how run photorec_static in ubuntu Topic is solved
akhilms004
#1 Post by akhilms004 »
how can i run photorec_static in my ubuntu
when i try to run photorec _static using the following command "sudo ./photorec_static"
it shows " sudo: ./photorec_static: command not found "
remy
Re: how run photorec_static in ubuntu
#2 Post by remy »
Did you download and uncompress the 6.14-WIP archive on the website ?
./photorec_static means that you are in the folder where photorec_static is.
akhilms004
#3 Post by akhilms004 »
hai remy,
yes i download testdisk-6.14-WIP.linux26.tar.bz2 from cgsecurity.org , then i uzipthe archive and tried to execute
photorec_static from folder where photorec_static is.
remy
#4 Post by remy »
try to copy photorec_static in your/home/user folder and verify in properties if executable flag is ticked.
Then,
sudo ~/photorec_static /dev/yourdisk
should work
akhilms004
#5 Post by akhilms004 »
@remy,
it works;
thnx
