Formated EXT4 on GPT disk - can not recover
burke
#1 Post by burke »
First of all Hello to every one.
Second - my English is not always grate - sorry .
Third - I am a linux novice.
In short yesterday I pulled one of my drives from my pc. I did't notice that my /dev/sdd disk become /dev/sdc. :oops:
I wanted to change label on sdc (not aware of change) but did not mange to to it, as I thought it was an empty drive, I formatted it with ext4 and changed label. After reboot i saw something was wrong with my partition so I changed label back.
I tried running test disk - deepscan but did not manage to find valid partition.
Drive is WD 2TB Black.
Second run of deep scan is in progress, I will borrow a 4 TB drive from a friend, but after first failure Icould really use some advice.
If you need some more info just let me know.
Thank you in advance.
Sinisa aka burke :(
burke
Re: Formated EXT4 on GPT disk - can not recover
#2 Post by burke »
OK, second pass is over,
There are less partitions then on the first run ?!?
There were some UEFI and FAT? first time around
There is no folder structure inside thees partitions ...
Is there anything more I can try?
Thank you :)
