler: GCC 4.9, MinGW 3.11
Compilation date: Feb  9 2015 17:11:54
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=512110190592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=480800407552
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000169537536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Q:)=22218276864
Disk \\.\PhysicalDrive0 - 512 GB / 476 GiB - CHS 62260 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512
Drive C: - 480 GB / 447 GiB - CHS 58453 255 63, sector size=512
Drive E: - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512
Drive Q: - 22 GB / 20 GiB - CHS 2701 255 63, sector size=512
NTFS at 0/32/33
 1 P HPFS - NTFS              0  32 33 121597  37 40 1953456128
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
filesystem size           1953456128
sectors_per_cluster       8
mftmirr_lcn               122091007
clusters_per_mft_record   -10
Status: OK
Status: OK
Sectors are identical.
rebuild_NTFS_BS
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
Status: OK
Status: OK
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Not an exFAT boot sector.
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
Status: OK
Status: OK
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
Status: OK
Status: OK
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
Status: OK
Status: OK
Re: Filesystem seems damaged
Run "cmd" (Right click "Run As Administrator") and "chkdsk /f d:" (replace d: by the correct drive letter).
What is the result ?
If it doesn't work, you can use PhotoRec on this partition to recover your data but it won't recover the original filenames.
Damien
#3 Post by Damien »
Thanks for the answer.
I have heard that "chkdsk /f" can cause data lose... What's the risk?
Damien
#4 Post by Damien »
Does anyone have had a bad experience with the "chkdsk /f" command?
Damien
#5 Post by Damien »
Here is what I get:
The type of the file system is NTFS.
Unable to determine volume version and state. CHKDSK aborted.
What can I do now?
alesterw123
#6 Post by alesterw123 »
Data loss from any storage devices is an inevitable process, however there are probable solutions for recovering data from situations like damaged partitions, file system corruption, deletion of partitions and many other disastrous situations.
The reasons behind recovery of data from these kind of situations is because, the data which is lost from the drive or storage device will not permanently lost from the device until it is overwritten with other data. Thus this paves the way for recovery of data. To know more for the solution refer the following link: url]http://www.rawpartitionrecovery.com/damaged.html[/url]
