Hi ppls.... in advance I thank you for any help you can give me...
I had a failure on SUSE server with raid 0.... I did a rebuild and then all partitions were gone... now I'm trying to get data back from it and in a quick scan I see all 3 partitions but the partition on which are the most important data gives me an error: the hard disk seems too small
ext3 blocksize=4096 large file sparse superblock, 57GB/53GiB....
can anyone help anyhow... last time they did backup was 2y ago... is there any help
seems too small
Re: seems too small
Can you run a diagnose and copy and paste the content of your testdisk.log into your next post?
Re: seems too small
Mon Apr 20 16:58:54 2015
OS: Windows XP
Compilation date: 2012-10-14T21:06:28
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=79930851328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=4048551936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=79930851328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4048551936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=500105217024
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=4048519680
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=3162112
Disk /dev/sda - 79 GB / 74 GiB - CHS 9717 255 63, sector size=512 - LSI MegaIDE #00, FW:1.0
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WD My Book, FW:1028
Disk /dev/sdc - 4048 MB / 3861 MiB - CHS 492 255 63, sector size=512 - JetFlash Transcend 4GB, FW:1100
Drive X: - 3162 KB / 3088 KiB - CHS 193 1 32, sector size=512 - Microsoft Corporation RamDisk
Disk /dev/sda - 79 GB / 74 GiB - LSI MegaIDE #00
Analyse Disk /dev/sda - 79 GB / 74 GiB - CHS 9717 255 63
Linux Swap 0 1 1 130 254 43 2104432
SWAP2 version 1, pagesize=4096, 1077 MB / 1027 MiB
recover_EXT2: s_block_group_nr=0/160, s_mnt_count=2/500, s_blocks_per_group=32768, s_inodes_per_group=16416
recover_EXT2: s_blocks_count 5242880
recover_EXT2: part_size 41943040
Linux 131 0 1 2741 212 34 41943040
ext3 blocksize=4096 Large file Sparse superblock, 21 GB / 20 GiB
recover_EXT2: s_block_group_nr=0/428, s_mnt_count=1/500, s_blocks_per_group=32768, s_inodes_per_group=16384
recover_EXT2: s_blocks_count 14030769
recover_EXT2: part_size 112246152
Linux 2742 0 1 9728 254 60 112246152
ext3 blocksize=4096 Large file Sparse superblock, 57 GB / 53 GiB
This partition ends after the disk limits. (start=44050230, size=112246152, end=156296381, disk end=156114944)
The harddisk (79 GB / 74 GiB) seems too small! (< 80 GB / 74 GiB)
get_geometry_from_list_part_aux head=255 nbr=3
* Linux Swap 0 1 1 130 254 63 2104452
P Linux 131 0 1 2741 254 63 41945715
1 * Linux Swap 0 1 1 130 254 63 2104452
2 P Linux 131 0 1 2741 254 63 41945715
ty fiona
OS: Windows XP
ty fiona
Re: seems too small
Your disk or array size looks somehow unusual?The harddisk (79 GB / 74 GiB) seems too small! (< 80 GB / 74 GiB)
Probably disk size should be 80 GB and is 79 GB?
Currently, I've no idea why?
Sometimes I'm using a trick to increase disk capacity virtually, so that your partition will be displayed and if it lists data, you can copy them off of your RAID/Disk?
Example:
http://forum.cgsecurity.org/phpBB3/post ... icky#p3435
Please have a try to increase your disk size virtually and run another diagnose to have a try to list your data.
Note: It's intended as a diagnose only.
Don't confirm at Write or modify something.
In testdisk, before you confirm at Analyse, go to geometry and change the value at Cylinder from 9717 to 9729.
Leave all the other options alone and quit the menu geometry at Ok
Run another Analyse and Quick Search.
If your partition ist listed, please mark it and press p to have a try to list your files.
In case, you should copy them to another healthy disk.
Please let me know, have you been able to list your files?
Re: seems too small
ty for your effort....
now after a quick scan I see all 3partitions but there are no files on 3rd one.... at the moment I'm doing extended search.... I will inform you with the results.... one more time ty... cheers
Re: seems too small
I assume that Deeper Search wouldn't be as much helpful either?
Searching partitions on the virtual area can cause read errors.
Did you recreate your RAID?
Are you sure that your RAID fits exactly like before?
Might be possible that there is a problem with your size?
Before your partition was ending exactly at 80 GB and now your disk has less than 80 GB.
If it doesn't fit exactly, it can cause such problems.
Some MB are not available anymore.The harddisk (79 GB / 74 GiB) seems too small! (< 80 GB / 74 GiB)
