TestDisk 7 on linux stuck after the first screen
addverma
#1 Post by addverma »
I am using TestDisk 7 on linux to recover a lost partition. I am having issues with one of my external hard disk. I believe that the partition on this particular external hard disk has got corrupted. There was a single partition on this external hard disk.
The problem that I am facing is that TestDisk 7 gets stuck after the first screen, where we select the hard disk. On selecting the device and then going for proceed option nothing happens. I have waited for approximately 5 minutes and then I kill the process using kill -9 option.
Can you please let me know how to go the next screen after the first screen in TestDisk 7?
________________________
Have a nice day
Amardeep
addverma
Re: TestDisk 7 on linux stuck after the first screen
#2 Post by addverma »
I finally got TestDisk 7.0 to run. In the Analyze section it gave me an error, "Partition: Read error"
Disk /dev/sdc - 250 GB / 232 GiB - LaCie little Disk
Analyse Disk /dev/sdc - 250 GB / 232 GiB - CHS 238475 64 32
file_pread(6,16,buffer,32(0/1/1)) read err: Input/output error
file_pread(6,3,buffer,48(0/1/17)) read err: Input/output error
file_pread(6,3,buffer,95(0/2/32)) read err: Input/output error
file_pread(6,8,buffer,111(0/3/16)) read err: Input/output error
file_pread(6,11,buffer,158(0/4/31)) read err: Input/output error
file_pread(6,16,buffer,51(0/1/20)) read err: Input/output error
file_pread(6,1,buffer,51(0/1/20)) read err: Input/output error
file_pread(6,2,buffer,98(0/3/3)) read err: Input/output error
file_pread(6,2,buffer,119(0/3/24)) read err: Input/output error
file_pread(6,2,buffer,169(0/5/10)) read err: Input/output error
file_pread(6,16,buffer,63(0/1/32)) read err: Input/output error
file_pread(6,1,buffer,63(0/1/32)) read err: Input/output error
file_pread(6,8,buffer,71(0/2/8)) read err: Input/output error
file_pread(6,3,buffer,79(0/2/16)) read err: Input/output error
file_pread(6,3,buffer,126(0/3/31)) read err: Input/output error
file_pread(6,8,buffer,142(0/4/15)) read err: Input/output error
file_pread(6,11,buffer,189(0/5/30)) read err: Input/output error
file_pread(6,16,buffer,512(0/16/1)) read err: Input/output error
file_pread(6,1,buffer,512(0/16/1)) read err: Input/output error
file_pread(6,8,buffer,520(0/16/9)) read err: Input/output error
file_pread(6,3,buffer,528(0/16/17)) read err: Input/output error
file_pread(6,3,buffer,575(0/17/32)) read err: Input/output error
file_pread(6,8,buffer,591(0/18/16)) read err: Input/output error
file_pread(6,11,buffer,638(0/19/31)) read err: Input/output error
file_pread(6,16,buffer,544(0/17/1)) read err: Input/output error
file_pread(6,1,buffer,544(0/17/1)) read err: Input/output error
file_pread(6,8,buffer,552(0/17/9)) read err: Input/output error
file_pread(6,3,buffer,560(0/17/17)) read err: Input/output error
file_pread(6,3,buffer,607(0/18/32)) read err: Input/output error
file_pread(6,8,buffer,623(0/19/16)) read err: Input/output error
file_pread(6,11,buffer,670(0/20/31)) read err: Input/output error
file_pread(6,16,buffer,1008(0/31/17)) read err: Input/output error
file_pread(6,1,buffer,1008(0/31/17)) read err: Input/output error
file_pread(6,8,buffer,1016(0/31/25)) read err: Input/output error
file_pread(6,3,buffer,1024(0/32/1)) read err: Input/output error
file_pread(6,3,buffer,1071(0/33/16)) read err: Input/output error
file_pread(6,8,buffer,1087(0/33/32)) read err: Input/output error
file_pread(6,11,buffer,1134(0/35/15)) read err: Input/output error
file_pread(6,16,buffer,1074(0/33/19)) read err: Input/output error
file_pread(6,1,buffer,1074(0/33/19)) read err: Input/output error
file_pread(6,8,buffer,1079(0/33/24)) read err: Input/output error
file_pread(6,8,buffer,1150(0/35/31)) read err: Input/output error
file_pread(6,11,buffer,1197(0/37/14)) read err: Input/output error
file_pread(6,1,buffer,0(0/0/1)) read err: Input/output error
Store new MBR code
I believe that my partition has got corrupted or has been lost. How do I recreate it and get my data back. This disk has some important data which I need to recover
_________________________
Have a nice day
Amardeep
#3 Post by cgrenier »
It looks like a hardware problem. As root, use smartctl to check the status of the disk. Check "dmesg" output for errors after trying to access the disk with TestDisk.
