Like written in the other thread, I got two partitions on 2x 1TB HDD in RAID 0:
When selecting the first HDD and using Intel as its type, it says:
But TestDisk seems to find only some non-existent Linux partitions.
When using EFI GPT, it says something like "Bad EFI", but finds way more after a deep search:
Apparently, both the partitions I should be having are listed. While the first one is still intact and is accessible, the 200GB one contains all my actual data and my system but is the one that is broken.
When selecting the 200GB partition, it shows me another list of partitions:
However, none of them gave me a reasonable file listing.
The second HDD says "partition sector doesn't have the endmark 0xAA55" when selecting type Intel. I haven't run a deep search on it yet.
I actually don't really know what I'm dealing with here, so I really could use some help.
Windows is the only OS I have installed and I'm not touching my PC atm because I don't want to lose my data, means I cannot use it all.
If anybody is familiar with my problem and would give me some insight or tips, please, I'd really appreciate it.
