Folders found in 1st run disappeared
yamivy
#1 Post by yamivy »
Thanks for building this tool!
I was able to locate the Users folder with all my files in the first run. I started to copy files and recovered 280MB
My computer crushed and since then the Users folder is empty.
Is there any way to re-find the folders in a specific folder?
Re: Folders found in 1st run disappeared
I'd need more info.
Did you use testdisk to copy data?
Can you repeat your diagnose and provide more info?
Can you copy the content of your testdisk.log into your next post?
