3TB external drive became RAW
oyvdei
#1 Post by oyvdei »
Hello, please I'm in need for some help.
I got an Seagate expansion external drive with 3TB. A little time ago, the USB 3.0 port got broken, so I bought a new enclosure with a new connector from another manufacturer. When I connected it to my computer, I couldn't get access and Windows wanted me to format the drive. The drive was visible in Windows though, as station (F:) as before, but with no other info. When I ran chkdsk, it said it had became RAW and couldn't do anything.
I got a tip from a friend to try TestDisk. I read a lot on this board to get a hang of what I had to do. After Create, I saw the drive as "Disk /dev/sdb - 3000 GB/2794 GiB". I chose Intel then Analyse and Quick Search. After that, I couldn't see my files and folders in List, just some other stuff, so I ran Deep Search.
When the Deep Search was finished after many hours, I went in the partition I thought was right (I wasn't able to see a List with files here). In the hope of fixing the problem, I probably hesitated a bit and didn't exactly knew what I was doing. I chose Write and rebooted.
Now, Windows don't recognize the drive anymore, it is not visible. It's still visible in TestDisk though, so I try again now.
I take screenshots this time as seen below, as the same with the file log. Can you see from this if I still can recover my drive? I have many valuable files on it I don't want to lose.
The test_logical error didn't show the first time I tried before I wrote the partition the first time.
oyvdei
Re: 3TB external drive became RAW
#2 Post by oyvdei »
And this is the result after Quick Search. I'm currently running the Deep Search now. So far it reports about an invalid FAT boot sector.
Can it be I have to change something in the disk geometry?
Following is the log file prior to the Quick Search:
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=750156374016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=214748364800
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=258513829888
filewin32_getfilesize(\\.\E:) GetFileSize err Feil funksjon.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Feil funksjon.
filewin32_getfilesize(\\.\G:) GetFileSize err Feil funksjon.
filewin32_setfilepointer(\\.\G:) SetFilePointer err Feil funksjon.
Disk /dev/sda - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Drive C: - 214 GB / 200 GiB - CHS 26108 255 63, sector size=512
Drive D: - 258 GB / 240 GiB - CHS 31429 255 63, sector size=512
 1 E extended LBA         267349  89  4 315694  89  3  776662425
Change partition type:
test_logical:
file_pread(5,1,buffer,1565566975(364801/98/33)) lseek err Invalid argument
file_pread(5,1,buffer,1565566976(364801/98/34)) lseek err Invalid argument
file_pread(5,14,buffer,1565566977(364801/98/35)) lseek err Invalid argument
file_pread(5,3,buffer,1565566991(364801/98/49)) lseek err Invalid argument
file_pread(5,3,buffer,1565567038(364801/99/33)) lseek err Invalid argument
file_pread(5,8,buffer,1565567054(364801/99/49)) lseek err Invalid argument
file_pread(5,11,buffer,1565567101(364801/100/33)) lseek err Invalid argument
file_pread(5,2,buffer,1565569023(364801/131/2)) lseek err Invalid argument
test_logical:
test_logical:
test_logical:
test_logical:
Edit: The Deeper Search is now finished.
The second partition shows 923 GB/860 GiB and the third shows 2076 GB/1933 GiB.
oyvdei
#3 Post by oyvdei »
Hi. I'm still stuck right where I was..
I am in fact able to access my files with another data recovery program. But to save my files that way and then format my drive, will be a very twisted and time consuming process for me.
I'll be very happy if there is a way to repair and recover my partition(s) with TestDisk, so I once again can get directly access to all my files without formatting the drive :)
#4 Post by Fiona »
Sry for late.
TestDisk Deeper Search might be time consuming too.
But it would be necessary to run and find your lost partition.
Your current partition table only contain an extended partition and a FAT16-Partition which is probably wrong.
Looks like that you aborted Deeper Search:
oyvdei
#5 Post by oyvdei »
Hi again, and thanks for your reply.
I had in fact run Deeper Search a couple of times when I made this topic, but I messed up the log file, I guess.
Anyway, I still haven't got any further with my lost partition. I'm starting to think I have to manually add a partition or change something with the disk geometry.
But I don't know, so any further help is much appreciated.
I ran Deeper Search again, and here is my current log file:
Mon Aug  3 17:39:49 2015
test_logical:
BAD_RS LBA=12354332 14010884
     FAT16 >32M           268118  94 37 316462  57 53  776644046
file_pread(5,2,buffer,1565566976(364801/98/34)) lseek err Invalid argument
   L FAT16 >32M           268118  94 37 316462  57 53  776644046
add_ext_part_i386: max
add_ext_part_i386: min
 1 E extended LBA         268118   0  1 316462 254 63  776662425
 5 L FAT16 >32M           268118  94 37 316462  57 53  776644046
BAD_RS LBA=2549719637 2743124
file_pread(5,3,buffer,2549719637(426062/14/22)) lseek err Invalid argument
file_pread(5,1,buffer,2549719637(426062/14/22)) lseek err Invalid argument
     FAT32 LBA            426062  14 22 477639 244 42  828599016
This partition ends after the disk limits. (start=6844686933, size=828599016, end=7673285948, disk end=5860533168)
BAD_RS LBA=3331482131 11102796
file_pread(5,3,buffer,3331482131(474724/132/52)) lseek err Invalid argument
file_pread(5,1,buffer,3331482131(474724/132/52)) lseek err Invalid argument
     FAT16 >32M           474724 132 52 727142 157  6 4055096700
This partition ends after the disk limits. (start=7626449427, size=4055096700, end=11681546126, disk end=5860533168)
BAD_RS LBA=2756655873 5875812
file_pread(5,3,buffer,2756655873(438943/61/32)) lseek err Invalid argument
file_pread(5,1,buffer,2756655873(438943/61/32)) lseek err Invalid argument
     FAT16 >32M           438943  61 32 551234 218 22 1803964797
This partition ends after the disk limits. (start=7051623169, size=1803964797, end=8855587965, disk end=5860533168)
The harddisk (3000 GB / 2794 GiB) seems too small! (< 5980 GB / 5570 GiB)
interface_load
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63 Fri Jul 31 12:10:04 2015
 1 D No partition         267349  89  4 315694  89  3  776662425
check_part_i386 1 type 00: no test
Invalid partition structure.
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
test_logical:
oyvdei
#6 Post by oyvdei »
Hi Fiona. As mentioned in my previously reply, I ran Deeper Search properly as you requested. Is there anything in my log file that can help identify the issue with the partitions?
chops
#7 Post by chops »
oh my friend I am in the same boat as you. I think our problem was using the wrong kind of enclosure. I might of used one that could not handle 3TB, I read somewhere this can cause read issues. Just try to run Photorec dude, see if you can backup your files and then just format the drive and reupload your stuff. Stop using the enclosure, plug the HDD into your computer (if you have a desktop). Im currently using the Photorec tutorial and i see all my files popping up again. I ran chkdsk too after I changed the enclosure, fkd the HDD lol. Damn you windows!
