Hello!
I accidentily deleted a simple volume from my data drive. I used testdisk, and it show me the partition, but i cant recover it.
HPFS - NTFS 2610 245 4 63411 195 16 976764928 [DataDrive]
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
The harddisk (500 GB / 465 GiB) seems too small! (< 521 GB / 485 GiB)
What do i can do to recover de partition? Can yo help me?
Here'S the log (I used version 6.14)
Thank you so much
regards
Juan
LOG
Sat Apr 11 13:47:15 2015
filewin32_getfilesize(\\.\PhysicalDrive3) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive3) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\PhysicalDrive4) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive4) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\PhysicalDrive5) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive5) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\PhysicalDrive6) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive6) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=500000882688
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=1073741824000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=426556522496
filewin32_getfilesize(\\.\F:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\F:) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\H:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\J:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\J:) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=0
Warning: can't get size for \\.\M:
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500320AS, S/N:2020202020202020202020205135334d38594237, FW:SD1A
Disk /dev/sdb - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512 - ST31500341AS, S/N:202020202020202020202020563930534b534a58, FW:SD17
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500320AS, S/N:2020202020202020202020205135334d305a4735, FW:SD1A
Disk /dev/sda - 500 GB / 465 GiB - ST3500320AS
Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
NTFS at 0/32/33
filesystem size 41943040
mftmirr_lcn 2
HPFS - NTFS 0 32 33 2610 245 3 41943040 [SWAP]
NTFS, blocksize=4096, 21 GB / 20 GiB
NTFS at 2610/245/4
filesystem size 976764928
mftmirr_lcn 2
This partition ends after the disk limits. (start=41945088, size=976764928, end=1018710015, disk end=976773168)
recover_EXT2: s_block_group_nr=0/140, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
recover_EXT2: s_blocks_count 4605952
recover_EXT2: part_size 36847616
Linux 3836 48 53 6129 216 39 36847616
ext4 blocksize=4096 Large file Sparse superblock Recover, 18 GB / 17 GiB
recover_EXT2: s_block_group_nr=0/400, s_mnt_count=3/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 13107200
recover_EXT2: part_size 104857600
Linux 7200 113 18 13727 134 39 104857600
ext4 blocksize=4096 Large file Sparse superblock Recover, 53 GB / 50 GiB
recover_EXT2: s_block_group_nr=0/400, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 14190 8 27 20717 29 48 104857600
Linux 21556 117 2 28083 138 23 104857600
recover_EXT2: s_block_group_nr=0/242, s_mnt_count=17/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
recover_EXT2: s_blocks_count 7937024
recover_EXT2: part_size 63496192
Linux 47358 213 24 51311 74 27 63496192
ext4 blocksize=4096 Large file Sparse superblock Recover, 32 GB / 30 GiB
file_pread(4,3,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(4,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(4,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(4,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(4,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(4,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(4,13,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(4,3,buffer,976775183(60801/112/63)) lseek err Invalid argument
file_pread(4,3,buffer,976775230(60801/113/47)) lseek err Invalid argument
file_pread(4,8,buffer,976775246(60801/113/63)) lseek err Invalid argument
file_pread(4,11,buffer,976775293(60801/114/47)) lseek err Invalid argument
file_pread(4,2,buffer,976777215(60801/145/16)) lseek err Invalid argument
* HPFS - NTFS 0 32 33 2610 245 3 41943040 [SWAP]
P Linux 3836 48 53 6129 216 39 36847616
P Linux 7200 113 18 13727 134 39 104857600
L Linux 14190 8 27 20717 29 48 104857600
L Linux 21556 117 2 28083 138 23 104857600
L Linux 47358 213 24 51311 74 27 63496192
Deleted volume from HDD
Re: Deleted volume from HDD
Using the arrow keys, set the partition you want to recover as P(rimary). On next screen, choose Write, confirm, Quit
