Unexpected end of file - Nikon D800e raw files Topic is solved
semillerimages
#1 Post by semillerimages »
Photorec 7 manages to find 400+ files off of a Lexar 32Gb compact flash card, but I'm unable to open them in any of the software I have. Photoshop gives an 'unexpected file end' error.
Thanks for any help!
Re: Unexpected end of file - Nikon D800e raw files
Can you send an unmodified files from your D800e camera and a recovered file ?
semillerimages
#3 Post by semillerimages »
Interestingly enough, and probably because of my operation error, the "qphotorec" version recovered all the photos without a single problem!
Thank you cgrenier! I'll be sending a donation very soon!
*steve
cgrenier wrote:Can you send an unmodified files from your D800e camera and a recovered file ?
