The Hard Disk seems too small - Can't be recovered
purplegreendave
#1 Post by purplegreendave »
I've just tried TestDisk on my external My Passport Ultra 2TB.
I was installing Win 7, only half paying attention and I messed up between sorting out error codes (too many hard drives in the system), trying to load a System Image backup and finally clean installing.
I ended up with a 2 raw partitions, and unallocated space. Test disk gave me these errors, I (probably stupidly) deleted the raw partitions and then tried again, but to no avail.
Most of the data is a second backup, all of the important stuff is a third backup, but there is a bunch of stuff I would like to retrieve that I don't have anywhere else.
After a deep search, this is my log file:
Thu Jun 18 07:03:01 2015
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20120504, curses lib: pdcurses build  3401
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=120030494720
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=500105740288
Disk \\.\PhysicalDrive0 - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive C: - 120 GB / 111 GiB - CHS 14592 255 63, sector size=512
Drive D: - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive2 - 2000 GB / 1862 GiB - CHS 243197 255 63
BAD_RS LBA=2825141096 6376514
     HPFS - NTFS          175856 229 30 269411 159  2 1502956638
This partition ends after the disk limits. (start=2825141096, size=1502956638, end=4328097733, disk end=3906963456)
NTFS at 243197/57/60
filesystem size           3906961408
sectors_per_cluster       8
mftmirr_lcn               244185087
clusters_per_mft_record   -10
     HPFS - NTFS              0  32 33 243197  57 60 3906961408
     NTFS found using backup sector, blocksize=4096, 2000 GB / 1862 GiB
The harddisk (2000 GB / 1862 GiB) seems too small! (< 2215 GB / 2063 GiB)
   * HPFS - NTFS              0  32 33 243197  57 60 3906961408
 1 P HPFS - NTFS              0  32 33 243197  57 60 3906961408
And this is my TestDisk window.
Searching gave me this thread:
http://forum.cgsecurity.org/phpBB3/the- ... t2770.html
Wherein the last post suggests "Write, confirm, BackupBS, confirm, Quit and reboot"
I'd just like to get some advice on whether this is the best course of action, or to write a new partition and then try a data recovery or a combination of both.
Re: The Hard Disk seems too small - Can't be recovered
Did you use TestDisk 64Bit?
TerstDisk 32Bit is recommended.
You can select Disk instead of Physical Drive.
purplegreendave
#3 Post by purplegreendave »
Ran 32bit, seems to have the same outcome
Fri Jun 19 17:30:06 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2000365289472
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Disk /dev/sdc - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Analyse Disk /dev/sdc - 2000 GB / 1862 GiB - CHS 243197 255 63
file_pread(6,16,buffer,225280(14/5/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,225280(14/5/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,224910(14/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,224926(14/0/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,224973(14/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,224989(14/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,225036(14/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,226958(14/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,13,buffer,224976(14/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,225052(14/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,225099(14/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,227021(14/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,225281(14/5/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,225282(14/5/58)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,225296(14/6/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,225343(14/6/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,225359(14/7/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,225406(14/7/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,227328(14/38/25)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,227330(14/38/27)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,227344(14/38/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,227391(14/39/25)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,227407(14/39/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,227454(14/40/25)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,229376(14/70/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,229378(14/70/59)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,229392(14/71/10)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,229439(14/71/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,229455(14/72/10)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,229502(14/72/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,231424(14/103/26)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,231426(14/103/28)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,231440(14/103/42)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,231487(14/104/26)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,231503(14/104/42)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,231550(14/105/26)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,233472(14/135/58)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,233474(14/135/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,233488(14/136/11)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,233535(14/136/58)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,233551(14/137/11)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,233598(14/137/58)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,235520(14/168/27)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,235522(14/168/29)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,235536(14/168/43)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,235583(14/169/27)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,235599(14/169/43)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,235646(14/170/27)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,237568(14/200/59)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,237570(14/200/61)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,237584(14/201/12)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,237631(14/201/59)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,237647(14/202/12)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,237694(14/202/59)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,239616(14/233/28)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,239618(14/233/30)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,239632(14/233/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,239679(14/234/28)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,239695(14/234/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,239742(14/235/28)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,241664(15/10/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,240975(15/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,240991(15/0/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,241038(15/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,241054(15/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,241101(15/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,243023(15/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,13,buffer,241041(15/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,241117(15/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,241164(15/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,241666(15/10/62)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,241666(15/10/62)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,241672(15/11/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,241680(15/11/13)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,241727(15/11/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,241743(15/12/13)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,241790(15/12/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,243712(15/43/29)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,243714(15/43/31)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,243728(15/43/45)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,243775(15/44/29)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,243791(15/44/45)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,243838(15/45/29)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,245760(15/75/61)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,245762(15/75/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,245776(15/76/14)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,245823(15/76/61)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,245839(15/77/14)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,245886(15/77/61)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,247808(15/108/30)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,247871(15/109/30)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,247871(15/109/30)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,247887(15/109/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,247934(15/110/30)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,249856(15/140/62)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,249858(15/141/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,249872(15/141/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,249919(15/141/62)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,249935(15/142/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,249982(15/142/62)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,251904(15/173/31)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,251906(15/173/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,251920(15/173/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,251967(15/174/31)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,251983(15/174/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,252030(15/175/31)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,253952(15/205/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,254078(15/207/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,254078(15/207/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,256000(15/238/32)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,256002(15/238/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,256016(15/238/48)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,256063(15/239/32)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,256079(15/239/48)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,256126(15/240/32)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,258048(16/16/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,259088(16/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,259088(16/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,258050(16/16/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,258050(16/16/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,258056(16/16/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,258064(16/16/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,258111(16/17/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,258127(16/17/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,258174(16/18/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,260096(16/48/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,260098(16/48/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,260112(16/48/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,260159(16/49/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,260175(16/49/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,260222(16/50/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,262144(16/81/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,262146(16/81/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,262160(16/81/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,262223(16/82/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,262223(16/82/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,262270(16/83/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,264192(16/113/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,264194(16/113/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,264208(16/113/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,264255(16/114/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,264271(16/114/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,264318(16/115/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,266240(16/146/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,266242(16/146/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,266256(16/146/19)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,266303(16/147/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,266319(16/147/19)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,266366(16/148/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,268288(16/178/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,268290(16/178/37)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,268304(16/178/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,268351(16/179/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,270336(16/211/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,270336(16/211/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,270337(16/211/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,270338(16/211/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,270352(16/211/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,270399(16/212/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,270415(16/212/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,270462(16/213/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,272384(16/243/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,272386(16/243/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,272400(16/243/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,272447(16/244/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,272463(16/244/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,272510(16/245/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,274432(17/21/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,273105(17/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,274434(17/21/7)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,280576(17/118/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,280576(17/118/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,280577(17/118/39)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,280578(17/118/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,348160(21/171/23)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,348160(21/171/23)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,348161(21/171/24)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,348162(21/171/25)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,385560(24/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,385560(24/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,391168(24/89/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,417792(26/1/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,442368(27/136/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,442368(27/136/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2379668(148/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,4841551(301/95/2)) ReadFile Data error (cyclic redundancy check).
file_pread(6,1,buffer,4841551(301/95/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,4841598(301/95/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,4843520(301/126/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,4845568(301/158/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,4845631(301/159/50)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,12374016(770/62/61)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,12462143(775/186/51)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,19759230(1229/243/37)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,343595008(21387/204/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,346072230(21542/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,346075262(21542/48/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,346075262(21542/48/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,346077184(21542/78/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,346077186(21542/78/43)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,346077200(21542/78/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,346077247(21542/79/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,353702014(22016/237/44)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,353705153(22017/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,353705153(22017/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,353705216(22017/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,353705984(22017/45/45)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,353705984(22017/45/45)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,353705985(22017/45/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,353705986(22017/45/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,353706000(22017/45/61)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,356126783(22167/221/6)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,356429887(22186/187/17)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,358836224(22336/133/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,358836224(22336/133/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,358887424(22339/180/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,358887424(22339/180/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,358894148(22340/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,358894148(22340/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,358894211(22340/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,358894211(22340/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,358893631(22340/24/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,358893631(22340/24/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,358893647(22340/24/36)) ReadFile Data error (cyclic redundancy check).
file_pread(6,11,buffer,358893694(22340/25/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,358895616(22340/55/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,358895618(22340/55/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,361355264(22493/82/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,361359360(22493/147/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,361359486(22493/149/55)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,373913679(23275/12/49)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,469822973(29245/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2637680362(164188/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2637680766(164188/8/43)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,2637680766(164188/8/43)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,2637682688(164188/39/12)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,2637682690(164188/39/14)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,2637682704(164188/39/28)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,2637682751(164188/40/12)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,2637682767(164188/40/28)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,2637682814(164188/41/12)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,2637684736(164188/71/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2637692928(164188/201/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2637692930(164188/201/48)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,2981055578(185562/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(6,1,buffer,2981055578(185562/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2981055641(185562/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,2981055641(185562/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2981054527(185562/15/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,2981054527(185562/15/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,2981054543(185562/16/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,2981054590(185562/16/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,2981056512(185562/47/22)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,14,buffer,2981056514(185562/47/24)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,2981056528(185562/47/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,2981056575(185562/48/22)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,2981056591(185562/48/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2981101725(185565/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,1,buffer,2981101725(185565/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,2981101733(185565/0/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2993552100(186340/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(6,1,buffer,2993552100(186340/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(6,8,buffer,2993552108(186340/0/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,3,buffer,2993552116(186340/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(6,3,buffer,2993552163(186340/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,2993552179(186340/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,2993552226(186340/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,2,buffer,2993554148(186340/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,13,buffer,2993552166(186340/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,8,buffer,2993552242(186340/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,11,buffer,2993552289(186340/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2993553424(186340/21/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2993610831(186343/167/16)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,2993703038(186349/100/54)) ReadFile Data error (cyclic redundancy check).
file_pread(6,1,buffer,2993703038(186349/100/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(6,16,buffer,2997135423(186563/13/10)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,2997215109(186568/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(6,16,buffer,3013105790(187557/41/3)) ReadFile Data error (cyclic redundancy check).
file_pread(6,2,buffer,3906963456(243197/57/61)) ReadFile The drive cannot find the sector requested.
file_pread(6,1,buffer,3906963456(243197/57/61)) ReadFile The drive cannot find the sector requested.
file_pread(6,14,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(6,1,buffer,3906963457(243197/57/62)) lseek err Invalid argument
file_pread(6,8,buffer,3906963463(243197/58/5)) lseek err Invalid argument
file_pread(6,3,buffer,3906963471(243197/58/13)) lseek err Invalid argument
file_pread(6,3,buffer,3906963518(243197/58/60)) lseek err Invalid argument
file_pread(6,8,buffer,3906963534(243197/59/13)) lseek err Invalid argument
file_pread(6,11,buffer,3906963581(243197/59/60)) lseek err Invalid argument
file_pread(6,2,buffer,3906965503(243197/90/29)) lseek err Invalid argument
file_pread(6,6,buffer,3906963458(243197/57/63)) lseek err Invalid argument
file_pread(6,1,buffer,3906963474(243197/58/16)) lseek err Invalid argument
file_pread(6,1,buffer,3906963521(243197/58/63)) lseek err Invalid argument
file_pread(6,1,buffer,3906963542(243197/59/21)) lseek err Invalid argument
file_pread(6,1,buffer,3906963592(243197/60/8)) lseek err Invalid argument
file_pread(6,1,buffer,3906965505(243197/90/31)) lseek err Invalid argument
#4 Post by Fiona »
Your disk displays some read errors.
Can you check your disk running CrystalDiskInfo.
The portable version is recommended, because the installer (exe) contains the adware Open Candy.
Your current partition table is empty.
There is no partition listed.
How many partitions did you have on your disk?
After Deep Search, one partition was found by its backup of the boot sector and uses the whole space.
Before you can run a boot sector diagnose, you could try to write your partition into your partition table.
If you get any read error, please let me know.
TestDisk will display the menu Boot to repair your boot sector using BackupBS.
Until yet, it's not recommended to avoid any problems that your OS would recognize a faulty file system and hang.
Close testdisk running quit and restart your computer.
Open testdisk and run Advanced / Boot.
Have a try to list your files.
It's only intended as a diagnose.
Please let me know.
purplegreendave
#5 Post by purplegreendave »
CrystalDiskInfo 6.5.2 (C) 2008-2015 hiyohiyo
                                Crystal Dew World : http://crystalmark.info/
    OS : Windows 7 Professional SP1 [6.1 Build 7601] (x64)
  Date : 2015/06/21 5:45:34
-- Controller Map ----------------------------------------------------------
 - Ricoh SD/MMC Host Controller [ATA]
 + Intel(R) 5 Series/3400 Series Chipset Family 6 Port SATA AHCI Controller - 3B2F [ATA]
   + ATA Channel 0 (0)
     - Samsung SSD 840 EVO 120GB ATA Device
   + ATA Channel 1 (1)
     - Hitachi HTS545050A7E380 ATA Device
   - ATA Channel 2 (2)
 - DAEMON Tools Lite Virtual SCSI Bus [SCSI]
-- Disk List ---------------------------------------------------------------
 (1) Samsung SSD 840 EVO 120GB : 120.0 GB [0/0/0, pd1] - sg
 (2) Hitachi HTS545050A7E380 : 500.1 GB [1/1/0, pd1]
 (3) WDC WD20NMVW-11AV3S2 : 2000.3 GB [2/X/X, sa1] - wd
           Model : Samsung SSD 840 EVO 120GB
        Firmware : EXT0DB6Q
   Serial Number : S1D5NSBF435404P
       Disk Size : 120.0 GB (8.4/120.0/120.0/120.0)
     Buffer Size : Unknown
     Queue Depth : 32
    # of Sectors : 234441648
   Rotation Rate : ---- (SSD)
       Interface : Serial ATA
   Major Version : ACS-2
   Minor Version : ATA8-ACS version 4c
   Transfer Mode : SATA/300 | SATA/600
  Power On Hours : 2026 hours
  Power On Count : 1350 count
     Host Writes : 2666 GB
Wear Level Count : 15
     Temperature : 35 C (95 F)
   Health Status : Good (100 %)
        Features : S.M.A.R.T., 48bit LBA, NCQ, TRIM
       APM Level : ----
       AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
05 100 100 _10 000000000000 Reallocated Sector Count
09 _99 _99 __0 0000000007EA Power-on Hours
0C _98 _98 __0 000000000546 Power-on Count
B1 _98 _98 __0 00000000000F Wear Leveling Count
B3 100 100 _10 000000000000 Used Reserved Block Count (Total)
B5 100 100 _10 000000000000 Program Fail Count (Total)
B6 100 100 _10 000000000000 Erase Fail Count (Total)
B7 100 100 _10 000000000000 Runtime Bad Block (Total)
BB 100 100 __0 000000000000 Uncorrectable Error Count
BE _65 _50 __0 000000000023 Airflow Temperature
C3 200 200 __0 000000000000 ECC Error Rate
C7 _99 _99 __0 000000000003 CRC Error Count
EB _99 _99 __0 000000000043 POR Recovery Count
F1 _99 _99 __0 00014D4E8150 Total LBA Written
-- IDENTIFY_DEVICE ---------------------------------------------------------
        0    1    2    3    4    5    6    7    8    9
000: 0040 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 5331 4435 4E53 4246 3433 3534 3034 5020 2020 2020
020: 0000 0000 0000 4558 5430 4442 3651 5361 6D73 756E
030: 6720 5353 4420 3834 3020 4556 4F20 3132 3047 4220
040: 2020 2020 2020 2020 2020 2020 2020 8001 4001 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0101
060: 4BB0 0DF9 0000 0007 0003 0078 0078 0078 0078 0F10
070: 0000 0000 0000 0000 0000 001F 850E 0044 006C 0060
080: 03FC 0039 746B 7D01 4163 7469 BC01 4163 407F 0001
090: 0004 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 4BB0 0DF9 0000 0000 0000 0008 4000 0000 5002 5388
110: A03A 4104 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0001
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000
220: 0000 0000 107F 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0000 0800 0000 0000 0000 0000
240: 0000 0000 0000 4000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 A9A5
-- SMART_READ_DATA ---------------------------------------------------------
     +0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 01 00 05 33 00 64 64 00 00 00 00 00 00 00 09 32
010: 00 63 63 EA 07 00 00 00 00 00 0C 32 00 62 62 46
020: 05 00 00 00 00 00 B1 13 00 62 62 0F 00 00 00 00
030: 00 00 B3 13 00 64 64 00 00 00 00 00 00 00 B5 32
040: 00 64 64 00 00 00 00 00 00 00 B6 32 00 64 64 00
050: 00 00 00 00 00 00 B7 13 00 64 64 00 00 00 00 00
060: 00 00 BB 32 00 64 64 00 00 00 00 00 00 00 BE 32
070: 00 41 32 23 00 00 00 00 00 00 C3 1A 00 C8 C8 00
080: 00 00 00 00 00 00 C7 3E 00 63 63 03 00 00 00 00
090: 00 00 EB 12 00 63 63 43 00 00 00 00 00 00 F1 32
0A0: 00 63 63 50 81 4E 4D 01 00 00 00 00 00 00 00 00
0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 68 10 00 53
170: 03 00 01 00 02 46 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C1
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 01 00 05 0A 00 00 00 00 00 00 00 00 00 00 09 00
010: 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
020: 00 00 00 00 00 00 B1 00 00 00 00 00 00 00 00 00
030: 00 00 B3 0A 00 00 00 00 00 00 00 00 00 00 B5 0A
040: 00 00 00 00 00 00 00 00 00 00 B6 0A 00 00 00 00
050: 00 00 00 00 00 00 B7 0A 00 00 00 00 00 00 00 00
060: 00 00 BB 00 00 00 00 00 00 00 00 00 00 00 BE 00
070: 00 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00
080: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
090: 00 00 EB 00 00 00 00 00 00 00 00 00 00 00 F1 00
0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E
           Model : Hitachi HTS545050A7E380
        Firmware : GG2OA6C0
   Serial Number : TEJ51139108ZTS
       Disk Size : 500.1 GB (8.4/137.4/500.1/500.1)
     Buffer Size : 8192 KB
     Queue Depth : 32
    # of Sectors : 976773168
   Rotation Rate : 5400 RPM
   Major Version : ATA8-ACS
   Minor Version : ATA8-ACS version 6
   Transfer Mode : ---- | SATA/300
  Power On Hours : 4704 hours
  Power On Count : 2370 count
     Temperature : 29 C (84 F)
        Features : S.M.A.R.T., APM, 48bit LBA, NCQ
       APM Level : 4001h [ON]
       AAM Level : ----
01 100 100 _62 000000000000 Read Error Rate
02 100 100 _40 000000000000 Throughput Performance
03 253 253 _33 000F00000001 Spin-Up Time
04 _66 _66 __0 00000000D5F2 Start/Stop Count
05 100 100 __5 000000000000 Reallocated Sectors Count
07 100 100 _67 000000000000 Seek Error Rate
08 100 100 _40 000000000000 Seek Time Performance
09 _90 _90 __0 000000001260 Power-On Hours
0A 100 100 _60 000000000000 Spin Retry Count
0C _99 _99 __0 000000000942 Power Cycle Count
BF 100 100 __0 000000000000 G-Sense Error Rate
C0 100 100 __0 000000340037 Power-off Retract Count
C1 _75 _75 __0 00000003F03A Load/Unload Cycle Count
C2 206 206 __0 002E0005001D Temperature
C4 100 100 __0 000000000000 Reallocation Event Count
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
DF 100 100 __0 000000000000 Load/Unload Retry Count
        0    1    2    3    4    5    6    7    8    9
000: 045A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 5445 4A35 3131 3339 3130 385A 5453
020: 0003 4000 0004 4747 324F 4136 4330 4869 7461 6368
030: 6920 4854 5335 3435 3035 3041 3745 3338 3020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 1706 0000 005E 0040
080: 01FC 0028 746B 7D69 6163 7469 BC49 6163 407F 0038
090: 0039 4001 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 6030 3A38 0000 0000 0000 0000 6003 826C 5000 CCA7
110: 1FCE 3943 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 000B
130: 0000 0000 2182 1CF1 FA00 0000 4000 0400 0003 0000
140: 0000 0505 0802 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 3232 4236 0000 2802 0000 5DBD 2518 8000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0000
210: 0000 0000 0000 0000 0000 0000 0000 1518 0000 0000
220: 0000 0000 101F 0021 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 03E0 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 CEA5
000: 10 00 01 0B 00 64 64 00 00 00 00 00 00 00 02 05
010: 00 64 64 00 00 00 00 00 00 00 03 07 00 FD FD 01
020: 00 00 00 0F 00 00 04 12 00 42 42 F2 D5 00 00 00
030: 00 00 05 33 00 64 64 00 00 00 00 00 00 00 07 0B
040: 00 64 64 00 00 00 00 00 00 00 08 05 00 64 64 00
050: 00 00 00 00 00 00 09 12 00 5A 5A 60 12 00 00 00
060: 00 00 0A 13 00 64 64 00 00 00 00 00 00 00 0C 32
070: 00 63 63 42 09 00 00 00 00 00 BF 0A 00 64 64 00
080: 00 00 00 00 00 00 C0 32 00 64 64 37 00 34 00 00
090: 00 00 C1 12 00 4B 4B 3A F0 03 00 00 00 00 C2 02
0A0: 00 CE CE 1D 00 05 00 2E 00 00 C4 32 00 64 64 00
0B0: 00 00 00 00 00 00 C5 22 00 64 64 00 00 00 00 00
0C0: 00 00 C6 08 00 64 64 00 00 00 00 00 00 00 C7 0A
0D0: 00 C8 C8 00 00 00 00 00 00 00 DF 0A 00 64 64 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 2D 00 01 5B
170: 03 00 01 00 02 71 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A3
000: 10 00 01 3E 00 00 00 00 00 00 00 00 00 00 02 28
010: 00 00 00 00 00 00 00 00 00 00 03 21 00 00 00 00
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
030: 00 00 05 05 00 00 00 00 00 00 00 00 00 00 07 43
040: 00 00 00 00 00 00 00 00 00 00 08 28 00 00 00 00
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
060: 00 00 0A 3C 00 00 00 00 00 00 00 00 00 00 0C 00
070: 00 00 00 00 00 00 00 00 00 00 BF 00 00 00 00 00
080: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00
090: 00 00 C1 00 00 00 00 00 00 00 00 00 00 00 C2 00
0A0: 00 00 00 00 00 00 00 00 00 00 C4 00 00 00 00 00
0B0: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00
0C0: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 00
0D0: 00 00 00 00 00 00 00 00 00 00 DF 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 89
           Model : WDC WD20NMVW-11AV3S2
        Firmware : 01.01A01
   Serial Number : WD-WX91AA3W9886
       Disk Size : 2000.3 GB (8.4/137.4/2000.3/----)
     Queue Depth : 32
    # of Sectors : 3906963633
   Rotation Rate : 5200 RPM
       Interface : USB (Serial ATA)
   Minor Version : ----
   Transfer Mode : SATA/300 | SATA/300
  Power On Hours : 527 hours
  Power On Count : 210 count
     Temperature : 27 C (80 F)
   Health Status : Caution
       APM Level : 0080h [ON]
       AAM Level : ----
01 200 200 _51 0000000003A1 Read Error Rate
03 219 200 _21 000000000FD2 Spin-Up Time
04 100 100 __0 000000000146 Start/Stop Count
05 200 200 140 000000000000 Reallocated Sectors Count
07 100 253 __0 000000000000 Seek Error Rate
09 100 100 __0 00000000020F Power-On Hours
0A 100 100 __0 000000000000 Spin Retry Count
0B 100 100 __0 000000000000 Recalibration Retries
0C 100 100 __0 0000000000D2 Power Cycle Count
C0 200 200 __0 000000000071 Power-off Retract Count
C1 200 200 __0 00000000081F Load/Unload Cycle Count
C2 125 104 __0 00000000001B Temperature
C4 200 200 __0 000000000000 Reallocation Event Count
C5 198 198 __0 0000000002B8 Current Pending Sector Count
C6 100 253 __0 000000000000 Uncorrectable Sector Count
C8 100 253 __0 000000000000 Write Error Rate
        0    1    2    3    4    5    6    7    8    9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2057 442D 5758 3931 4141 3357 3938 3836
020: 0000 4000 0000 3031 2E30 3141 3031 5744 4320 5744
030: 3230 4E4D 5657 2D31 3141 5633 5332 2020 2020 2020
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0100
060: FFFF 0FFF 0000 0107 0003 0078 0078 0078 0078 0010
070: 0000 0000 0000 0000 0000 001F 9F06 0004 004C 0000
080: 03FE 0000 706B 7C69 6123 7069 BC49 6123 007F 00FF
090: 0001 0080 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 88B1 E8DF 0000 0000 0000 0000 6003 0000 5001 4EE2
110: 5EF0 1233 0000 0000 0000 0000 0000 0000 0000 4018
120: 4018 0000 0000 0000 0000 0000 0000 0000 0021 0000
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 7035 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 1450 0000 0000
220: 0000 0000 103E 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 A6A5
000: 10 00 01 2F 00 C8 C8 A1 03 00 00 00 00 00 03 27
010: 00 DB C8 D2 0F 00 00 00 00 00 04 32 00 64 64 46
020: 01 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 2E 00 64 FD 00 00 00 00 00 00 00 09 32
040: 00 64 64 0F 02 00 00 00 00 00 0A 32 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 64 64 D2 00 00 00 00 00 00 C0 32
070: 00 C8 C8 71 00 00 00 00 00 00 C1 32 00 C8 C8 1F
080: 08 00 00 00 00 00 C2 22 00 7D 68 1B 00 00 00 00
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
0A0: 00 C6 C6 B8 02 00 00 00 00 00 C6 30 00 64 FD 00
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00
0C0: 00 00 C8 08 00 64 FD 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 5C 94 01 7B
170: 03 00 01 00 02 FF 05 A3 01 00 00 00 00 00 00 00
180: 00 00 01 08 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CE
000: 10 00 01 33 C8 C8 C8 C8 C8 C8 C8 C8 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 00 64 64 64 64 64 64 64 64 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0C0: 00 00 C8 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5D
Crystal Disk Output.
There was only 1 partition, it's my file backup drive - so I don't think it should be a bootable partition anyway?
I hit "write' after the deeper search this time:
That's my data! I feel like I'm getting close. It's offering to try and copy them somewhere but this is my biggest drive and I can't fit all of that anywhere else. If I just write a new partition using testdisk will the files be lost?
#6 Post by Fiona »
The problem is, if you repair a boot sector, your partition gets visible to windows and a corrupted file system can cause problems.
CrystalDiskInfo displays your disk as follow:
It easily means that you should backup all data first.
After backup you can have a try to repair your boot sector and run some maintenance like chkdsk driveletter: /r etc..
If it doesn't work, your disk should probably be replaced.
Before you decide to repair your boot sector, you should copy as much important data as possible.
purplegreendave
#7 Post by purplegreendave »
I've used testdisk to rewrite a partition table and run CHKDSK. Crystal Disk still gives me an error however
#8 Post by Fiona »
Was chkdsk succesful?
Did you get your files back?
Caution on crystaldiskinfo means, that you should backup your data and your disk should be replaced soon.
After datarecovery, some users formatted their disk using a tool and the procedure was something like low level format.
It means that each sektor will be overridden by zeros.
In some cases it helped to get a disk working again.
But you should keep an eye on it and check it from time to time.
Most important is alway to have a backup.
