feature request
WHK102
feature request
#1 Post by WHK102 »
Hello, there are three things I would like to consider please:
When navigating on the files to recover when you return with ".." returns to the entire directory listing and you back down around the car to find the directory where you were, it would be very comfortable if when you return the pointer is on the selected directory above.
When copying a file or directory should have an option to cancel without losing the current session.
When you copy a directory should be displayed in a single line the last file copied (like verbose mode) or else a percentage of progress as it is uncomfortable to be almost an hour copying files without knowing how long it takes and how much remains.
Thanks.
Re: feature request
I have uploaded a new 7.1-WIP that adds the possibility to stop file copy without loosing the session.
Can you try it ?
