I have a Sandisk CLIPP that was formatted with firmware for the Bureau of Prisons (U.S.) so that it hides the music files in a hidden partition. I have used testdisk to create a dd file but when I restore it by changing it to '.dmg' it just brings up an exact copy of the file directory that I see when I open the Sansa directly. That means the music files are still hidden.
I am doing this because I want to wipe the drive of the Sansa and reinstall the original manufacturers firmware. I am following the instructions from this link: http://www.wikihow.com/Unlock-a-Federal ... MP3-Player
In it he says to do a whole disk recovery, is that what I did when I created the dd file?
Is there any other way to see the files on there other than changing the dd to dmg?
Thanks in advance for any help.
Hidden Partitions
Re: Hidden Partitions
It looks like you need to run PhotoRec (not TestDisk): start it, select the device, choose the whole disk, Search
