Recover files
drummermandan02
Recover files
#1 Post by drummermandan02 »
Hi.
I have followed various instructions on here regarding restoring files from my HDD.
In windows the partition that I wish to boot from & contains all of my data on is viewed as RAW.
But when I run a scan with TestDisk it see's the partition as P HPFS - NTFS.
To get the drive to boot in windows do I need to change the property to '*' (Primary Bootable) rather than 'P' (Primary).
I can view my files after I have run a deeper scan & have managed to recover some.
Any help please? I would massively appreciate it.
Re: Recover files
If you'd like to boot from any partition, it must be set to star * for primary activ.
Only 1 partition can be active.
RAW means unformatted.
Cause can be either a damaged boot sector or faulty file system.
Can you copy and paste the content of your testdisk.log into your next post?
Have you been able to list your files?
drummermandan02
Re: Recover files
#3 Post by drummermandan02 »
When I return to my laptop I will post the content of the log file.
Before I start changing anything on the drive - I am cautious that I will lose my files, how do I make a full backup of the drive?
drummermandan02
Re: Recover files
#4 Post by drummermandan02 »
Ok, the contents of the Log file is:
Thu Jul 16 11:31:26 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=729074753536
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=15728640000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=484272267264
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Y:)=20971520000
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 729 GB / 679 GiB - CHS 88638 255 63, sector size=512
Drive E: - 15 GB / 14 GiB - CHS 1912 255 63, sector size=512
Drive F: - 484 GB / 451 GiB - CHS 58876 255 63, sector size=512
Drive Y: - 20 GB / 19 GiB - CHS 2549 255 63, sector size=512
Analyse Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63
check_part_i386 1 type DE: no test
NTFS at 12/223/20
NTFS at 1925/27/23
1 P Dell Utility 0 32 33 12 223 19 204800
2 * HPFS - NTFS 12 223 20 1925 27 22 30720000
3 P HPFS - NTFS 1925 27 23 60801 48 31 945844272
Re: Recover files
#5 Post by Fiona »
You can clone your disk using hdd raw copy:
http://hddguru.com/software/HDD-Raw-Copy-Tool/
Please be carefull and set the right source and destination/target.
I've only got your current partition table.
There are no info about your boot sector and file system.
Can you run TestDisk / Advanced (select your affected partition and Boot?
Would need info about your boot sector and the backup of your boot sector.
Are they both OK?
Until yet, don't use Write nor RepairMFT.
drummermandan02
Re: Recover files
#6 Post by drummermandan02 »
Hi.
Sorry about the late reply.
Is this what you are after?
Mon Jul 27 15:12:26 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1093120
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=4702208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1093120
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4702208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1093120
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=4702208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=15728640000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=484272267264
Disk /dev/sdb - 1093 KB / 1067 KiB - 2135 sectors, sector size=512
Disk /dev/sdc - 4702 KB / 4592 KiB - 9184 sectors, sector size=512
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive G: - 15 GB / 14 GiB - CHS 1912 255 63, sector size=512
Drive H: - 484 GB / 451 GiB - CHS 58876 255 63, sector size=512
NTFS at 12/223/20
NTFS at 1925/27/23
NTFS, blocksize=4096, 15 GB / 14 GiB
NTFS, blocksize=4096, 484 GB / 451 GiB
ntfs_boot_sector
NTFS at 1925/27/23
NTFS at 1925/27/23
filesystem size 945844272
mftmirr_lcn 16
Status: OK
Status: OK
Sectors are identical.
Re: Recover files
#7 Post by Fiona »
The boot sector and its backup are OK.
Di you have a try to list your files?
Can you run another Deeper Search?
I'd like to compare the partition in your current partition table and your found partition.
Copy and paste the content of your testdisk.log again.
Can you check your disk using CrystalDiskInfo?
The portable version is recommeded, the installer (exe) contains adware OpenCandy.
drummermandan02
Re: Recover files
#8 Post by drummermandan02 »
I can list the files & I have been able to recover most files, but the gui isn't as friendly as Windows, so I'm worried I've left something behind. So I would like to get the hdd bootable again so I can have a final hunt around before retiring the hdd.
I will get the results from the other searches & post it asap.
Thank you so much for your help!
