no partition found after deep search.
appius
#1 Post by appius »
hi,
I'm trying to fix a 300 IDE disk that turned to raw.
unfortunately, the partition can't be found even after a deep search.
what should I do to restore it?
thanks in advance for your help.
Disk /dev/sda - 300 GB / 279 GiB
New options :
Dump : No
Align partition: Yes
Expert mode : Yes
Analyse Disk /dev/sda - 300 GB / 279 GiB - CHS 36479 255 63
file_pread(4,2,buffer,586041344(36479/98/36)) lseek err Invalid argument
file_pread(4,1,buffer,586041344(36479/98/36)) lseek err Invalid argument
file_pread(4,1,buffer,586041343(36479/98/35)) lseek err Invalid argument
file_pread(4,14,buffer,586041345(36479/98/37)) lseek err Invalid argument
file_pread(4,3,buffer,586041359(36479/98/51)) lseek err Invalid argument
file_pread(4,3,buffer,586041406(36479/99/35)) lseek err Invalid argument
file_pread(4,8,buffer,586041422(36479/99/51)) lseek err Invalid argument
file_pread(4,11,buffer,586041469(36479/100/35)) lseek err Invalid argument
file_pread(4,2,buffer,586043391(36479/131/4)) lseek err Invalid argument
Re: no partition found after deep search.
Currently you have no partition in your partition table.
In case, you should run "Deeper Search" also, to have a try to find your partition by its backup of the boot sector.
If a partition would be found, you can select it and press p to have a try to list your files.
Please copy and paste the content of your testdisk.log again.
appius
#3 Post by appius »
thanks Fiona for you quick answer!
but as I said, this the deeper search results already.
#4 Post by Fiona »
I'm not sure that Deeper Search was running but Quick Search instead.
That's your current situation (partition table) and no partition available or empty.
It's your result of Quick Search, which follows after Analyse (your current partition structure).The result has been that NO partition was found!
The write interface displays 2 opportunities.
Write and Deeper Search.
Are you sure that you were running Deeper Search?
Deeper Search can find more partitions by the backup of the boot sector and recover them.
If you were running Deeper Search, there would be another/second Search displayed and I don't find it?
appius
#5 Post by appius »
I've just redone the two searches, Fonia. nothing found.
after the deeper one, i don't have any more option than quit.
here the log:
Store new MBR code
Store new MBR code
appius
#6 Post by appius »
do you see anything weird?
appius
#7 Post by appius »
what do those lseek err Invalid argument stand for?
#8 Post by Fiona »
As far as I've seen (already a long time ago) pread and pwrite had something to do with cygwin (unix for windows).
Despite that, partitions should be found and be recoverable.
Unfortunately testdisk didn't find any partition by the backup of the boot sector.
You can try to recover files using photorec instead.
You can use PhotoRec / FileOpt and press s to deselect all filetypes and just activate those where you'd like to recover.
So PhotoRec will not recover unnecessary files.
appius
#9 Post by appius »
thanks for your answer Fiona.
I've tried photorec, but it gave me a bunch of corrupted files with stupid names. useless.
any other solution?
can't the boot sector be recreated?
appius
#10 Post by appius »
up.
