I have a 1TB disk with it's actuator arm stuck on the platter. I fixed that, and it spins up good again.
I couldn't acces the disk and it didn't showed up in Disk Management, so I tried TestDisk. No partitions were found in the quick search, so I did a deep search. It searched for almost 2 days and after it was done, I saw 1 green partition. TestDisk asked if I wanted to write the partition. I did. After that it said something like 'Could not write partition' (I forgot the exact error).
So I thought I just start TestDisk again and see what happens. Unfortunately it doesn't recognize the disk anymore. I rebooted my computer, reconnect the disk, but nothing works.
Did I do something wrong?
Thanks in advance for the help!
Muloza
