Hi, My external sony hard disk is got corrupted. When I try to open in windows its asking me to format it.
I have attached the log file. Could you please help me to recover the data ?
Thanks,
Kiran
1 * Sys=4F 120527 49 53 234813 237 34 1836016416
Bad relative sector.
2 * Sys=73 119380 132 62 153270 41 37 544437093
3 * Sys=2B 113201 29 24 147074 114 59 544175136
4 * SpeedStor 177063 118 26 177066 225 63 54974
1TB external harddisk recovery
Re: 1TB external harddisk recovery
Did you select your disk under disk selection or drive?
You should use disk instead of drive.
TestDisk 32bit is recommended.
Can you repeat your diagnose and copy and paste the content of your testdisk,log of running Analyse / Quick Search and if nothing would be found Deeper Search also?
If partitions are found, please mark them and press p to have a try to lsit your files.
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
