Files Recovered are damaged
omega11
#1 Post by omega11 »
I loose more than 100 GB of data (music, videos, images, documents, pdf, doc, etc.) in strange circumstance, I share partition (NTFS) only for share data between Linux (Debian 8) and Windows (Windows 7). After use Windows I reboot and start Linux when I tried to mount the share partition I get error like Windows is yet using. I reboot and start Windows my surprise when windows started was that the share partition was empty all my data loose it.
After that I come back to Linux and use Photorec to recover files. Photorec took more than 24 hours for complete the task and recover more than 500,000 files. Here my second surprise only some jpg, png and mp3 were recovered. All others files (doc, pdf, docx, odt, txt, html, php, css, djvu, avi, mkv, etc. etc.) are damaged.
Is there any form that can I repair the recovered files?
P.D.: No suggest me search in internet. I have more than 24 hours searching and not found any that work.
Thanks in advance!
I will appreciate any help!
Re: Files Recovered are damaged
Can you run a diagnose using testdisk?
You should run Analyse, Quick Search and if nothing would be found, Deeper Search also.
If partitions are found, please slect them and press p to have a try to list your files.
TestDisk creates a testdisk.log file.
Cna you open it and copy and paste the content into your next post?
omega11
#3 Post by omega11 »
I believe that my partition is this 7 L HPFS - NTFS 25165 0 1 60801 254 63 572508405
In my system is /dev/sda7
testdisk.log
Tue Jul 7 03:38:24 2015
OS: Linux, kernel 3.16.0-4-amd64 (#1 SMP Debian 3.16.7-ckt11-1 (2015-05-24)) x86_64
Compiler: GCC 4.4
Compilation date: 2015-04-18T13:05:16
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20120504, curses lib: ncurses 5.7
/dev/sda: size 976773168 sectors
/dev/sda: user_max 976773168 sectors
/dev/sda: dco 976773168 sectors
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST9500325AS, S/N:S2WDCTER, FW:D005DEM1
Disk /dev/sda - 500 GB / 465 GiB - ST9500325AS
Analyse Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63
NTFS at 0/32/33
NTFS at 12/223/20
NTFS at 25165/0/1
Info: size boot_sector 572497393, partition 572508405
1 * HPFS - NTFS 0 32 33 12 223 19 204800
2 P HPFS - NTFS 12 223 20 12748 86 10 204595200
3 P Linux Swap 12748 118 43 13234 173 59 7811072
4 E extended LBA 13234 173 60 60801 254 63 764168962
5 L Linux 13234 206 29 13842 131 49 9762816
X extended 13842 163 1 25164 246 42 181893201
6 L Linux 13842 164 19 25164 246 42 181893120
X extended 25164 254 1 60801 254 63 572508468
