Invalid FAT Boot Sector
zadie1
#1 Post by zadie1 »
I need help dealing with an external HDD turned RAW. (Toshiba 1 GB SATA). I ran TestDisk analayze and got this screen:
TestDisk analyzed - before quick search.jpg (71.44 KiB) Viewed 18047 times
I then ran Quick Search and got this screen:
TestDisk analyzed - after quick search.jpg (90.86 KiB) Viewed 18047 times
I then ran Deeper Search and got this:
TestDisk analyzed - after deeper search.jpg (64.46 KiB) Viewed 18047 times
Is there any hope for this disk? It contains about 900 GB of MP3 files from iTunes. How can I proceed, please?
thank you.
zadie1
Re: Invalid FAT Boot Sector
#2 Post by zadie1 »
Also, I ran CrystalDisk and got these results:
Does this mean the HDD is physically damaged?
zadie1
#3 Post by zadie1 »
And the TestDisk Log file from the first Analysis:
Sat Jul 18 15:51:04 2015
OS: Windows Vista (6002) SP2
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdf)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive5)=1000204886016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=489311698944
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=10737418240
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\K:)=1000202043392
Disk /dev/sdf - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Drive C: - 489 GB / 455 GiB - CHS 59488 255 63, sector size=512
Drive D: - 10 GB / 10 GiB - CHS 1305 255 63, sector size=512
Drive K: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Analyse Disk /dev/sdf - 1000 GB / 931 GiB - CHS 121601 255 63
test_FAT()
1 P FAT32 LBA 0 32 33 121601 25 24 1953519616
sector_size 32768
cluster_size 0
reserved 780
fats 0
dir_entries 0
sectors 18
media 00
fat_length 0
secs_track 0
heads 0
hidden 1258291200
total_sect 1128420181
Invalid FAT boot sector
#4 Post by Fiona »
You still have a FAT32 LBA-partition in your partition table.
You can try to run TestDisk / Advanced / Boot and RebuildBS.
If it'd be successful, you can use the menu List to have a try to list your files.
Until yet, you shouldn't use Write nor RepairFAT!
If your data are listed, you can use testdisk to copy them to another healthy disk or partition.
During listing your files, at the bottom of the display you´ll find all the commands.
Caution in CrystalDiskInfo means that you should immediately run a backup/recovery.
Afterwards you can try to repair your file system running chkdsk driveletter: /r.
Recheck your disk again.
If it doesn't work for you, your disk should be replaced soon.
zadie1
#5 Post by zadie1 »
Thank you so much Fiona! Was able to recover all my files and soon I will be happily listening to my iTunes collection again.
