Thanks again for the help. I just followed your instructions on the last post. I was able to list the files in the hard drive by pressing "p" and gone through all the file selections and copy selected files. However, the copying process isn't fun.
it says "copying, please wait... 0 ok, 4458 failed", then went straight back to listed files..
**One strange thing I found was that at the very beginning, when I select the disk -> analyze -> no partition shown with a message "Partition: Read Error". I have to do Quick Search to get the " >* HPFS - NTFS 0 32 33 91197 195 6 1465090048" to show up. is that normal?***
Log file as below. (i've deleted a bunch of failed file listed in the log due to post message limitation)
Fri Jul 10 21:08:41 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=80026361856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=750127153152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=80026361856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=750127153152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=79919316992
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=750048509952
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=208666624
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=479723520000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=20065550336
filewin32_getfilesize(\\.\I:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Incorrect function.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=108027904
Disk /dev/sdb - 80 GB / 74 GiB - CHS 9729 255 63, sector size=512
Disk /dev/sdc - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512
Disk /dev/sdd - 750 GB / 698 GiB - CHS 91197 255 63, sector size=512
Disk /dev/sde - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512
Drive C: - 79 GB / 74 GiB - CHS 9716 255 63, sector size=512
Drive D: - 104 MB / 100 MiB - CHS 12 255 63, sector size=512
Drive E: - 750 GB / 698 GiB - CHS 91188 255 63, sector size=512
Drive F: - 208 MB / 199 MiB - CHS 25 255 63, sector size=512
Drive G: - 479 GB / 446 GiB - CHS 58323 255 63, sector size=512
Drive H: - 20 GB / 18 GiB - CHS 2439 255 63, sector size=512
Drive J: - 108 MB / 103 MiB - CHS 13 255 63, sector size=512
Analyse Disk /dev/sdd - 750 GB / 698 GiB - CHS 91197 255 63
Partition: Read error
NTFS at 0/32/33
filesystem size 1465090048
mftmirr_lcn 2
NTFS, blocksize=4096, 750 GB / 698 GiB
file_pread(7,8,buffer,1465092096(91197/195/7)) ReadFile The drive cannot find the sector requested.
file_pread(7,1,buffer,1465092096(91197/195/7)) ReadFile The drive cannot find the sector requested.
file_pread(7,1,buffer,1465092097(91197/195/8)) lseek err Invalid argument
file_pread(7,14,buffer,1465092098(91197/195/9)) lseek err Invalid argument
file_pread(7,3,buffer,1465092112(91197/195/23)) lseek err Invalid argument
file_pread(7,3,buffer,1465092159(91197/196/7)) lseek err Invalid argument
file_pread(7,8,buffer,1465092175(91197/196/23)) lseek err Invalid argument
file_pread(7,11,buffer,1465092222(91197/197/7)) lseek err Invalid argument
file_pread(7,2,buffer,1465094144(91197/227/39)) lseek err Invalid argument
1 P HPFS - NTFS 0 32 33 91197 195 6 1465090048
file_pread(7,1,buffer,0(0/0/1)) ReadFile Data error (cyclic redundancy check).
Store new MBR code
New options :
Dump : No
Align partition: Yes
Expert mode : No
NTFS at 0/32/33
mftmirr_lcn 2
Fri Jul 10 22:08:36 2015
NTFS at 0/32/33
mftmirr_lcn 2
1 * HPFS - NTFS 0 32 33 91197 195 6 1465090048
Sat Jul 11 08:51:31 2015
NTFS at 0/32/33
mftmirr_lcn 2
Store new MBR code
NTFS at 0/32/33
mftmirr_lcn 2
Store new MBR code
Failed to read $MFTMirr: Input/output error.
Error reading $Mft record(s): Input/output error.
NTFS at 0/32/33
mftmirr_lcn 2
file_pread(7,16,buffer,2064(0/32/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(7,1,buffer,2064(0/32/49)) ReadFile The request could not be performed because of an I/O device error.
dir_partition inode=5
5 dr-xr-xr-x 0 0 0 9-Jul-2015 08:18 .
5 dr-xr-xr-x 0 0 0 9-Jul-2015 08:18 ..
503 dr-xr-xr-x 0 0 0 6-Jul-2015 17:11 $RECYCLE.BIN
506 dr-xr-xr-x 0 0 0 26-Mar-2015 22:57 56b7defda2aa10b264a574ff1ce9b8
6715 dr-xr-xr-x 0 0 0 6-Jul-2015 17:39 57d1df684cfd19d4688936245685a458
6356 dr-xr-xr-x 0 0 0 11-Jun-2015 23:35 Blackhat.2015.WEB.RIP.CAM.AUDIO.XviD.AC3-FANTA
585 dr-xr-xr-x 0 0 0 4-Feb-2015 22:28 Cadimage
525 dr-xr-xr-x 0 0 0 4-May-2014 15:37 Daniel
557 dr-xr-xr-x 0 0 0 29-Apr-2014 14:00 Documents
46121 dr-xr-xr-x 0 0 0 13-Feb-2015 12:25 Fonts
40403 dr-xr-xr-x 0 0 0 24-May-2014 18:57 Home Remodel
3928 dr-xr-xr-x 0 0 0 29-Oct-2013 14:22 L&M Guitar Complete
468 dr-xr-xr-x 0 0 0 27-Dec-2014 15:56 Movies
1319 dr-xr-xr-x 0 0 0 16-Jan-2014 10:46 Music
77302 dr-xr-xr-x 0 0 0 7-Sep-2013 14:25 P90X
6354 dr-xr-xr-x 0 0 0 11-Jun-2015 23:32 Pitch.Perfect.2.2015.1080p.HC.WEBRip.x264.AAC2.0-RARBG
41 dr-xr-xr-x 0 0 0 9-Jul-2015 07:45 Softwares
36 dr-xr-xr-x 0 0 0 13-Apr-2015 11:25 System Volume Information
40344 dr-xr-xr-x 0 0 0 24-May-2014 18:49 THHS
370 dr-xr-xr-x 0 0 0 13-Feb-2015 12:42 TV Shows
5560 dr-xr-xr-x 0 0 0 9-Jun-2015 16:12 Thesis Timelapse
532 dr-xr-xr-x 0 0 0 8-May-2015 08:29 backupToshiba
7754 dr-xr-xr-x 0 0 0 23-May-2014 20:50 books
5631 dr-xr-xr-x 0 0 0 9-Jun-2015 11:45 微電影
2484 dr-xr-xr-x 0 0 0 13-Feb-2015 12:30 文化局
6360 dr-xr-xr-x 0 0 0 9-Jul-2015 08:12 暑期育樂營
24134 -r--r--r-- 0 0 28747 15-Jan-2013 01:23 0114PatrickCheng-1a-7750488200-97.pdf
24134 -r--r--r-- 0 0 26 15-Jan-2013 01:23 0114PatrickCheng-1a-7750488200-97.pdf:Zone.Identifier
24135 -r--r--r-- 0 0 49402 15-Jan-2013 01:23 0114PatrickCheng-1b.pdf
24135 -r--r--r-- 0 0 26 15-Jan-2013 01:23 0114PatrickCheng-1b.pdf:Zone.Identifier
24124 -r--r--r-- 0 0 366166 25-Oct-2012 11:28 Creme Brulee Recipes _ Ricardo.pdf
19014 -r--r--r-- 0 0 4117148 15-Mar-2008 16:45 M4V06544.MP4
3922 -r--r--r-- 0 0 936 10-Nov-2008 18:02 MessageLog.lang.xsl
3920 -r--r--r-- 0 0 9921 4-Dec-2008 16:20 MessageLog.xsl
17046 -r--r--r-- 0 0 14605 4-Feb-2011 01:44 Thank you letter to Matt.docx
1087 -r--r--r-- 0 0 36349 4-Nov-2010 12:49 bookmark.html
24123 -r--r--r-- 0 0 35205 2-Jan-2013 08:44 bookmarks_1_1_13.html
17117 -r--r--r-- 0 0 374301 26-Jan-2012 16:07 jess19875143681483815.xml
17118 -r--r--r-- 0 0 5217204 4-Mar-2011 00:31 jovanjen08112463445640 - Archive.xml
17119 -r--r--r-- 0 0 5181080 12-Apr-2011 10:30 jovanjen08112463445640 - Archive1.xml
17120 -r--r--r-- 0 0 5127494 15-Jan-2012 21:25 jovanjen08112463445640.xml
1086 -r--r--r-- 0 0 36864 21-May-2010 00:23 V小小的改了一下的澎湖行程.doc
opendir(/cygdrive/c/pagefile.sys) failed
file_pread(7,16,buffer,6309266(392/187/6)) ReadFile Data error (cyclic redundancy check).
file_pread(7,1,buffer,6309266(392/187/6)) ReadFile Data error (cyclic redundancy check).
ntfs_readdir failed for cluster 528: Input/output error
Can't create file //Documents/BIM 2011/BIM Team Meeting.docx: No such file or directory
Can't create file //Documents/BIM 2011/LOD.jpg: No such file or directory
Can't create file //Documents/BIM 2011/LOD.jpg_Zone.Identifier: No such file or directory
Can't create file //Documents/BIM 2011/Software need for the competition.docx: No such file or directory
Can't create file //Documents/BIM 2011/Webcor_Open_BIM_2011.pdf: No such file or directory
Can't create file //Documents/BIM 2011/Webcor_Open_BIM_2011.pdf_Zone.Identifier: No such file or directory
ERROR: Couldn't set the file's date and time for //Documents/BIM 2011
Can't create file //Documents/CM 213 winter 2010/Santa Barbara Airport.docx: No such file or directory
Can't create file //Documents/CM 213 winter 2010/Tracy Projcet Schedule.mpp: No such file or directory
Can't create file //Documents/CM 213 winter 2010/Traffic control Presentation.pptx: No such file or directory
Can't create file //Documents/CM 213 winter 2010/cambria schedule.JPG: No such file or directory
Can't create file //Documents/CM 213 winter 2010/company logo.jpg: No such file or directory
Can't create file //Documents/CM 213 winter 2010/company logo.tif: No such file or directory
Can't create file //Documents/CM 213 winter 2010/culvert.bpn: No such file or directory
Can't create file //Documents/CM 213 winter 2010/culvert.pln: No such file or directory
Can't create file //Documents/CM 213 winter 2010/environmental research.docx: No such file or directory
Can't create file //Documents/CM 213 winter 2010/google earth airport.JPG: No such file or directory
Can't create file //Documents/CM 213 winter 2010/mass diagram table 2.3.xlsx: No such file or directory
Can't create file //Documents/CM 213 winter 2010/mass diagram table 2.3.xlsx_Zone.Identifier: No such file or directory
Can't create file //Documents/CM 213 winter 2010/pipe 3d.jpg: No such file or directory
Can't create file //Documents/CM 213 winter 2010/runway1.JPG: No such file or directory
Can't create file //Documents/CM 213 winter 2010/runway2.JPG: No such file or directory
Can't create file //Documents/CM 213 winter 2010/runwaymain.JPG: No such file or directory
Can't create file //Documents/CM 213 winter 2010/santa barbara airport schedule.mpp: No such file or directory
Can't create file //Documents/CM 213 winter 2010/santa barbara airport schedule.xml: No such file or directory
Can't create file //Documents/CM 213 winter 2010/santa barbara statments.docx: No such file or directory
Can't create file //Documents/CM 213 winter 2010/santa-barbara-airport-address.jpg: No such file or directory
Can't create file //Documents/CM 213 winter 2010/santa-barbara-airport-address.jpg_Zone.Identifier: No such file or directory
Can't create file //Documents/CM 213 winter 2010/schedule1.JPG: No such file or directory
Can't create file //Documents/CM 213 winter 2010/schedule2.JPG: No such file or directory
ERROR: Couldn't set the file's date and time for //Documents/CM 213 winter 2010
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Cabiniet Layout/.._AFP_AFPINFO: No such file or directory
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Cabiniet Layout/._AFP_AFPINFO: No such file or directory
ERROR: Couldn't set the file's date and time for //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Cabiniet Layout
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Conditions of Approval/.._AFP_AFPINFO: No such file or directory
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Conditions of Approval/._AFP_AFPINFO: No such file or directory
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Conditions of Approval/Phase 3 Development Agreement.PDF: No such file or directory
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Conditions of Approval/Phase 3 Development Agreement.PDF_AFP_AFPINFO: No such file or directory
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Conditions of Approval/Phase 3 Development Agreement.PDF_AFP_RESOURCE: No such file or directory
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Conditions of Approval/Resolution No. 9233 - TR 34920.pdf: No such file or directory
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Conditions of Approval/Resolution No. 9233 - TR 34920.pdf_AFP_AFPINFO: No such file or directory
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Conditions of Approval/Resolution No. 9233 - TR 34920.pdf_AFP_RESOURCE: No such file or directory
ERROR: Couldn't set the file's date and time for //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Conditions of Approval
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Option/.._AFP_AFPINFO: No such file or directory
Can't create file //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Option/._AFP_AFPINFO: No such file or directory
ERROR: Couldn't set the file's date and time for //Documents/CM 311 Spring 2010/CM 311/Construction Documents/Option
Can't create file //0114PatrickCheng-1b.pdf: Is a directory
Can't create file //Creme Brulee Recipes _ Ricardo.pdf: Is a directory
Can't create file //M4V06544.MP4: Is a directory
Can't create file //bookmark.html: Is a directory
Can't create file //bookmarks_1_1_13.html: Is a directory
file_pread(7,16,buffer,0(0/0/1)) ReadFile Data error (cyclic redundancy check).
Store new MBR code
NTFS at 0/32/33
mftmirr_lcn 2
Store new MBR code
