Am I doing this right?
lonrot
#1 Post by lonrot »
I'm trying to recover a single 4 TB ExFat partition made in Maverick's Disk Utility.
This single partition on the disk has storage files shared between Windows and Mac.
It became inaccessible after a Windows performed a repair reboot on the main hard drive.
Here's what TestDisk has found:
1) Disk selection (Note: disk0 and rdisk0 have the same size!)
2) EFI GPT detected on Disk0. Is this okay for an exFat partition?
3) MS DATA found! The sector size reflects the 4 TB storage. Is this a green light?
Re: Am I doing this right?
In Advanced, select the partition and choose List or Undelete or Boot/List.
You can try
sudo fsck.exfat /dev/disk0p1
or something similar
lonrot
#3 Post by lonrot »
Christophe the partition is back, however Windows mistakenly tried to "repair" the hard drive during boot, and now it shows up as a Windows primary partition even though it does not have an OS.
Is there a way to get rid of this leftover MBR data and remove the drive from the boot list?
