I am not able to install TestDisk via sudo apt-get install testdisk any longer
I read that TestDisk is portable and no install was needed from the downloaded folder but that isnt working
Maybe this is only for Windows OS
I am using a Linux Mint 14 live CD to recovery my partition table.
I am failing at a compile from source code method
Would it be better to create a Live restore disk containing Testdisk?
TestDisk install for Linux Mint
Re: TestDisk install for Linux Mint
Did you already try this too?
http://www.itworld.com/article/2718298/ ... nt-13.html
Especially with:
If it doesn't work, I've only experience running knoppix Live-CD.
Info:
Under programs you'll find a folder called knoppix.
Start the root terminal and get root with writing sudo -s to get full access to all your disks.
Have another try to run testdisk.
Especially with:
I'm not as much a linux tech savvy.sudo apt-get install testdisk -y
Info:
