Hi everyone:
I need to recover .xar files,but I can't see them in the filetype list.How can I add them to Photorec?Somebody can do that?
Thank you very much.
About .xar files Topic is solved
Re: About .xar files
I have uploaded a new 7.1-WIP version. Can you try it ?
OK.Thank you very much for your help.
Oh
It doesn't work on 32 bits Windows system. When I extract the folder it says something like "unexpected format" and I can't execute it (even from the zip file)
Can you fix it?
Regards
Can you fix it?
Regards
I have reuploaded the 7.1-WIP version. Can you empty your navigator cache and download it again ?
