Problem with external drive
danyo
#1 Post by danyo »
Hi
I have a problem with my Buffalo model CE500us drive. It is showing up as raw, cannot access it with Windows.
drive shows being healthy in disk management
disk managment shows drive healthy
I ran testdisk Intel, analize and this is what it showed.
analize
analize
It shows 3 partitions all bad? I don't know what to do next. Could someone please advise.
Thx
Re: Problem with external drive
Can you repeat your diagnose and select your disk instead of a drive?
Run Analyse, Quick Search and if nothing would be found, Deeper Search also.
If partitions are found, please mark them and press p to have a try to list your files.
Can you copy and paste the content of your testdisk.log into your next post?
You'll find it within your testdisk folder.
danyo
#3 Post by danyo »
Hi fiona
Thank you for the reply, I don't see where I would select the "disk" instead of the drive.
When I open testdisk it.just shows the drives listed.
Sorry missed the disk selection at the top.
danyo
#4 Post by danyo »
This is what shows after doing the analize. Which partition do you want me to select.
danyo
#5 Post by danyo »
Got this window partition
danyo
#6 Post by danyo »
Listed all the files
danyo
#7 Post by danyo »
Here is what I got in the testdisk log.
Thu Jun 11 19:53:28 2015
OS: Windows Vista (6002) SP2
Compilation date: 2015-05-23T20:38:26
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=294596596224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=25473692160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500096991744
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512
Drive C: - 294 GB / 274 GiB - CHS 35815 255 63, sector size=512
Drive D: - 25 GB / 23 GiB - CHS 3097 255 63, sector size=512
Drive F: - 500 GB / 465 GiB - CHS 60799 255 63, sector size=512
NTFS at 1/1/1
1 E extended LBA 1 0 1 60800 254 63 976752000
5 L HPFS - NTFS 1 1 1 60800 254 63 976751937
Failed to open inode: Input/output error.
NTFS at 1/1/1
filesystem size 976751937
mftmirr_lcn 61046996
file_pread(5,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(5,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(5,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(5,8,buffer,976773376(60801/84/20)) lseek err Invalid argument
file_pread(5,8,buffer,976773504(60801/86/22)) lseek err Invalid argument
file_pread(5,8,buffer,976773632(60801/88/24)) lseek err Invalid argument
file_pread(5,8,buffer,976773760(60801/90/26)) lseek err Invalid argument
file_pread(5,8,buffer,976773888(60801/92/28)) lseek err Invalid argument
file_pread(5,8,buffer,976774016(60801/94/30)) lseek err Invalid argument
file_pread(5,8,buffer,976774144(60801/96/32)) lseek err Invalid argument
file_pread(5,8,buffer,976774272(60801/98/34)) lseek err Invalid argument
file_pread(5,8,buffer,976774400(60801/100/36)) lseek err Invalid argument
file_pread(5,8,buffer,976774528(60801/102/38)) lseek err Invalid argument
file_pread(5,8,buffer,976774656(60801/104/40)) lseek err Invalid argument
file_pread(5,8,buffer,976774784(60801/106/42)) lseek err Invalid argument
file_pread(5,8,buffer,976774912(60801/108/44)) lseek err Invalid argument
file_pread(5,8,buffer,976775040(60801/110/46)) lseek err Invalid argument
file_pread(5,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(5,13,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(5,3,buffer,976775183(60801/112/63)) lseek err Invalid argument
file_pread(5,3,buffer,976775230(60801/113/47)) lseek err Invalid argument
file_pread(5,8,buffer,976775246(60801/113/63)) lseek err Invalid argument
file_pread(5,11,buffer,976775293(60801/114/47)) lseek err Invalid argument
file_pread(5,2,buffer,976777215(60801/145/16)) lseek err Invalid argument
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 27-May-2015 13:01 .
5 dr-xr-xr-x 0 0 0 27-May-2015 13:01 ..
35 dr-xr-xr-x 0 0 0 10-Oct-2009 02:08 $RECYCLE.BIN
4016 dr-xr-xr-x 0 0 0 7-May-2013 01:48 312253c08292cf9cea5c
1525 dr-xr-xr-x 0 0 0 9-Mar-2015 01:44 Application
47 dr-xr-xr-x 0 0 0 10-Oct-2014 13:28 Downloads
40 dr-xr-xr-x 0 0 0 12-Aug-2014 01:37 E-Books
5594 dr-xr-xr-x 0 0 0 4-Dec-2014 14:12 Mi Documents
5342 dr-xr-xr-x 0 0 0 7-Dec-2014 10:19 Movies
48321 dr-xr-xr-x 0 0 0 21-Oct-2012 11:32 Recorded TV
4729 dr-xr-xr-x 0 0 0 12-Feb-2009 13:08 System Volume Information
38 dr-xr-xr-x 0 0 0 8-Mar-2015 23:49 Utilities
17 dr-xr-xr-x 0 0 0 4-Apr-2013 10:25 found.000
82 dr-xr-xr-x 0 0 0 11-Aug-2014 11:21 temp_dvd
61647 -r--r--r-- 0 0 32413045 19-Nov-2014 14:34 Android Tablets For Dummies, 2nd Edition.pdf
#8 Post by Fiona »
Looks like your file system is slightly damaged!
I'd suggest to copy/backup important files first running testdisk.
If you list your files, at the bottom of the testdisk display, you'll find all the commands.
Standard path is the testdisk folder.
If you'd like to select another disk or partition, you can check that 2 dots in the upper area of the testdisk display and press enter.
Each time you'll get one directory up until you get to your disk selection.
If you'd like to copy your data to another folder, you can create a folder in advance and in testdisk easily mark it and use the right arrow key on your keyboard to enter it as your target.
If you'd like to repair your file system, you should open a command prompt with administrator privileges and running:
chkdsk driveletter: /r
As far as I've seen, the driveletter of your affected partition is F: !
http://forum.cgsecurity.org/phpBB3/down ... hp?id=3125
danyo
#9 Post by danyo »
Hi Fiona chkdsk doesn't work for me get message "unable to determine volume version and state".
As for copying to another disk, I can't see at the top the 2 dots you are referring to.
Please advise.
Thanks
