HDD not found by Testdisk? :(
Kebap
#1 Post by Kebap »
Dear all,
I am trying to recover my HDD files. Since the weekend, I can't access the HDD. It does not seem to be recognised by the Bios anymore, at all. Of course, then, it is also not recognised by the operating systems. I wonder if there is any hope left? The HDD motor still works.
Now a friend informed me so I tried connecting the HDD with a SATA->USB adapter. This actually seems to work. At least, I can see the drive in the Windows "Computer Management" Partition overview as "Datenträger 2" (file system = not initialised). See screenshot.
However, Testdisk (windows version) does not seem to recognise this HDD at all. It only shows the other HDD, which has roughly the same size (3tb). I know this, because last night, for ~12 hours, I tried to analyse /dev/sdb - only to notice, it shows the same files as drive Z: listed beneath.
Next, I want to try if the Testdisk Boot-version is any different. What else could I try? Thank you in advance! :mrgreen:
Re: HDD not found by Testdisk? :(
Boot from a Linux LiveCD and check if the disk is detected or not.
http://www.cgsecurity.org/wiki/TestDisk_Livecd
