A 2TB disk that I use to backup some (fortunately not too important) data broke down during a automated write procedure. I found it unmounted without any partition/partition table.
I cloned the disk using ddrescue and ran testdisk on the copy. It stopped with "The harddisk (2000 GB / 1863 GiB) seems too small! (< 2209 GB / 2057 GiB)...partition can't be recovered".
(I let testdisk run not only once. Since there was no partition I wrote a partition table via testdisk during one of my earlier tries. A single ext4 partition it was. I still have the original broken disk and could clone it again...)
I was able to get the data using photorec. So, it is there...
Why is the disk "too small"?
And, of course: Is there any chance to get the (structured) data back?
Marc
Here is the testdisk log:
Thu Jul 23 17:27:38 2015
OS: Linux, kernel 3.11-2-amd64 (#1 SMP Debian 3.11.8-1 (2013-11-13)) x86_64
Compiler: GCC 4.8
Compilation date: 2013-10-17T13:40:45
ext2fs lib: 1.42.8, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size 976773168 sectors
/dev/sda: user_max 976773168 sectors
/dev/sdb: size 3907029168 sectors
/dev/sdb: user_max 3907029168 sectors
/dev/sdb: native_max 3907029168 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size 3907029168 sectors
/dev/sdc: user_max 3907029168 sectors
/dev/sdc: native_max 3907029168 sectors
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AAKX-00ERMA0, S/N:WD-WCC2EF474817, FW:15.01H15
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM001-1CH164, S/N:W2F0NVG8, FW:CC24
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM001-1CH164, S/N:W2F0NVB6, FW:CC24
Disk /dev/sdc - 2000 GB / 1863 GiB - ST2000DM001-1CH164
1 P Linux 0 32 33 243201 78 13 3907026944
block_group_nr 1
recover_EXT2: s_block_group_nr=1/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 488378368
recover_EXT2: part_size 3907026944
Linux 0 32 33 243201 78 13 3907026944 [scratch1]
ext4 blocksize=4096 Large file Sparse superblock Backup superblock, 2000 GB / 1863 GiB
* Linux 0 32 33 243201 78 13 3907026944 [scratch1]
1 P Linux 0 32 33 243201 78 13 3907026944 [scratch1]
block_group_nr 1
block_group_nr 3
recover_EXT2: s_block_group_nr=3/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 25
recover_EXT2: s_block_group_nr=25/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
BAD_RS LBA=3768620075 8241850
FAT32 234585 191 18 268567 99 52 545915069
This partition ends after the disk limits. (start=3768620075, size=545915069, end=4314535143, disk end=3907029168)
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 625
recover_EXT2: "e2fsck -b 20480000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=625/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 729
recover_EXT2: "e2fsck -b 23887872 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=729/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2187
recover_EXT2: "e2fsck -b 71663616 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2187/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2401
recover_EXT2: "e2fsck -b 78675968 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2401/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 3125
recover_EXT2: "e2fsck -b 102400000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=3125/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 6561
recover_EXT2: "e2fsck -b 214990848 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=6561/14904, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
dir_partition inode=2
ext2fs_dir_iterate failed with error 2133571387.
