can get the correction
Re: can get the correction
If testdisk finds a partition during Quick Search it'll jump to the end of the found partition and keeps scanning.
Your screen shot is taken during a scan.
Important is the result when your scan has finished.
If some partitions are not found during Quick Search, you should run Deeper Search.
