hostmagyar
Re: USB HDD Switched to "Unknown File System\Raw data"
I am having the same issue. Had a failing drive that I ddrescued to an external USB. Log looks like this, but it's still showing as RAW, and chkdsk still reports no MFT or mirror.
Photorec was able to recover about 200 GB of files, so it seems like the actual data isn't too damaged, just the MFT. Any idea on how to help with that? I don't need a full bootable OS, just being able to have file names and directories back would be a big help.OS: Windows 7 (7601) SP1
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=319965626368
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000316862464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000048425472
Disk \\.\PhysicalDrive0 - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive C: - 319 GB / 297 GiB - CHS 38900 255 63, sector size=512
Drive E: - 1000 GB / 931 GiB - CHS 121614 255 63, sector size=512
Drive F: - 1000 GB / 931 GiB - CHS 121582 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive1 - 2000 GB / 1862 GiB - CHS 243197 255 63
NTFS at 0/0/3
FAT32 at 121614/237/35
Info: size boot_sector 1953219581, partition 1953219581
FAT1 : 32-238403
FAT2 : 238404-476775
start_rootdir : 476776 root cluster : 2
Data : 476776-1953219559
sectors : 1953219581
cluster_size : 64
no_of_cluster : 30511606 (2 - 30511607)
fat_length 238372 calculated 238372
1 * HPFS - NTFS 0 0 3 121588 57 7 1953314816
2 E extended LBA 121614 0 1 243197 57 60 1953234546
5 L FAT32 LBA 121614 237 35 243197 57 60 1953219581 [DATA YO]
NTFS at 0/0/3
filesystem size 1953314816
mftmirr_lcn 2
FAT1 : 32-238403
cluster_size : 64
FAT32, blocksize=32768, 1000 GB / 931 GiB
add_ext_part_i386: max
add_ext_part_i386: min
NTFS at 0/0/3
mftmirr_lcn 2
FAT1 : 32-238403
cluster_size : 64
write!
write_all_log_i386: CHS: 121614/0/1,lba=1953728910
Did you use testdisk 64 bit?
TestDisk 7.1WIP 32bit is recommended.
In most cases if a partition appears as RAW indicates either a problem with the boot sector or file system.
A boot sector diagnose could probably help.
Info will follow.
Please let me know, did you use testdisk 64bit or testdisk 32bit?
Info will follow.
hostmagyar
I definitely used testdisk 64 bit. I'll retry it using the 32 bit application, and print the boot sector diagnostic tomorrow. Thanks for the advice!
ò.
I have run testdisk on ubuntu.
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60797 255 63
Invalid FAT boot sector
1 P FAT16 >32M 0 32 33 60797 27 30 976703488
>[Quick Search] [ Backup ]
Try to locate partition
