Did I mess up..?
Luuk
Did I mess up..?
#1 Post by Luuk »
2 weeks ago, one of my hard drives in my laptop died, and last week my second hard drive died. The first hard drive, I was able to recover using TestDisk and the basic step by step tutorial, which worked perfectly and was surprisingly simple to do. The second hard drive however I think I messed up. I tried to recover it in the same way as the first one, but now I have written a partition that is only 30 gb big in size, and includes none of the files I originally had on my HDD. I can't seem to find or access the other 300 GB of files I had on my HDD. Did I mess up??
edit: some more info. The search results show that 'The harddisk seems too small' (naturally). Deeper search finds another NFTS but it shows 'cant open file system. filesystem seems damaged'.
Re: Did I mess up..?
Can you copy and paste the content of your testdisk.log?
Is your disk size recognized correctly?
Luuk
#3 Post by Luuk »
Thank you for your reply Fiona.
The disk size it not recognized correctly anymore. It was before I wrote this partition. Now it shows 32GB \ 29GB.
Attached is my log file.
testdisk.zip
(4.93 KiB) Downloaded 569 times
#4 Post by Fiona »
Did you use testdisk 64bit?
The latest release of TestDisk 7 32bit is recommended.
Also, you shouldn't select a drive but your affected Disk instead.
Can you repeat your diagnose and selecting your Disk?
Luuk
#5 Post by Luuk »
Thanks for the reply again. I did use the 7.0 64 bit. I tried the diagnostics again selecting the drive.
Attached is my log.
testdisk.zip
(3.77 KiB) Downloaded 566 times
#6 Post by Fiona »
Would it be possible to use testdisk 32 bit?
TestDisk 64bit is only recommended to work on computer machines like Itanium without WoW64, as some features are not available.
